I have a 2002 Winnebago that had an analog TV, I am getting a new TV. Do I need any accessory to make this work with factory antenna? In the past I used a digital converter. I know that will not be necessary. I just have a concern about antenna
BettyBoop7 wrote: I have a 2002 Winnebago that had an analog TV, I am getting a new TV. Do I need any accessory to make this work with factory antenna? In the past I used a digital converter. I know that will not be necessary. I just have a concern about antenna
If you have the typical batwing antenna, you should be fine. You might consider adding the Winegard Wingman. It increased the range of my batwing antenna. Happy viewing.
DW and Me
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
If the old TV worked fine with your present antenna, just get rid of the converter box and hook the antenna direct to the TV. Do a channel scan on your new TV and you will be good to go.
Tom 2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
