RV.Net Open Roads Forum: Home made torklift-type rear camper anchors - pics
 > Home made torklift-type rear camper anchors - pics
SoCalDesertRider
Arizona desert
Posted: 06/15/08 05:10pm Link  |  Print  |  Notify Moderator
I made these a long time ago when I had my camper. I finaly got around to taking some digital pics with the cell phone, now that I have an easy way to take pics and put them on the computer.
The anchors, if I remember all the dimensions correctly after such a long time, are 1/4" tabs welded to short sections of 1.5" x 1/4" wall square tube, maybe 6" long. These end pieces are removeable from the truck and insert into and cross-bolt to a 2x2x1/4" 'hitch' tube that I welded accross the inside of the bumper.
The 2x2 tube welds to the bumper center frame section, which is mostly 3/16" plate, if I remember right, and also is welded to the 1/4" side plates that mount the bumper to the frame. I welded in extra gusseting between the tube, the bumper and the side plates with 1/4 or 3/16" plate, forget which. I also welded the ends of the tube to the inside ends of the bumper, which is why in the pics the chrome is flaked off the bumper next to the end of the tube and painted black.
Underneath the tube, I welded mounting plates for the mud flaps. This tube going accross the back of the truck accomplished strengthening up the bumper as well as providing a rear frame-mounted anchor point for the camper turnbuckles and chains. It is a very sturdy assembly. Cost was.. not much, maybe $40 in steel, at prices from a few years ago.
Here are the pics --
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
JimBollman
Lost State of Franklin
Posted: 06/15/08 07:32pm Link  |  Print  |  Notify Moderator
Very nice job.
I lucked out on my hitch and it had a straight though square tube as part of the construction. I got a tube the right size and slid it all the way through sticking out a little on each side. I put a bolt through the tube to keep it from sliding in to far and then a removable pin on the other side to keep it from sliding out. Works good for the back and I have TorkLifts on the front.
Jim...
SoCalDesertRider
Arizona desert
Posted: 06/15/08 08:35pm Link  |  Print  |  Notify Moderator
Thank you. Your system sounds like it should work good. Yeah, I don't know why more hitches aren't made with the main tube piercing the side plates and open on the ends, that would be a very convenient place to attatch all sorts of cool home-brew devices to. [emoticon]
Slick Lizard
High Desert Colorado
Posted: 06/15/08 10:11pm Link  |  Print  |  Notify Moderator
And I half expected to see bailing wire sticking out of the end of plastic tow truck [emoticon]
but seriously nice work, I may just have to look into doing the same.
2002 Dodge 2500 CTD
Skamper 100S PU TC
195W of Solar
Desert Dweller On The Road
SoCalDesertRider
Arizona desert
Posted: 06/15/08 11:16pm Link  |  Print  |  Notify Moderator
ROFLMAO!! [emoticon] ^^
Thanks!
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 06/15/08 11:42pm Link  |  Print  |  Notify Moderator
LOL
I too wasn't sure what to expect with this thread.
Nice job on the tie-downs.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
silversand
Montreal
Posted: 06/16/08 06:53am Link  |  Print  |  Notify Moderator
Very nice design. Elegant, looks very functional. Let us know how they perform!
[emoticon]
Cheers,
Silver-
Silver
SoCalDesertRider
Arizona desert
Posted: 06/16/08 08:09am Link  |  Print  |  Notify Moderator
Thanks.
The tiedown apparatus works great. I used it with my last camper for 3 or 4 years I guess, never a problem. Don't have the camper anymore but will get another some time in the future I imagine (if gas prices ever go back down to sane levels). I do miss camping in it.
Camp, Forrest, Camp!
Boise, ID
Posted: 06/17/08 08:48am Link  |  Print  |  Notify Moderator
I want your cell phone.
-2000 Chevy K3500 CC DRW 7.4L, Auto; 2000 Arctic Fox 1150 WB; 1999 Bayliner Capri 1800LS Outboard
-Air Lift bags, Torklift tie-downs, Superhitch w/48", Rancho RS9000X, K&N FIPK, MagnaFlow exhaust.
SoCalDesertRider
Arizona desert
Posted: 06/17/08 11:07pm Link  |  Print  |  Notify Moderator
PM sent.
