RV.Net Open Roads Forum: It is that time to check your spare!!!
 > It is that time to check your spare!!!
KKELLER14K
BEAVERTON OREGON
Posted: 04/04/09 03:34am Link  |  Print  |  Notify Moderator
I say it this time each year and that is to check your spare tire. I, we, have heard it all. Is it even there?? Checked mine it was 10 PSI down from last year. Travel season is here and the fact is that if you need it in the middle of no where and it is flat....your screwed!
Jack_Diane_Freedom
Milton Ontario Canada
Posted: 04/04/09 07:21am Link  |  Print  |  Notify Moderator
I check mine before each trip along with all the other tires.
~DJ~
Boise, Idaho
Posted: 04/04/09 07:25am Link  |  Print  |  Notify Moderator
While I'm under there, every Spring, I pull the control knobs off the Ranchos and spray them with WD 40.
'16 FORD F250 6.2. Air Bags
'16 Arctic Fox 25R. Xantrex 2000 inverter/charger, four Trojan 6 volts, 450 watts solar.
jimh425
Western MT
Posted: 04/04/09 08:38am Link  |  Print  |  Notify Moderator
I'm not sure if I'd even try to change mine if I had the camper on the truck. My thought is I'd probably call roadside assistance. I do however carry an air pump.
Jim2007
Greeley, Colorado
Posted: 04/04/09 09:47am Link  |  Print  |  Notify Moderator
HI: I learned the hard way. When I started RVing I headed out without checking my spare (dealer said the trailer was ready to go). We had a flat on I-25 going through Denver. We did pull off and find a shopping mall parking lot. I got the flat tire off and then found out the spare was also flat. Good news there was a gas station (with air) about 200 feet from where we parked the trailer. We aired up the tire and put it on the trailer and headed down the road. Just lucked out on that one. Now I check the air in the spare and all the tires daily when we are traveling Happy Camping Jim2007
TV: 2016 Dodge 2500 Diesel
Rig: 2013 Heartland, Sundance, 5th wheel
SoCalDesertRider
Arizona desert
Posted: 04/04/09 10:00am Link  |  Print  |  Notify Moderator
I just lifted up my shirt. The spare is doing fine. [emoticon]
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
DesertDave100
San Jose CA
Posted: 04/04/09 10:04am Link  |  Print  |  Notify Moderator
I check mine at least every 5000 miles when I do a five-tire rotation.
2014 Four Wheel Grandby. Rides on a 2007 Ford F350 6.0 SRW Torqshift
time2roll
Posted: 04/04/09 10:13am Link  |  Print  |  Notify Moderator
I carry a compressor. Actually two when camping. Is it inherantly better to store a tire at full pressure? Or can I fill when actually needed?
675w Solar pictures back up
SoCalDesertRider
Arizona desert
Posted: 04/04/09 10:28am Link  |  Print  |  Notify Moderator
You can store it flat and fill it later, just make sure that the tire doesn't come off the bead in the meantime and also that your spare tire retention method does not depend on squeezing the tire to keep it in place, as it may want to fall out if it is flat. I would rather have the tire full and ready to use when needed. Sometimes they are needed at times and in places where it is inconvenient enough just to change it out, nevermind finding the air compressor, hooking it up, finding the the tire chuck and pressure gauge... you get the idea... Just travel it with it ready to go and save some hassle later.
Sand Lizard
Long Island New York
Posted: 04/04/09 06:46pm Link  |  Print  |  Notify Moderator
Thanks KKELLER14K, breezed by your post this morning and said "hmmm I should check that" well wouldn't you know it, totally flat! Valve had a slow leak, went to a tire shop no charge for a new valve and a fill and gave the kid $10 for his time. Thanks again.
* This post was edited 04/04/09 06:54pm by Sand Lizard *
