RV.Net Open Roads Forum: Truck Campers: Shower valve
 > Shower valve
pjay9
Tacoma, WA
Posted: 06/10/09 10:20am Link  |  Print  |  Notify Moderator
A while ago a member in CND installed a Moentrol in his TC...I copied it and here is the results. I tell you the fitting of all the bits was very tight and my hand has nicks to prove it. Watch out for the raw fiberglass shards on the sink and inside wall, they'll get you!
The next step will be to switch out the pump for a variable speed to basically eliminate the cycling when running the water very slow. No an accululator tank didn't solve the issue...and I returned it.
This should be standard or optional on TC's! Thx for looking. Capt PJ
2005 Lance 1161, 2004 Dodge CTD 3500 Dually 19.5's Stabiloads Roadmaster Sway, 2009 20' Raider 185 Pro Fish 90hp & 9.9 Yamaha vintage Penn elec.downriggers EZLoad roller trailer
Photomike
Southern Alberta or where the camper is parked!
Posted: 06/10/09 05:25pm Link  |  Print  |  Notify Moderator
I like the corner soap shelf, you have given me another idea.
Thanks,
2017 Ford Transit
EVO Electric bike
Advanced Elements Kayaks
fast.5
Ontario, Canada
Posted: 06/10/09 07:18pm Link  |  Print  |  Notify Moderator
Dam that looks like mine[emoticon]
Nice job..
Mike
2004 FORD F350 Supercrew 4x4 V10 Airlift incab controls 42" titan extension.
2007 LANCE 1131 Loaded, Air,Dicor,all weather packages Awning&Slide awning,2500lp Onan camp power,back up camera,dish
Fast.5 Reno Page http://community.webshots.com/user/fast5
pjay9
Tacoma, WA
Posted: 06/11/09 12:39am Link  |  Print  |  Notify Moderator
Nice job..
Mike
AND so it should be! Thx for being the guiding light. Capt PJ
pjay9
Tacoma, WA
Posted: 06/11/09 12:42am Link  |  Print  |  Notify Moderator
Use some plastic like Starboard from the local plastic place out of the scrap bin..cheaper that way! I used 3/8" and predrill the holes. When doing the hole with a hole saw go slow it melts and makes a mess! Capt PJ
pjay9
Tacoma, WA
Posted: 08/30/09 09:33am Link  |  Print  |  Notify Moderator
UPDATE: The shower and sink plumbing are marvelous and with the install of the Shruflo Smart Sensor pump the use of the freshwater system is so much nicer. Whether taking a shower of washing dishes the flow is excellent and doest not pulse. I had to call Shurflo to ask about fine tuning the pump and now that it is adjusted...Great!
It is funny as I used to listen to the pump go on and off when I had the old style. Now I listen and it goes down really slow and I expect a surge, but it maintains a trickle...If you are thinking of doing bath plumbing and pump mods...DO IT! Capt PJ
mranger1911
Sitka, AK
Posted: 08/30/09 11:46am Link  |  Print  |  Notify Moderator
I'm digging the new renovation. You have given me many ideas.
06 F-350 PSD crew cab w/ 07 AF 990
MTW1
north carolina
Posted: 08/30/09 12:42pm Link  |  Print  |  Notify Moderator
Very Nice JOB !!!
 > Shower valve
