RV.Net Open Roads Forum: Honda 2000i Carb Job With Photos Must Read!!!!!
 > Honda 2000i Carb Job With Photos Must Read!!!!!
Page of 23
scootsk
Long Island, NY
Posted: 01/12/16 03:29am Link  |  Quote  |  Print  |  Notify Moderator
Mobile sport wrote:
Unbelievable ,, I took my carb apart and it looked clean as could be , didn't think cleaning it was going to work but I went ahead and bought some carb cleaner , I sprayed it through all the holes and soaked the jet for a couple hours , made sure everything was dry and put back together.
Fired it up and I couldn't believe it kept running !!!!!!
Thanks AISurffish
Forgot to mention , man that was easy , I don't use the red Honda case so basically unbolted the air filter , slide off the carb ,
Disassemble carb , spray , assemble.
Just curious, why don't you use the red Honda case? Your entire case is removed? Is there an advantage to that? How is the noise level?
Don, Kathleen and our little men Henry, Will and Bailey the Wonder Wheaten
2014 Ram 3500 Crew Cab 4x4 Dually 6.7 CTD/AISIN
Formally: 02' Chevy Silverado 3500 Crew Cab 4x4 Dually 8.1/Allison (The Gasoholic)
2010 Jayco 351 RLSA Fifth Wheel
Mobile sport
desmoines iowa
Posted: 01/12/16 09:53am Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 01/12/16 02:04pm by Mobile sport *
roadtoadflorida
Posted: 01/12/16 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I use a guitar string to clean the emulsion tube with all the little holes. Then carb cleaner and air. But this has been an annual event for me. So I have come to expect it, even after I run it dry, use 100% gas/no ethanol, and drain the bowl. But I love my Honda 2000IE.
Ken and Pat
"Road Toad" Channel 19
Flagstaff 35 FT TT
2015 Ford F250 4x4 Crew Cab
Okaloosa County, Florida
scootsk
Long Island, NY
Posted: 01/13/16 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Mobile sport wrote:
What happened to you response? Looks interesting. Any video of the finished product?
Footloose4ever
Narragansett Bay
Posted: 08/01/16 08:41am Link  |  Quote  |  Print  |  Notify Moderator
I have a Honda eu1000i generator that has been faithful for a long time. Upon starting it this year, however, it would surge and stop. The key to fixing it was near the end of your eu2000i service tips. The main jet is beneath the float chamber bolt, just as you describe. The gunk in the bowl was obvious, but that main jet was hard to find in the eu1000i tips. It was clogged solid. Cleaning it as you describe has my faithful generator purrrring again. Thank you.
bigfootford
Fair Oaks, California
Posted: 08/01/16 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Excellent. Many of us have had that condition... Amazing the junk that collects in the bowl.
Some of us have added inline filters to catch stuff... Amazing the water that will collect in it.
That **** Ethanol will turn to molasses... Just put an oz of E10 gas in a small glass jar, leave the lid off and see what you have after it all evaporates!
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
Hundo24
Calif
Posted: 06/09/17 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
I just posted in another thread. I bought one and ordered another to combine. Two weeks old and shuttering and stopping. I used a new plastic fuel can, new fuel, ran good for a day after cleaning out with Seafoam. Then issue again, maybe it's Californians ethanol ****? I used 91 grade. I don't see this happening with the Yamahas as much. I was thinking of converting to Propane but that's $200 per hint. I've owned many Honda products, from cars, motors and power equipment. Never any issues except the 09 civic wasn't as good. I bought through Amazon, I'll send them back. One I had to rest on my trailer tongue against the diamond plate since I couldn't set on tailgate (has to use truck) and it scratched up the plastic. Other choice was on ground with dry hay, didn't plan on returning it. Had dogs in trailer with ac on. Dry camping arggggg
Reddog1
El Dorado, CA
Posted: 06/10/17 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Hundo24, I really doubt there is anything wrong with the Honda generator. Everything I have read says it is a bad idea to run 91 fuel in most small engines.
What you described the Honda does, shuttering and stopping, sounds like you are not opening the vent on the fuel cap. I suggest you take your Honda to a small engine repair shop and have it checked out.
You say you are in Cailf. If you indicate where in Calif someone with experience or knowledge of a shop might be able to help you.
Wayne
Hundo24
Calif
Posted: 06/10/17 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
I used 87 when this started. A mechanic in another forum recommended 91 because when there's ethanol in the fuel your 87 is less. I pulled the plug, it's running lean. Cap has been adjusted half way, 1/4 as some have suggested, no help. Only runs good with half choke. Another guy had the same problem, the Honda dealer couldn't figure it out? I'll pull cover off to check inline fuel filter. We can't be down a week or two. This is new and the benefit with Amazon I can get two Yamahas within two days. Honda isn't want it use to be across the board imo. I've owned over 12+ Moto's and cars power equipment in the past is why I went back. There's too many issues with the fuel/carbs with Honda. Not as many with Yamaha, not as sensitive with poor fuel as we have in California (placerville)
Thanks all
Don
Reddog1
El Dorado, CA
Posted: 06/10/17 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Help is available, I live in the Placerville area. Check your PMs.
As I understand, all gasoline in Calif by law is required to have a minimum of 10 percent ethanol. Some stations have more.
Wayne
Page of 23
