wsdepa
Raleigh, NC
The wings on my lance do not contain any wood. They appear to be foam board sandwiched between plastic held together with an aluminum edging. Thie is the same construction as all of the hatches and the door. The compartment underneath containing the batteries and dump controls and shore power and the generator compartment on the other side is all plastic and aluminum. Maybe they have learned from their mistakes.
2006 F-350 S/C 6.0 DRW 4x4 3.73, 2005 Lance Max 981, most options. Camped 49 states and all Canadian Provences(cept Labrador). 100,000 miles and 500 plus nights of TCing.
http://truckntravels.blogspot.com/
hotvet67
michigan
Looks like the same rot I had on my 2004 845 , not sealed at rear of the inside mld. by the factory both sides. If I had to charge for a repair like this it would be $1000.00 + parts per side , no dealer will take the time to do it right .
![[image]](http://i24.photobucket.com/albums/c30/vetgirl67/LANCE%20PHOTOS/LH1.jpg)
![[image]](http://i24.photobucket.com/albums/c30/vetgirl67/LANCE%20PHOTOS/LH3.jpg)
2004 Lance 845
2006 F350 PSD 4X4 SWB 20" Fact. Wheels
1967 corvette drag car
kcabpilot
CA
Had the same issue on the right side of our '94 990. The cause was a very small breach in the sealant at the very far, lower right corner just above the bumper. That and some inattention is all that is required. When you discover such a thing the first reaction is to tear it open and fix it so you probably won't be able to tell where it initiated itself since you have taken it all apart and destroyed the forensic evidence. I was able to detect my breach because it was at the rear away from where the damage manifested itself. In the end it wasn't really a big deal. I replaced the OBS with a 1x6 board cut to fit and used some epoxy repair stuff from Home Depot.
The only other problem I've ever had was the 1x2 strip at the bottom of the door. Same thing, water got in at the corner because the weather stripping had migrated upwards and created a small breach. That was a pretty easy fix as well.
1994 Lance 990 on 1997 F350 PSD Dually "Rhino Haunches"
Eric&Lisa
Scappoose, OR
Wasatch Lance wrote: I am curious what you did in the repair phase to prevent a reoccurrence of the rotted skirts. Did you use different materials, caulks or trims?
I used Pro-flex RV sealant quite liberally. I did not replace the strip sealant that was originally used. There is no possibility of a water channel existing underneath the white trim piece. Furthermore, all the wood was sealed with the Clear Penetrating Epoxy Sealer just in case it ever does get wet.
The down side of using so much Pro-Flex is it is a real sticky PITA to work with. It gets all over everything. It can be cleaned up and made to look nice, but it is very labor intensive.
I was able to re-use all the hardware with the exception of the screws & staples. The problem had not progressed to the point where I needed to replace the aluminum siding. I did implement stainless steel screws. In place of the long staples, I used small nails.
Thanks,
-Eric
Eric & Lisa - Oregon
'97 Silverado K2500, New HT383 motor!, Airbags, anti-sway bar
'03 Lance model 1030, generator, solar,
jgorm
san diego
I had some bad rot on one side of my old '91 camper in the same area. It was mostly just the very bottom piece of wood. I pumped in a bunch of polyurethane glue into all the screw holes and between the fiberglass and the bottom metal strip. I pushed in the screws that had no bite after coating all of them with the glue too. Its plenty strong now, but is nonstructural so who cares anyway. I sealed the snot out of it as well on both sides.
'97 C3500 4 door dually with big heavy camper The Camper My Ford EFI Tuning Website
97Ford97Lance
Puyallup, WA
I have a 97 11'3" Squire, I think its the 9500. I too have rot in the same areas. Thanks for the information.
narcodog
Georgia
I have a 2006 8scs and I found rot on the bottom of both wings. I am waiting for a call from the dealer as it was still under warranty.
Spott
SE Michigan
Great post, thank for the update and taking the time to spell everything out.
Me - Kim - Spot
Eric&Lisa
Scappoose, OR
Link to F350mule's Lance dry rot problems.
gsbuick65
Southaven Ms.
found this old topic, just noticed I have the same problem, I also just found a soft spot above the front window about the size of a serving plate. how do you go about fixing this problem? is this a insurance claim deal?
mike
1988 Pace Arrow 28' sold
2002 Lance 1130 sold
2008 v-lite 30lrs sol
2014 Sunset trail reserve 30re
2005 Dodge 2500 quad cab 4x4 CTD
Southaven Ms.
