WesternHorizon
New Mexico
Great thread but it does not appear to be getting the photos back.
I have started a notebook of all my clippings, part numbers, video links, etc. on the EU2000i
http://bit.ly/2R9l1f3
Crabbypatty
Long Island, New York
Not certain what the carb issue is except maybe gummed up from old gas. I learned that the hard way years ago and since then put Star Tron fuel stabilizer in all my jerries. never has a problem since.
John, Lisa & Tara">">">
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
opnspaces
San Diego Ca
Since the post is not very useful without the photos I recreated the original with new photos.
New post here
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
bigfootford
Fair Oaks, California
Well here is one more step you all need to do when you do a teardown and clean the internals and jet/emulsion tube....
I had trouble that was more than just the low speed surging etc. I found this video...
The main jet the fella shows is something I have not even removed in the past. If you do remove the main jet then when you install it you need to make sure it is placed in on the proper direction on the top otherwise the jet will not seat fully and you will have high rpm surging.
Be sure to count the turns for the Idle speed screw which has to be removed to raise up the Main jet. Use care lifting that main jet, it is plastic.
Here is the video:
https://www.youtube.com/watch?v=QdUlhJFHlDU
Another one to clarify what the fella was saying.
https://www.youtube.com/watch?v=dLCXb-hg78s
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
