RV.Net Open Roads Forum: Truck Campers: Home made SkyLight (Lots-O-Photos)
 > Home made SkyLight (Lots-O-Photos)
Spott
SE Michigan
Posted: 02/22/08 08:35pm Link  |  Print  |  Notify Moderator
If you read my other thread How I removed my Air Conditioner (with photos) you know that I have a hole in the roof that needs to be filled, and this is what we decided on.
Since a truck camper is so small to begin with and it has four operable windows, three operable vents (two with fans) and a full size door with screen, I didn’t feel the need to have another vent. So I choose to make a fixed Skylight (albeit small).
I got an inside bezel and mounted it so I could determine how much to cut off, using a chalk line and holding it tight to the mounting surface I marked it.
I found something the correct size to use as a cutting guide, in this case a piece of 2.5” angle. I cut one side at a time keeping the saw tight to the edge of the metal. I actually cut about ¼” short of the caulk line so the bezel does not rub the skylight.
Here it is installed
I picked up some ¼” Polycarbonate (same thing as Lexan) and cut it on the table saw to fit the opening, than eased over all the edges.
Using blue painters tape I marked all the hole locations
Drilled the small holes first, through the Lexan, fiberglass and into the plywood. Than I enlarged the holes in the Lexan a bit larger than the screws to allow for expansion and contraction.
To allow for squeeze out I added cardboard to the camper and tape to the Lexan, after the installation I will remove both for a clean line of sealer.
Since I needed to move the Lexan many times after drilling the holes I added the Blue arrow, it tells me which side is up & forward.
Sealed and screwed
Masking removed
Screw heads sealed and bezel installed
Our new low profile skylight.
Now I just need to do something with the rear vent and maybe then I can drive the truck & camper into the barn.
I have a pull shade that I may install for the times we don’t want all the light, until than I've got a vent pillow that inserts for insulation in the winter.
Me - Kim - Spot
mission mike
fraser valley b.c canada
Posted: 02/22/08 09:13pm Link  |  Print  |  Notify Moderator
Sweet
othertonka
Stockton, CA
Posted: 02/22/08 11:40pm Link  |  Print  |  Notify Moderator
Excellent job. Excellent workmanship. Excellent post and Pictures.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 02/22/08 11:46pm Link  |  Print  |  Notify Moderator
Very nice job and informative post.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
DSeckt
Cedar Point , Northern Ohio
Posted: 02/23/08 01:21am Link  |  Print  |  Notify Moderator
I think if I was doing this I'd have the lexan dish in a little to create a bird bath. Would be fun to sit at the dinette and watch them walk around in it.. Maybe even have a little fountain..
06 Ford F350 Dually/ Crew/ PS / SB
Lance 820.......
cdl2
ohio
Posted: 02/23/08 07:33am Link  |  Print  |  Notify Moderator
Good job. A couple of things: You're going to need that pillow in the summer too. How much height does the vent cover add to the fantastic fan? Does the fan have a rain sensor?
spkncarl
That Way
Posted: 02/23/08 09:15am Link  |  Print  |  Notify Moderator
Great follow-up on the removal of the A/C. I was really curious what you were going to do with the hole...[emoticon]
Nice job!!![emoticon]
Conch Cruiser
Southport, North Carolina
Posted: 02/23/08 09:35am Link  |  Print  |  Notify Moderator
Spott,
Nice Camper, It is on my wish list.
One thing I noticed from your photos that is news to me since I am researching your brand of camper for a later purchase.
It appears that your camper has a separate piece of fiberglass around that opening with some ribbing to give it strength for an a/c. I was under the impression that your brand camper was a two piece clam shell construction, and that was a superior method of construction to avoid leaks.
However, it appears that there is another section that is set on the roof, screwed together, and then sealed.
Am I correct? or is that just an illusion?
Thanks,
Conch Cruiser
1999 Chevy 3500 SRW 4x4 Crew Cab Long Bed
1996 Coachmen Ranger 100SD
Tork Lift Front Tie Downs
Happijac Rear Tie Downs
Ride Rite Air Bags
Polar Cub AC Model 9201a-776 8,300BTU
Honda EU2000i generator
BirdSongPlace
San Diego County, CA
Posted: 02/23/08 09:48am Link  |  Print  |  Notify Moderator
That is the cleanest roof I have ever seen!
2000 Ford F350
2004 Adventurer
Hey there
Pendergrass, GA
Posted: 02/23/08 11:33am Link  |  Print  |  Notify Moderator
Hey Spott,
Hi,
How come you didn't just install a big vent? I'm guessing that vent non-transparency played a part. I really like the job you did.
Kurt
2001 Silverado 3500 DRW CC LB 6.0
1993 Lance Squire Lite 150 (8'6")
2001 Fleetwood Caribou 11J (11'6")
