Jeff4au
Eufaula Alabama USA
I have an aluminum cover for my 5th wheel and the driveway under it is gravel I want to concrete it. Is 4" thick enough or does it need to be thicker?
2001 F250 V10 4x4 CC Lariat 3.73
2003 Keystone Challenger 32TKB 5er
Honda EU3000, Prodigy, RDS tool/tank combo
Crazy Ray
Monroe,La
I made mine 6 , footing 12
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
Ranger Smith
Wherever the rig is parked
When I built my RV park I used 2x6 for concrete forms with rebar. That should suffice. I think a 4" pad may be a bit shy. But I am not a concrete expert
Where we are now
Amateur Radio Operator N1JS . . . SunSDR2 Dx, Ameritron AL-80 Amp, Icom 7100
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
larry barnhart
wenatchee. wa usa
I made ours 5" with steel rebar on 20" centers.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Turbo Diesel Dude
Ocala,Fl
Why don't you do a mono-lithic pour with 6" where the wheels roll and two in the middle. Re-inforce the wheel tracks with some rebar and you should be home free. Takes as much as just 4" thru out. JMHO
charles weidman
Spyglass
Santa Fe, NM
First, evenly spread the gravel then thoroughly compact it with a jumping jack or rolling vibratory compactor. Then pour a 4" slab with 6X6 wire reinforcing mat. When pouring, use a concrete scoring tool to cut expansion joints at about 4'-8' on center in both directions. The secret is a good subgrade. My 11,000# Apenlite has not caused a single crack.
Obs (architect and contractor)
2002 F250, 7.3 CC
2000 Alpenlite Spyglass
pigman1
Delaware
We poured a 4" floor wire reinforced for temperature (the wire doesn't add strength, only keeps it from cracking due to temp changes) and made it 8" under the wheel and jack parking positions. I previously had 16x16x8" thick poured concrete pads where the jacks landed on a dirt floor and did not have an issue. The solid floor sure makes it easy to do maintenance. We're at 35,000 pounds.
John
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
Flyin Finn
Battle Ground, WA, USA
6" is the common thickness. But you can do 4", as long as the sub grade is properly prepared (gravel or sand, well compacted, etc...), using re-bar, and also consider using stronger grade of concrete.
It is also important that the concrete is applied correctly (not adding too much water to the mix).
If you have a very heavy 5th wheel, I would recommend 6" thickness.
Finn
97 Silverado 2500HD Ext Cab 2WD 7.4L towing a 08 Rockwood 8281SS Fifth wheel
cummins2014
Utah
I am surprised to see people pouring that thick of concrete for a rv pad, mine is poured 4", 6 bag. My pad is 10 x 50 . Expansion joints 5 feet down the middle and 5 feet centers. No rebar, wire mesh, or other type of reinforcement . If you are compacted well under the pad you are good to go with 4" . My pad is nine years old gone thru 8 winters ( Utah ) no cracks or settling with a nearly 13k fifth wheel setting on it. Anything more than 4" is a waste of money and concrete.
ryoung
Oregon
For the fifth wheel you presently have, 4" thick is sufficient. But if you ever consider upgraging to a motorhome, you will most likely will crack it at that thickness. Always plan for the future. Another 2 inches will add 50% to the concrete cost, but should not add anything to the finishing costs depending on the grade.
ryoung
