RV.Net Open Roads Forum: Truck Campers: Polar Cub & EU2000i learnings
 > Polar Cub & EU2000i learnings
msiminoff
Silicon Valley, CA
Posted: 09/05/07 06:43pm Link  |  Print  |  Notify Moderator
I just returned from a boondocking trip where I ran my Polar Cub from the EU2000 for 8-10 hours/day, for six days at an altitude of 3910 ft and air temps in the mid-high 90's.
During the first day, the generator overloaded several times... each time about 40 minutes apart (Red "overload" light ON, no power output, engine returns to idle). It took until the 3rd or 4th time re-starting the generator for me to remember that I had left the refrigerator on the "AUTO" setting and the 120V heating element was kicking on and increasing the current load on the genn'y by another 325 Watts. As soon as I switched the fridge to "LP" the Honda ran the AC in ECO mode without any problem at all... including cycling the compressor (thermostat was set to 72deg).
I used a total of about 5.5 gallons of gasoline which works out to around 0.1 gal/hr (10hrs/gal). When I needed the run the microwave (2-3 minutes/day), I simply shut-off the AC at the wall thermostat. I did have several other small AC loads on from time to time (battery chargers and laptop power supplies)... these appeared to have no adverse effect on the generator. Since I have plenty of solar power to charge the house batteries, I don't have the power converter connected at all.
During the week I used approximately 2.5 gallons (10lbs) of propane to run the fridge and water heater continuously (1 shower/day plus washing hands and dishes). The fridge stayed right around 38F and the freezer was around 0F... I had frozen ice-cream all week in the middle of the Nevada desert [emoticon]
Hope this info helps somebody.
Cheers
-Mark
* This post was last edited 09/05/07 10:17pm by msiminoff *   View edit history
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
kottfam6wi
South Central Wisconsin
Posted: 09/05/07 06:53pm Link  |  Print  |  Notify Moderator
What size a/c do you have that you were able to run only .1 gallons per hour?
Joe
Our Family Pictures
Joe & Erika
Chris-16, Emily-12, Jessica-10, Jason-9, Derek-4
"Rallies Attended 19 1/2" (Wahoo!! we're catching up!)
2005 Dodge Ram 2500 Quad Cab 5.9L CTD
2005 K-Z Durango 315BH 5th Wheel (2nd Camper)
trapperdick
Bridgton,Me.
Posted: 09/05/07 06:55pm Link  |  Print  |  Notify Moderator
Good post Mark.....I'm thinking of a 2000i and Polar Cub for my Lance.......glad to have that input. TD
OLDER AND BOLDER,,,,,N1ATF
Ford F-350 Dually Diesel, Lance 9SC, Harley Davidson Heritage Softail, 12 ft Hallmark trailer and Skeeter the camping beagle ">.........
jefe 4x4
West Slope, Northern Sierra Nevada
Posted: 09/05/07 07:09pm Link  |  Print  |  Notify Moderator
Hmm? (in the Church lady voice) We wouldn't have been to BURNING MAN!, would we? HMM?
Mark, thanks for the info.
regards, as always, jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
Crazy Ray
Monroe,La
Posted: 09/05/07 08:01pm Link  |  Print  |  Notify Moderator
Should have got a YAMAHA 2400. JMO
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
msiminoff
Silicon Valley, CA
Posted: 09/05/07 08:03pm Link  |  Print  |  Notify Moderator
The A/C is a Coleman Polar Cub. It draws between 900 & 1000 Watts (depending on fan speed and system pressure) on my Watt-meter. I think it is rated at 8300BTU's.
kottfam6wi
Posted: 09/05/07 08:04pm Link  |  Print  |  Notify Moderator
Why?? It's heavier, louder, and sucks more gas. So why should he have gotten a yamaha 2400?
kottfam6wi
Posted: 09/05/07 08:11pm Link  |  Print  |  Notify Moderator
It's amazing what those little Honda's can do isn't it. I wish I only ran .1 gph, but with the wife and kids we just run too much junk.
Joe
msiminoff
Silicon Valley, CA
Posted: 09/05/07 08:16pm Link  |  Print  |  Notify Moderator
This post is simply a report about my experience with my specific set-up. It is NOT about generator comparisons or brand wars.
Please feel free to start another post if you would like to have a lengthy debate about the virtues of one generator over another.
firemanchris
Idaho
Posted: 09/05/07 08:29pm Link  |  Print  |  Notify Moderator
Thanks for the info. I have the same set up but haven't tested it yet.
