RV.Net Open Roads Forum: Tow Vehicles: mileage
Search only in Tow Vehicles
 > mileage
Fabguy
Auburn, Washigton
Posted: 04/19/02 09:32pm Link  |  Print  |  Notify Moderator
I'm lucky to get 10 MPG with just the TRUCK!!!!
Jeff
2002 GMC Sierra 2500HD 8.1/Allison/4:10/Prodigy brake controler/Pullrite Superglide
Pulling a 2015 Keystone Cougar 280RLS
tigerhwk
where I land
Posted: 04/20/02 04:47am Link  |  Print  |  Notify Moderator
Hey jimmy034,
I've got the same truck as you,checked out K&N filters,Which type did you install?
Thanks,Rick
Rick and Wendy
Border Collie--Maddie
Sheltie--Mick
Collie--Chloey
2011 F150 FX4 - Heavy Tow, 5.0,
2010 Crossroads Zinger 26 RL
Dayle1
Spicewood, Tx
Posted: 04/20/02 06:45am Link  |  Print  |  Notify Moderator
I get slightly over 10mpg, see my sig. for the rig details. That is 60-65 mph in OD running slightly under 2000 rpm. Length and weight are not the deciding factors for gas mileage on reasonably level roads, but speed and aerodynamics are. My current mid-profile 8ft wide 5th wheel is more aerodynamic than my previous low-profile 7.5ft wide unit.
BTW, with an aux. tank, I have greater than 600 miles range towing and 1100 miles solo. Pics at www.picturetrail.com/dayle1/
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
PY
S.West Louisiana
Posted: 04/20/02 07:13am Link  |  Print  |  Notify Moderator
Larry I have the same truck but a GMC. Did you add a fuel tank? Or did your truck come with 2. Sure would like to be able to get more than only 150-180 miles on a tank of gas.
I enjoyed your pics.
BTW how much does that 5er of yours weigh?
There are people who come into our lives for a season. Although the friendships, associations, bonds and commitments fade in time, the influences gained by these moments never expire. They continually help us grow into the men and women we should be.
PY
S.West Louisiana
Posted: 04/20/02 07:15am Link  |  Print  |  Notify Moderator
Dayle1
Spicewood, Tx
Posted: 04/21/02 06:25am Link  |  Print  |  Notify Moderator
PY
The 5'ver is 5000lbs dry, 6500 GVWR. The pics show the extra tank that I added in the bed. If someone wants more range, I would take a serious look at www.tourbuddy.com They make 11 gal tanks that fit over the wheel wells w/o taking up bed space. You can add 1 to 4 tanks at about $250 each. So, 2 tanks would almost double your range.
LAdams
Northern Illinois
Posted: 04/21/02 09:29am Link  |  Print  |  Notify Moderator
Well, on a really good day without too much headwind and running a bit under 60 MPH on flat land, I can usually coax about 9.5 MPG from my 250SD w/V10 and #6400 27' TT... But most of the time it's usually 8.0-8.5 MPG...
But that's still a lot better than my previous MH that used to get 6 MPG (big grin)!!!!
Best Regards,
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
Elliott
Guymon,OK USA
Posted: 04/21/02 05:26pm Link  |  Print  |  Notify Moderator
What is a stump grinder, or did I fall for some joke? (I know what a true stump grinder is, and you don't pull anything with it). Elliott
adVentureMan
Memphis, TN, USA
Posted: 04/22/02 08:15am Link  |  Print  |  Notify Moderator
Elliot, I get right under 10 mpg. The last time I checked I recall it was about 9.95. That was on a "loop" trip that was pretty level, and I keep the speed down under 63 mph or so. When I go faster the mpg drops like a dead duck.
Doug and Kathy
2008 Chevy 2500HD extended cab Duramax/Allison 4WD
2013 Cougar 327RES
"Nuestra casa con buena vistas"
Need RV Checklists?
RAMblin Al
Midland, Texas
Posted: 04/22/02 09:19pm Link  |  Print  |  Notify Moderator
Have pulled a 27' Wilderness TT (bunk model) GVWR=6400# with a 1997 Dodge B250 Wagon 360 cu in engine with 3.90 rear end all over the countryside. Never made less than 10 mpg unless bucking a headwind. Mostly 10.5-12mpg towing and 14-15mpg solo. Best of luck and many happy and safe trails to you.
'01 2500 Dodge QC,LB,Cummins HO/6spd w/4.10 LSD, E-Brake, A.R.E. canopy,Prodigy brake controller.
'00 HR Alumascape 29 FKS TT
 > mileage
