RV.Net Open Roads Forum: Truck Campers: Insulation project
 > Insulation project
Page of 7
AnEv942
CA
Posted: 01/11/09 09:58pm Link  |  Print  |  Notify Moderator
pjay9 wrote:
I have discovered another area that needs some attention, which I think was mentioned in another thread. The area behind the stove where the water line comes in to fill the tank. Just looking thru the gap I can see that it is uninsulated and the wall fitting could use some insulation sort of like the outside shower cabinet. Also the space back there is empty and full of sawdust...why can't they vacuum when building these rigs. It apperas that an ouitside door could be fitted and a nice sized storage compartment could be installed to hold water fitting, filter or what have you. It may even be the size to accomdate on the premade boat bins with a gasketed door and lock. We will have to see! :>) Capt PJ
Well I remounted the cord box. As I had to access from the inside to fix I was able to insulate it from the inside. Kinda nice since I lost 2" of cord storage space-ha. I never thought too much of those cord doors till I got behind it.
When I tried to shove box back woudnt move, removal of panel showed a ground clamp had been installed, it was hitting the drain locking the bottom of the box in its current postion. So its been like that since camper was built. Whoever installed box went to lunch before finishing, whoever installed ground lug didnt notice box wasnt against wall, or the lug was preinstaleld, &box wouldnt go against wall due to lug and they just attached at top. It had never been attached to wall along sides & bottom, but in 8 years theres no sign of the 'sawdust' having ever got wet. so that lil door is amazing.
I also saw the fill door-almost transulacent. Definatly could use somthing. Next weekend when I remove acces to battery box, I can get to it. Im thinking just remove hoses and attached a piece to wall-reinstall hoses?. The battery box Ill wrap-the expandofoam idea-theres just 2 much stuff/wiring pump etc to do (easily).
Your wardrobe/propane box looks simular to mine, I like the soap trick
Thanks for the motivation!
Mark
* This post was last edited 01/13/09 08:51am by AnEv942 *   View edit history
Our camper projects page
pjay9
Tacoma, WA
Posted: 01/11/09 10:32pm Link  |  Print  |  Notify Moderator
When you get started on something you sometimes find the other issues to resolve. Gald you got the wire bin fixed, bet that makes a big differance. While I had the cubby out I pulled a wire for future use...may put one of those 12V 100watt defroster heaters in the dump well, so when running down the road it keeps thing warm or when hooked up to site electricity or gen is running. But will see if my insulation schemes do the trick first.
Good luck with the expando, make sure you make some dams to guide the stuff and not fall back into usable space...it is really gooy and sticks to everything! Practice with something you can throw away.
Gald I was able to inspire and help with ideas. Brian and Sleepy are you there? Capt PJ
2005 Lance 1161, 2004 Dodge CTD 3500 Dually 19.5's Stabiloads Roadmaster Sway, 2009 20' Raider 185 Pro Fish 90hp & 9.9 Yamaha vintage Penn elec.downriggers EZLoad roller trailer
3+tons ain't pc
northern, ca.
Posted: 01/11/09 11:23pm Link  |  Print  |  Notify Moderator
Wow, what a great idea and a great result! But now I got another project on my plate...
2007 Dodge 3500 DRW,4x4,L/bed,Q/cab,6.7 diesel w/exhst brake,6 spd. auto,4:10,Timbrens, 2005 Citation 9-6 T/C, 1 keeper wife,1 son, 1 yellow lab, 2 quad polaris atv's & trailer,extreme lust for freedom & self accountibility, neither low output or income.
pjay9
Tacoma, WA
Posted: 01/11/09 11:38pm Link  |  Print  |  Notify Moderator
3+ What's on your plate? Capt PJ
* This post was edited 01/12/09 08:49am by pjay9 *
thundercloud
Durango, CO
Posted: 01/12/09 10:14am Link  |  Print  |  Notify Moderator
Great project PJ,
Where are you getting the polyethylene foam board from?
Happy TC'N,
David
____________________________________________
2006 Dodge Ram 3500 MegaCab 4x4 CTD 6-speed
2008 Bigfoot 25C9.4SB, Xantrex XADC 60, AM Solar 200 watt SunRunner system, Mach8 Cub, Honda eu2200i, Rigid Industries LED lights
pjay9
Tacoma, WA
Posted: 01/12/09 02:13pm Link  |  Print  |  Notify Moderator
Tcloud, I get it from a local foam supply wholesale house, I have a business license, they cut it to the thickness I need and you have to buy a whole sheet 54x109. You can get different density also. Comes in 3, I think, blue white and pink just like the insulation board at HDepot, but this stuff is flexible and resiliant. If you go on line I see companies out there that will ship it to you. Got to go working on the water filler behind the stove, pics to follow. Capt PJ
btggraphix
Golden, CO
Posted: 01/12/09 02:29pm Link  |  Print  |  Notify Moderator
pjay9 wrote:
....Brian and Sleepy are you there? Capt PJ
Yep, taking notes! Did you get the bottom of the closest back in well? I have to be careful about destrying pieces during removal as I am often slow about getting things back in to place nicely.
In any case, good work here.
pjay9
Tacoma, WA
Posted: 01/12/09 07:24pm Link  |  Print  |  Notify Moderator
The insulation project contiues...this was fairly simple...6 screws and the stove pulled out enough to allow access with the gas line still attached. I vacuumed the area first as it was full of sawdust ans metal chips.
Took some photos of the filler port. Note that the air duct was touching the hose and right next to the hole in the wall.
Four inch uninsulated hole.
I cut some more foam and slid it around the tubes and screwed it to the wall, filled the gap with a small wedge of foam (after I took this photo I tucked it down a bit further to seal off the opening)
In the following photo please take note of a few things...Breather tube has some pipe wrap on it as it is the tube with an open end (convection) therefore it will be colder than the fill tube which is capped preventing air from entering. On the bottom there is the hot and cold feed to the bathroom. 1/2" foam is placed under the pipes to keep them from touching the outside wing (conduction) and the hot pipe is separated from the cold water source pipe with a piece of pipe wrap (conduction again).
I measured the area and found that there is sufficent room to install a 11x15 door access from the outside and a 7" deep box behind the stove. It would be a handy cubby and a good use of dead space, the box probably will only be 6" deep inside as there will be 1" of insulation around it. Thinking of using a marine type hatch, flush fit. Have fun folks! Capt PJ
3+tons ain't pc
northern, ca.
Posted: 01/12/09 10:17pm Link  |  Print  |  Notify Moderator
Whats on my plate you ask?? Well now I gotta take on this great idea that you have planted in my head! Like I really need another project to deal with...but I just can't allow my fellow TC contemperaries to get a leg up on me...AIN'T GONN'A HAPPEN!!
thanks for the inspiration.
3 tons
thundercloud
Durango, CO
Posted: 01/13/09 10:17am Link  |  Print  |  Notify Moderator
3 tons
Ya but these are fun frustrating projects that should have been done at the factory [emoticon] , but then again the bean counters would not like this type of attention to detail [emoticon]
Page of 7
