RV.Net Open Roads Forum: Truck Campers: Exterior compartment re-organization
 > Exterior compartment re-organization
Spott
SE Michigan
Posted: 09/27/07 10:51am Link  |  Print  |  Notify Moderator
My left rear compartment contains…
The water pump,
Low point drains,
Gray & black dump valves,
The Happi-Jac controller/cable/remote,
A clear elbow for dumping,
A spare umbilical cord (just because I have happen to have one)
A wireless thermometer to keep an eye on basement temps in the winter
As you can see in the photo it’s a bit messy/cluttered.
Believe it or not it only took me almost two years to think about a solution. I decided on a very simple piece of metal bent into a “Z” and pop-riveted to the door.
Wow, it took a whole 5 minutes and I wonder why I hadn't thought of it on the first day.
Here’s with just the Happi-Jac cord.
And if you're asking why I have the “Remove before flight” attached to the end of the cord, it reminds me to flip out the front jacks before raising the camper.
Me - Kim - Spot
rhode trip
Rhode Island
Posted: 09/27/07 11:06am Link  |  Print  |  Notify Moderator
Good idea, Bruce! Thanks for posting.
2002 Dodge 3500 CTD/DRW/
2000 Northern Lite 10-2000cd
www.LapelPinPlanet.com
Beddows
Abbotsford, Canada
Posted: 09/27/07 11:26am Link  |  Print  |  Notify Moderator
Good idea, you need new rims.
jjohnson1179
Girdletree, Maryland
Posted: 09/27/07 11:34am Link  |  Print  |  Notify Moderator
and why are you hauling that camper on a six lug chevy the weight police is going to see that good work on the door that has givin me and idea
JIMMY JOHNSON
93 Ford F-250 V8 5.8
Sold my tc and got a TT
1987 LANCE 980 11.3
TRUCK CAMPER MAGAZINE
FEET IN THE SAND COLD BEER IN MY HAND
Troutguy
Midwest USA
Posted: 09/27/07 11:55am Link  |  Print  |  Notify Moderator
Actually I think that Spott has his camper mounted on an old farm wagon, when it's off of his truck, and as far as the nice wheels.......this is Michigan where winter road salt usage is why this is called "The Rust Belt"!
I think that the wheels look like they're in pretty good condition!![emoticon]
Spott, another nice idea!
TG
* This post was edited 09/27/07 12:05pm by Troutguy *
2018 RAM 3500 Crew Cab 4x4 DRW Cummins HO, Aisin trans and 4:10 gears, 14,000 lb GVWR
2018 Arctic Fox 1140 Truck Camper & Honda EU2000
Spott
SE Michigan
Posted: 09/27/07 12:57pm Link  |  Print  |  Notify Moderator
Ding, Ding, Ding, you are a winner...
Although it's not mounted, it just sits on the wagon in he barn.
Super_Dave
Harrisville, UT
Posted: 09/27/07 02:03pm Link  |  Print  |  Notify Moderator
I have a question, why does anybody want a clear elbow for dumping?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Matthew_B
The boonies near Dallas, Oregon
Posted: 09/27/07 04:20pm Link  |  Print  |  Notify Moderator
If you use a sprayer or flush system, you can tell when the "solids" have been removed from the tank.
Mexray
Stockton, Ca
Posted: 09/27/07 04:24pm Link  |  Print  |  Notify Moderator
To tell when the holding tank is clean when it's being flushed after draining...you can see the clear water and know it's rinsed.
...although, I have to admit I just look at the end of the hose a it runs down the drain to tell when it's clear...a 'clear' elbow would probably be easier to see...[emoticon]
2000 Lance 1010 atop 1999 Ford F-350 4x4
5.4L, Supercab, XM Radio, SWR, 325/65R18 ProComp XAT's
4" lift, DynaTrac Hub Conversion, 4.56 gears
Rear Detroit TruTrac, SuperSprings, Warn hubs.
Any time is 'Baja Time'
Jeff3161
Pasco,Washington
Posted: 09/27/07 06:08pm Link  |  Print  |  Notify Moderator
Wow simple mod, sometimes those are the best. As far aas seeing when the turds are gone I'll skip that.
