RV.Net Open Roads Forum: Towing a Jeep (too much for my setup?)
 > Towing a Jeep (too much for my setup?)
Page of 5
jgorm
san diego
Posted: 08/20/07 02:13pm Link  |  Print  |  Notify Moderator
I've been thinking about towing a jeep behind the TC for cruising around camp. My truck is a '97 3500 DRW with airbags, and sway bar. The camper is a '90 vacationer, probably a 11.5 that weighs a lot (??). I have a reese hitch (rated at 10K with 1200lb tongue), and a 36" extension (rated at 5K with a 500lb tongue). The main hitch receiver is larger size than normal, but is normal size on the end of the extension. I would add some sort of braking system to the jeep when towing. I'll be flat towing it also. Has anybody done something similar? I'm not sure on my weights, but am probably overweight by a fair bit.
'97 C3500 4 door dually with big heavy camper The Camper My Ford EFI Tuning Website
Polishnurse
Schodack, NY
Posted: 08/20/07 02:27pm Link  |  Print  |  Notify Moderator
Here is a system.
click
SpoiledRotten
Central Mississippi
Posted: 08/20/07 02:41pm Link  |  Print  |  Notify Moderator
I don't think "pulling" a Jeep will cause you any grief. I pull a Jeep Wrangler with my set up and my set up is a 2000 F-250 and a 33' 5th wheel.
Just the 3 of us...SpoiledRotten, TotallyRotten, and ALittleRotten
2000 F-250 Lariat, CC
7.3 PSTD-Superchipped
2005 33RL2 New Vision - AKA "SpoiledRotten"
2000 Jeep Wrangler Sahara Edition
jgorm
san diego
Posted: 08/20/07 02:42pm Link  |  Print  |  Notify Moderator
Polishnurse wrote:
Here is a system.
click
Very cool. I'm more worried about the extra weight, but this tow system looks like it would need no adjustments.
jgorm
san diego
Posted: 08/20/07 02:49pm Link  |  Print  |  Notify Moderator
Looks like i should be in the clear considering your rig!
GRice
Alsip,IL
Posted: 08/20/07 03:07pm Link  |  Print  |  Notify Moderator
You talking about a Jeep Wrangler? If so you wont have any problems with weight, growing up with friends in the late 60s that had Ford 3/4 tons with 11 ft campers, pulled jeeps with no problems and none used any braking systems...though I would recommend a good braking systems for emergencies.
Gary & Susan R
2005 Alfa See-Ya Founder
2005 Chevy Avalanche
jgorm
san diego
Posted: 08/20/07 03:22pm Link  |  Print  |  Notify Moderator
Yes Jeep Wrangler. Probably a TJ (97 and newer). Should be picking on up real soon. I think they weigh in the mid 3000's.
Bigfootf350
Loveland, CO
Posted: 08/20/07 03:32pm Link  |  Print  |  Notify Moderator
I towed my 2002 Wrangler several times before I sold it. Several hundred miles in Wyoming and Colorado up and down passes. Had no problems but I did notice some fading on the brakes coming down passes. That tow bar with a braking system looks like cheap insurance to me.
2000 Ford F350 Airlift bags overload extensions. 1999 bigfoot 3000 10.11
jefe 4x4
West Slope, Northern Sierra Nevada
Posted: 08/20/07 06:15pm Link  |  Print  |  Notify Moderator
I had nothing but woe flat towing my heavy Jeep. It weighs close to 5000 lbs. Two near catastrophic incidents. I do have a SB truck. That didn't help. Allot of the control loss was due to those 37x13.50 tires on steel wheels. What's that? 500 lbs of wheels and tires?
The tail just wagged the dog a little too much.
I now tow the Jeep on a car hauler (see sig). Much better. Mostly for the brakes and superior control and handling.
regards, as always, jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
mowermech
Billings, MT
Posted: 08/20/07 07:44pm Link  |  Print  |  Notify Moderator
I tow my Jeep Wrangler pickup (I know, they didn't build a pickup, it is a custom job) behind my truck/camper regularly. Let's see...once to Deadwood and back, once to Moab and back, once to Hungry Horse Reservoir and back, several local trips, I guess we could say several thousand miles with no problems. My hitch extension is 41 inches, secured to the camper bumper and guyed with chains to the truck bumper.
I agree with the car trailer, though. one of these days, I gonna get one!
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toad: '05 Wrangler Unlimited
Toy: 1999 Dodge QC LWB, Cummins, Auto, 4X4
Other toys: 2 Kawasaki Brute Force 750 ATVs.
Page of 5
