RV.Net Open Roads Forum: Truck Campers: Rancho 9000 Adjuster Knob
 > Rancho 9000 Adjuster Knob
BradW
Mayor of Flat Rock
Posted: 09/08/07 10:59pm Link  |  Print  |  Notify Moderator
Rancho 9000 shock adjuster knob.
Adjuster knob assembly is removed by loosening the two hex screws.
The round disc is the top of the dampening adjuster piston. When that piston is pressed inward, the dampening is increased. When folks report that they can't turn their adjuster knob because it is locked up, it's actually the piston locked up because it is rusted or corroded to the cylinder wall. If you saved your receipt, Rancho will replace your shock under the lifetime warranty.
Adjuster knob set on setting 1.
Adjuster knob set on setting 9.
Adjuster knob disassembled.
Dampening piston undepressed.
Dampening piston depressed. It only moves about 1/4" or so and it takes about 30 lbs of force to bottom it out.
* This post was edited 09/10/07 06:36pm by BradW *
Wake Up America
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
anothernewuser
Deming, New Mexico
Posted: 09/09/07 07:38am Link  |  Print  |  Notify Moderator
Very helpful, informative photos. Thanks.
Michigan Rod
Troy,MI.,USA
Posted: 09/09/07 08:31am Link  |  Print  |  Notify Moderator
Brad, I just replaced my two rear Ranchos and packed the adjusting knobs with wheel bearing grease. The original ones rusted up after 3 Michigan winters. I'm almost tempted to run regular shocks during the winter and keep the Ranchos just for summer travel. I really like the Ranchos but feel the company needs to do something about water proofing them for us snow bound Yankees..
2003Chevy LT3500,crew cab,4x4,Duramax/Allison,Firestone air bags w/in cab controls,Rancho RS 9000X shocks,cabover struts,Happijac tiedowns.Rhino bed liner. ReeseTowBeast.
2004 Lance 1161,generator,sofa,twin beds,rear observation camera,Chet's AirFoil
MikeyLikesIt
North Texas
Posted: 09/09/07 09:53am Link  |  Print  |  Notify Moderator
Thanks Brad, I just bought ranchos for the jeep. I'll put some water proof grease in there before I install them.
By the way...who's Donny? [emoticon]
Mikey
Fireballsocal
Rancho Cucamonga Ca.
Posted: 09/09/07 12:47pm Link  |  Print  |  Notify Moderator
And did you remember to call him?
Raften
Northern Calfornia
Posted: 09/09/07 01:18pm Link  |  Print  |  Notify Moderator
I haven't seen them on the web for awhile but there was a guy making replacement knobs out of brass and sst that looked like they would work well. I think they had a O ring to seal.
'01 Dodge 3500 CTD, Lance 1121, Air Bags, Rancho 9000, All Wheels Under Power When Needed, A Few Engine Mods For Increased HP
Burning Grease, 800 ft/lbs. of torque from something you throw away.
BradW
Mayor of Flat Rock
Posted: 09/09/07 02:01pm Link  |  Print  |  Notify Moderator
I'm just glad it didn't say "Call Donna"! [emoticon] [emoticon]
trapperdick
Bridgton,Me.
Posted: 09/09/07 02:07pm Link  |  Print  |  Notify Moderator
Good post Brad,,,,thank you....TD
OLDER AND BOLDER,,,,,N1ATF
Ford F-350 Dually Diesel, Lance 9SC, Harley Davidson Heritage Softail, 12 ft Hallmark trailer and Skeeter the camping beagle ">.........
lm17
NJ
Posted: 09/09/07 02:10pm Link  |  Print  |  Notify Moderator
i'm on my second set of Rancho's. These knobs freeze up all the time. I'm giving up (Plus I don't have my receipt). I just ordered bilstiens from camping world (one free with purchse this week). I'll give them a try.
2016 Forest River Forester 2801QSF Class C
FF1063
NY
Posted: 09/09/07 02:31pm Link  |  Print  |  Notify Moderator
* This post was edited 10/09/07 12:49pm by FF1063 *
