RV.Net Open Roads Forum: Dinghy Towing: Could I make my own base plate
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  All
 > Could I make my own base plate
DBakker
Saskatoon
Posted: 02/16/09 07:07pm Link  |  Print  |  Notify Moderator
Hi all,
I'm wanting to make my own base plate for a older truck
that I have. Is there anyone that has made one or can give me advice
on this. I only want to tow this truck for one year or so. So I don't
want to got though the cost of purchasing a base plate to just not use it in a few years.
Any input would be nice.
Thanks,
2000 Newmar Dutch Star 330hp
toad 2013 Toyota Tacoma
blueflash
East Tawas, Michigan
Posted: 02/16/09 09:08pm Link  |  Print  |  Notify Moderator
I made on for a ford ranger out of 3/16 angle iron. Hard part was finding places to attach to truck. Worked out real well and was probably greatly over built.
Blueflash
Gadget Guy
Calgary
Posted: 02/16/09 09:17pm Link  |  Print  |  Notify Moderator
My first question would be Do you have any experience, welding or mechanical?? If not, you should get perfessional help to build one. I travel in Saskatchewan and I certainely don't want to meet you on the highway towing a truck with a base plate built by you if you have no back ground in any mechanical trade. It is an easy job if you know what you are doing.
Bob N Deb
B.C.
Posted: 02/16/09 09:21pm Link  |  Print  |  Notify Moderator
I designed one for my Toyota PU and had a welding shop build it
it boltes onto the frame
sawdust_128
NC
Posted: 02/17/09 12:44am Link  |  Print  |  Notify Moderator
You migght try posting wanted ads on the classifieds here on rv.net, at hitchtrader.com and at the escapees web site. If you can get a used one that's close to right, you may well save $ and time and get a solid base plate asssembly sufficient to justify the $.
On the backside, you can post it for sale on those same sites.
Sawdust_128
rvtommy
blooming prairie minnesota
Posted: 02/17/09 08:21am Link  |  Print  |  Notify Moderator
We bought the wrong base plate and had it fitted to work???? It broke 2 times GET MY POINT !!!!!!!!!! It is not worth what could have happened and were were pulling small truck and the STEEL plate broke in half not the WELD please do not do it!!!!! rvtommy
this is rvtommy
rockhillmanor
On the Road
Posted: 02/17/09 04:20am Link  |  Print  |  Notify Moderator
The base plate itself is not that expensive. The labor an RV shop charges to install it is! Trust me I know!
IMHO buy the correct base plate for your tow vehicle and search the forum for the posts that relate to members installing it themselves.
This link will let you search for your tow vehicle and you can buy the correct 'base plate' made just for that vehicle. Also keep in mind that you have to consider how your homemade base plate will hook up with the available tow bars. These base plates include the tabs.
blueox.com
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
bacollins
Lawrenceburg, IN
Posted: 02/17/09 04:24am Link  |  Print  |  Notify Moderator
I made base plates for both of our toads. For the Wrangler, I made it from scratch using 2" square tubing and plates cut from 1/4" sheet. For the Cherokee, I bought a front mount receiver hitch and welded on tabs for the towbar.
2001 Tahoe
2013 Jayco 34XB
djevans
Tennessee
Posted: 02/17/09 06:11am Link  |  Print  |  Notify Moderator
Many have made them over the years - so "yes," a person of sufficient skill can perhaps, even easily make something that will work - HOWEVER, since you asked, no offense, but just having you ask this question, 'kinda indicates to me that you might not have enough skill or an adequate plan/design - It's too easy to have a "homebrew" design come apart - I installed our Saturn Vue's baseplate - it was bolted thru the frame and to the frame, it was just a VERY safe feeling design - at the very least maybe you could take a picture and measure a factory built unit
Hold down costs? - well one time I purchased one from EBay that was for another vehicle and modified it to fit the one I needed it on - that might be one option available to you, it sure made my job easier on that vehicle - I had all sorts of access to welders, grinders, massive metal presses, and torches at that time though
I know you wrote you are going to use it infrequently but you asked for advice and my advice, take it or leave it, is to simply purchase a good factory unit so you can safely tow the vehicle without the undue liability and worry - "it" can be done though...
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - HONDA Element
350hp Cummins ISC
2006 GL1800 HONDA GoldWing
- - - P i c t u r e s - - -
"HOPE" is not a strategy . . .
Ajones42
South Texas Puckerbrush
Posted: 02/17/09 07:40am Link  |  Print  |  Notify Moderator
I was forced to do this because nothing was available for my application. I would *not* do it if one was commercially available. The Aventa II and Brakebuddy for this application both came off of Craigslist at a huge savings.[image]
My Old RV
Fulltiming in a 2010 Puma 30RKSS
1993 Dolphin 32D -> Destroyed by hail April 2013
Gate Guards in the South Texas Pucker Brush
My Old RV
Oil Field Gate Guard Forum
