RV.Net Open Roads Forum: Truck Campers: Closet rod mod
 > Closet rod mod
luv2skyski
Stockbridge, Georgia
Posted: 05/15/09 06:47am Link  |  Print  |  Notify Moderator
I've always hated the closet "rods" that were installed in our NL. I don't know how many of you have these:
But they are a pain in the keister! That one in the kitchen pantry isn't that bad because you can see the holes to put the hangers in (Of course you are still limited to two, three at the most, hangers per hole). But the two in the bedroom are horrible. You have to just about put your head in the closet to line up to these holes:
So different rods were needed. The main problem was that I couldn't use a traditional rod hanger mount on the wall at the end of the rods because the walls were too thin. They were only about 3/16" thick plywood. So they had to be hung from the ceiling. I ended up using 1/8" thick aluminum angle for the brackets and 3/4" aluminum tubing for the rods. I drilled a hole and then tapered the edges of the angle. After polishing the tubing I used a small cotter pin to keep the tube from sliding out of the angle bracket:
Back side of the bracket:
Kitchen closet rod installed:
Close up:
Bedroom closet rod installed:
Ya'll like the sweatshirt? You know you do!!!!! Ok...Ok, here's one for you, Bruce:
BTW, thanks again for the windbreaker. Here's one without any clutter:
Now we're able to just hook and push our garments to the back. Much better. Happing camping, Dave.
2004 Northern Lite 10-2000RR, 1999 F250
luv2skyski.com
Northern Lite Owners
Truck Camper Enthusiasts Map
4 out of 3 people have trouble with fractions.
~DJ~
Boise, Idaho
Posted: 05/15/09 07:01am Link  |  Print  |  Notify Moderator
Very Nice!!! You are certainly a very talented person. [emoticon]
BTW, what is that black tube thing?
'16 FORD F250 6.2. Air Bags
'16 Arctic Fox 25R. Xantrex 2000 inverter/charger, four Trojan 6 volts, 450 watts solar.
Spott
SE Michigan
Posted: 05/15/09 07:19am Link  |  Print  |  Notify Moderator
Great looking job Dave,
how did you pick what screws to use?
Did you just use the same size that the factory used?
Thats a really cool MI jacket [emoticon]
In our camper the black Thing is the radio antenna and it's in our TV cabinet.
Me - Kim - Spot
Surfrat
Levittown, Long Island NY
Posted: 05/15/09 10:04am Link  |  Print  |  Notify Moderator
Not to highjack the topic but
Beddows wrote:
When we did tours on several factories 4 summers ago. We complained about those things at every one of them. Some listened, most did not. My SnowRiver came with plain wooden rods and this spring in Mexico over very rough roads & hundreds of Topes (speed bumps), some of which I hit at high speed, we never lost a single hanger.
I have a fix for lost hangers. Just add some plastic tubes to the hook area. plus cut a small notch to lock in the tip.
BobTowne
Fairfield, CA, USA
Posted: 05/15/09 10:51am Link  |  Print  |  Notify Moderator
Wow, nice job, and excellent pictures. That must be the kind of hanger "rod" that's used in most campers because we have the same in both the main closet/wardrobe and the cabover "wardrobes". Thanks for sharing, and happy camping.
GreatWhite
2004 Dodge Ram 3500 Quadcab Dually
2004 Alpenlite Santa Fe 1150
luv2skyski
Posted: 05/15/09 10:56am Link  |  Print  |  Notify Moderator
Yep, Bruce is right, radio antenna.
Spott wrote:
how did you pick what screws to use? Did you just use the same size that the factory used?
I used the same screws that held the old rods in place. I add a couple of extras the same size.
Happy camping, Dave.
97Ford97Lance
Puyallup, WA
Posted: 05/15/09 11:15am Link  |  Print  |  Notify Moderator
Nice work. Our a bracket like that in it. We have plastic hangers and you have to tilt/angle them to get them in the hole. I only think about replacing it like you did or get metal hangers when I'm fight with it.
(Note to self) Replace rod hanger.
Beddows
Abbotsford, Canada
Posted: 05/15/09 08:58am Link  |  Print  |  Notify Moderator
Tizi
Normandy Park, WA
Posted: 05/15/09 07:28am Link  |  Print  |  Notify Moderator
Excellent job. I was thinking about yanking the entire thing out and putting in shelves...still undecided.
2008 Dodge Ram 2500 QC 4x4 - HEMI
2007 Northern Lite 10.2 RR
Tizi's Transformer by Whazoo
Reddog1
El Dorado, CA
Posted: 05/15/09 09:21pm Link  |  Print  |  Notify Moderator
Gee, my old 1988 Bigfoot came with what you installed. Nice job.
Wayne
 > Closet rod mod
