RV.Net Open Roads Forum: What did you do to your Class C MH today???
 > What did you do to your Class C MH today???
Page of 444
camperdave
northern, California
Posted: 12/21/18 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
I got the motorhome all prepped and ready for a Christmas trip to Southern California! Beds made, batteries charged, coffee loaded, presents hidden. Head out first thing in the morning.
Hope my heater can keep up with the cold winter temps down there. [emoticon]
* This post was edited 12/28/18 10:45am by camperdave *
camperdave
Posted: 12/28/18 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Heater did fine. [emoticon]
On the way home I hit up a CAT scale. I had 3/4 full water, full fuel, and empty grey/black tanks. We were otherwise pretty lightly loaded (end of trip so no food).
With no people in it, but one 35ish pound dog sitting on the passenger seat, our weights are:
Front axle: 3940
Rear axle: 8240
Total: 12180
Specs on the door sticker are:
Front GAWR: 4600
Rear GAWR: 9450
GVWR: 14050
So I've got 1870 pounds available, 660 in front, and 1210 in the rear. I wish Fleetwood had made the floor of the rear (very large) storage areas stronger. There is no way I could load more than a few pounds on those flimsy plastic tubs without them pulling out from the wall! [emoticon] I had assumed it was no big deal since I wouldn't want heavy stuff that far back, but with over 1000 pounds to play with...
I think some kind of structural support for those tubs is in order this winter! [emoticon]
2004 Fleetwood Tioga 29v
TreeSeeker
San Diego
Posted: 12/28/18 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Camperdave wrote:
The pilot would light, but die as soon as I released the knob or turned it to any temperature position. Some interneting said the likely problem was the thermocouple, however I read two different folks say that stuffing some foil into the knob solved this problem for them.
I had problems with the knobs before and I lubed them with "Super Slick Stuff." It comes in spray can and does lube but dries to a clear finish. You probably wouldn't want to use any regular lube spray due the flammability issue. I just sprayed a tiny bit into the valve where the knob shaft enters it, then turned it on/off a few times to make sure it penetrates before it dries. Turn off the gas at the tank before doing this.
No problems since.
GKAbbott
On the road
Posted: 02/01/19 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
After driving a few hundred miles and setting up camp, I sat and admired the quality workmanship. Then I started planning how to improve upon the factory shortcomings. When we return home in a few weeks, I'll get on it.
sullivanclan
Grand Junction, Colorado
Posted: 02/04/19 11:49pm Link  |  Quote  |  Print  |  Notify Moderator
The wife and I are preparing for a winter trip from Colorado South to see family in the Yuma Arizona area for a few weeks. (Heck maybe help to build a wall). This past weekend we got the oil changed, fluids checked, annual brake inspection and tire check. Did a thorough cleaning and since I got done with some of that I took up rewiring an old rear camera and got it to work, replaced brake light bulbs and lubed the automatic steps and ran the generator. Then we took a 50-mile test drive for a pizza lunch and returned. All ran well.
The weekend before we practiced putting on some tire cables in case of winter weather before we hit the nice warm weather in Southern Utah. Evaluating replacing the front tires as they are going on five years...bummer.[emoticon]
2003 Ford 450 Jayco Greyhawk 25D
1986 Jeep Renegade
2011 Jeep Unlimited Rubicon JK
bobndot
Posted: 02/05/19 06:32am Link  |  Quote  |  Print  |  Notify Moderator
camperdave ,
They're called 'Pathetic Tubs' . [emoticon]
I can also see the need for something to be done with those tubs.
Can you imagine being pulled over by a LEO and in your sideview mirror , you see him/her walking towards you carry your plastic tub full of rv accessories ? [emoticon]
I added a 60"x30" piece of plywood, that covered 2 tubs, like a lid.
I used 4" 'E-ternabond' tape as a seal all around the edge of the tub, where the plastic tub lip meets the wood compartment . It's now dry and free from road-splash/insects.
As for now it works by allowing me to store some lighter 'not often used' items in the tubs, the plywood allows bulky heavier items to now be supported.
If I needed stronger support in the tubs themselves , I would buy or weld up a basket and use it as a liner , attaching it to the wooden framework of the rear compartment.
Sqdancecaller
Minford, Ohio
Posted: 02/05/19 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Finally had a warm day so did the monthly generator run, put a few items in the coach and sat dreaming of our upcoming 12 day trip to Florida. Heading to the St. Petersburg Indy race on March 10th and it can't get here soon enough. Did make a trip to our local tire shop and did some checking about getting new tires and made arrangements to have that done in a few weeks. So ready to get the coach back out on the road and away from the snow and ice.
2013 Thor Chateau 32 ft.
sullivanclan
Posted: 02/05/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
What kind of tires are you thinking about Sqdancecaller? Your first set since My 2013? My unit has firestone transforce HT, a bit cheaper than others, but I haven't had any problems with them. Not sure what I might do next.
Page of 444
