RV.Net Open Roads Forum: Truck Campers: Hitch survey for TC folks
 > Hitch survey for TC folks
Page of 6
woodrow
PNW
Posted: 12/25/08 09:57pm Link  |  Print  |  Notify Moderator
Wondering what the aftermarket hitch of choice is for the TC folks with extensions. Superhitch...Putnam, etc
SoCalDesertRider
Arizona desert
Posted: 12/25/08 10:00pm Link  |  Print  |  Notify Moderator
I put a Curt Magnum reciever hitch on my truck. 12,000/1,200 weight carrying rating, 14,000/1,400 weight distributing rating.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
Sportsman Matt
Blackstone, MA
Posted: 12/25/08 11:52pm Link  |  Print  |  Notify Moderator
Front or rear? I opted for a Hidden Hitch by Drawtite, 2" 500/5000NWD-600/6000WD on the rear my truck, mainly because it works with my Torklifts, plus it cost a fraction of a SuperHitch or Towbeast. Front is only rated 500 lbs weight /9000 lbs pulling.
Life is short, Play harder.
2002 GMC Sierra 1500 Regular Cab Long Bed 4.3L V6 Automatic 2WD
2010 KZ Sportsman Classic 19BH Travel Trailer
Fishing and Hunting New England and eventually the world
hunkydory
Wyoming, USA
Posted: 12/25/08 11:54pm Link  |  Print  |  Notify Moderator
What you don't want to do is buy your rear torklift tie downs or whatever type you choose then find out your present hitch isn't adequate for you trailer like I did. Our hitch which came with truck was good for a 1000 lbs tongue weight and thought would be fine with 24" extension behind our Eagle Cap 950 camper. Found the 18" extensions with present hitch are good for no more than 300 to 400 lbs and I need at least 500 for my boat or for a Wells Cargo Fun wagon Trailer, so now am looking at having to replace the rear tie downs and install a super hitch good for 750 tongue weight and 7500 trailer weight and a 24" extension without weight distribution.
From checking so far am planning on going with the Superhitch, but am interested in what others have to say that might change my mind.
BoilerEE
Anchorage, AK
Posted: 12/25/08 11:58pm Link  |  Print  |  Notify Moderator
TL SuperHitch w/36" extension.
BoilerEE
Anchorage, AK
Posted: 12/26/08 12:01am Link  |  Print  |  Notify Moderator
Well, the SuperHitch is great, but why not just buy a weight distribution hitch and keep using the hitch you have? Having just recently started towing with a WD hitch, I'm sold even if I got back to a lighter trailer eventually.
~DJ~
Boise, Idaho
Posted: 12/26/08 05:01am Link  |  Print  |  Notify Moderator
SuperHitch!! 1800/18000 on my dually without extension. I use a 24" extension with present camper for boat or enclosed trailer. I do not want to have a WD as it is a PITA and I also have enough weight on the front axle between the TC and motorcycle. [emoticon]
'16 FORD F250 6.2. Air Bags
'16 Arctic Fox 25R. Xantrex 2000 inverter/charger, four Trojan 6 volts, 450 watts solar.
HarryWM
Wherever we are parked this time.
Posted: 12/26/08 08:49am Link  |  Print  |  Notify Moderator
My F-450 came with unbranded Class V receiver. That receiver has (or had since I lost it somewhere) a sleeve that decreased receiver from 2 1/2 inch to 2 inch. I use a Reese extension cut to 41 inch. It is 2 1/2 in on truck end and 2 inch on other end. Previous truck I upgraded to a Class V Reese Tow Beast and used that extension.
Harry
With wife Carole 13 yrs fulltiming
Retired U.S. Army
2002 Carriage LS 37' 5er; 2006 Lance 1181truck camper
2008 F-450 King Ranch 4x4 fully loaded 5,000 lb air springs
2004 Jeep Grand Cherokee toad
SKP # 54751
Geocacher "DosTortugas"
Harry & Carole's BLOG
btggraphix
Golden, CO
I have a Tow Beast, but it is borderline strong enough for my 10,000# dump trailer when full of dirt (especially without the WD hitch) or my skidsteer in the dump trailer when at the end of an extension. I actually bent a 36" extension I had borrowed, and would like to go to the over/under style of the TL SuperHitch to be sure it won't bend. I can't easily use a WD hitch with thie trailer (even though I own one) because of the way the tongue is setup.
For now I am using a shorter than ideal extension becuase it is solid and very strong but I'd like to have a little more length.
I also have a Hide-A-Hitch gooseneck hitch under the bed.
2006 LanceMax 1191 - loaded and well-used
2005 C4500/Kodiak 4x4, GVWR 17,500
gtkato
Aurora, CO
Posted: 12/26/08 08:55am Link  |  Print  |  Notify Moderator
Super Hitch with 30" extension works great with trailer, or 500lb swing-out cargo carrier. Very stable and easy to attach or detach. I will get a 14-16' boat someday, and the ratings will be fine up to 4500lbs and 750lb tongue weight.
FlyFishn
2017 Cirrus 820 Truck Camper, Torklift, Rear view camera, solar, glow steps, roof rack
2012 GMC "Texas Edition" 2500 HD Duramax, MBRP exhaust, Fuel wheels, Toyo Open Country tires, Sumo springs, Torklift stable loads
Page of 6
