RV.Net Open Roads Forum: Toy Haulers: WW Repairs
Search only in Toy Haulers
 > WW Repairs
Page of 59
Wizbangdoodle
Washington
Posted: 03/30/16 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
lngwca2600 wrote:
Wizbangdoodle wrote:
Has anyone had to repair their tailgate? I have a soft spot on mine and will have to tear into it some time this year and I just want to know what to expect.
Repair shop had to rebuild mine from being rear ended. Nothing crazy. I did reinforce with angle to strengthin it. I'll see if I can find some pictures.
Outstanding. Would love to see some disassembled pics.
'17 F450 CCLB Platinum dually
portscanner
Georgia
Posted: 03/31/16 06:03am Link  |  Quote  |  Print  |  Notify Moderator
What to expect? Be prepared to rebuild the entire thing. I had a "soft spot" and ended up rebuilding the the entire thing as the water had rotted out half of it.
See my post Rotten Ramp Ruins Relaxing Recreation
One beautiful wife
Mattie and Trooper the furcampers
2019 Dodge 4500 with 2008 Lance 1181
2015 Jeep Wrangler toad w/ ReadyBrake/Brute
Web Site
Wizbangdoodle
Washington
Posted: 03/31/16 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the link. Great write-up and repair btw.
My tailgate has that flooring material that you see in the galley of a 737. Kind of a rubber/plastic flooring. Very durable. Was wondering what you ended up doing to the deck of your repair?
I guess I'll plan on a major rebuild. Not the first time I've had to do something like this on this trailer. Had to replace all the wood in the lower wall over the wheels as the spray from the wheels had rotted everything out. From main door to garage man door has been replaced. Not fun.
portscanner
Georgia
Posted: 03/31/16 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
I some paint from the local big box that the person there recommended and added an aggregate to it. (not sure if the one I linked to is exactly the same product - it has been a while!) but it worked very well!
BigDogF250
Ramona, CA
Posted: 10/24/16 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
And a note to WW owners, the wall footer is made of two, 1.25x1.75" strips of wood with the linoleum sandwiched between them. That explains why there are 2 bolts at every outrigger from the frame.
* This post was edited 10/24/16 12:10pm by BigDogF250 *
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200, Axles flipped, Bridgestone Duravis Tires
2005 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR & one Goffin Cockatoo
SuperDave23
Fresno, CA
Posted: 06/13/17 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Reviving the old thread. I've read all 57 pages (over multiple sittings!) and saw everything about reinforcing the frame on the Superlite models. Back in 2008 everyone had access to the Class Action Suit documents which I guess detailed the repairs necessary. I've been searching for these documents without much luck. Did anyone happen to save the frame reinforcement diagrams?
This is for a 2004 FS2300 that has a bent tongue. I measured about 2" of rise from the front of the trailer box to the ball hitch. Yes, it still has the 1/8" 2x4 square tubing. Also looking to do the other frame reinforcement. Fortunately the trailer doeesn't seem to be exhibiting any of the other issues besides the bent tongue.
I'm hoping to line up some local skilled fabricators to perform the repairs, and having the drawings would be a big help!
Thank you!
-Dave
NorthernCharlie
California
Posted: 06/13/17 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't hear from anyone else regarding the diagrams I would call Warrior Lifestyles in Corona, CA. They are the ones that have been doing the majority of these repairs and should have copies.
Good Luck!
lincster
Mesa Az
Posted: 06/13/17 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Contact Jim at SoCalRV repair.
http://socalrvdoctor.com/
He is the main man in your neck of the woods to fix Warrior issues.
2019 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
SuperDave23
Fresno, CA
Posted: 06/14/17 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Talked to SoCalRV. They estimated around $1500 for the tongue repairs and around $2500-3000 for the other frame upgrades, depending on the year (I guess the frames did change throughout the years). Not firm numbers as they would have to assess the trailer in person.
They are a 6hr drive from here.
At this point got to wonder about the benefit of investing $5k into the trailer. According to NADA it's only worth around $7-8k, but Toy Haulers in this vintage typically go for around $10k on Craigslist.
Steve92004
Borrego Springs Ca
Posted: 06/14/17 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
I found some photos on the Glamis forums from a place that reinforces WW frames
Mine had the newer 3/16" tongue but I decided not to take any chances
I did the reinforcements myself
It was a 2x2" 3/16" thick square tube welded along the bottom of the A Frame to stop it from bending
Also ran/welded the same 2x2" square tube underneath the trailer from each leaf spring hanger to the corresponding hanger on the other side. That stops the frame from twisting and getting the "dropping walls" syndrome
It was super easy to do and cost about 60 bucks in metal
Page of 59
 > WW Repairs
