jdj5125
texas
i have a dodge ram 2500 diesel i have a 43 ft 5th wheel trailer i weigh it at cat scale i was 19660 gross weight am i good at this weight
TravelinDog
Nevada
jdj5125 wrote: i have a dodge ram 2500 diesel i have a 43 ft 5th wheel trailer i weigh it at cat scale i was 19660 gross weight am i good at this weight
Thank you
DW-gray
Lompoc, CA
That is difficult to determine. I recommend you visit FifthWheelStreet.com and follow the 4-Step Weight Safety Plan.
Dave Gray
RV Safety Educator & Consultant
08 Dodge Ram 3500 4X4, Dually, 6.7L Diesel, 09 Heartland Cyclone 4012
Mike134
Elgin, IL
2019 F150 varies between 7000 and 7100 fully loaded ready to travel with trailer hitched.
Prime Time Adventurer 21rbs 6300 wet and stocked with food, usually 16% tongue weight to start.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
MikeRP
Westerville
My new 2020 Ram 3500 Longhorn long bed SRW Crew Cab with my B&W slider from my old truck, tool box loaded, 46 gallon ATI tanks full, me in the cab, reg tank full, def full loaded for a trip weighs 9300 lbs, 3980 on the drive axle. I have a 4156 lb payload. But I’m still very close to Max w my fifth wheel running 14,000 lbs.
I’ll probably switch to a Reese Goosebox and I may go to super singles, 295/70R18 at 4080 lb load rating per tire.
Pete_k
Stantonville Tn
Mine only weights 35,560. Thats full of fuel and hooked to the truck. But then again the truck has 470 gallons of diesel in it.
My Steer axle weights 11,200 lbs
2022 Ram Big Horn DRW
2016 Eagle Cap 1200
2012 Landmark Key Largo
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
Mike134
Elgin, IL
Pete_k wrote: Mine only weights 35,560. Thats full of fuel and hooked to the truck. But then again the truck has 470 gallons of diesel in it.
![[image]](https://i.imgur.com/OvIjslEl.jpg)
Nice to see someone who follows through about "get a bigger truck"
Always thought those preachers that stop at a 1 ton were hypocrites.
Cummins12V98
on the road
Surprised you are ONLY 1,560# heavier than I am.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
garyp4951
TN
Finally weighed my newest 5er.
2018 Ram 2500 CC SB Cummins, 2019 Vanleigh Pinecrest
Without rv, steer 4880, drive 3540
With rv, steer 4940, drive 5860, trailer axle 8740
Gross 19540
dyow2022
florida
encurtador.com.br/cdeqM
