RV.Net Open Roads Forum: Truck Campers: Happijac lubrication
 > Happijac lubrication
Page of 23
goshawk
wyoming
Posted: 03/08/21 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Cannon, you could be right. I bought the camper used with the jacks on it. Previous owner did indeed back into something, damaging the mounting plate on the back corner of the camper -- fixing that corner is one of the jobs on my list.
On the other hand, 3 of the jacks work fine, and the jack in question was on the front right side, which shows no sign of damage. And I can't detect any deflection in the stuck jack. But yes, with tolerances so tight, that could certainly be the problem. And previous owner might have swapped it around.
Glad to hear JimK got 18 years out of his. That would do me.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 03/08/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Most likely you have examined the suspect stuck jack with a good straightedge, but using a four foot level might indicate a tiny bend in the tube.
You could certainly try putting the tube into a clamped holder, and apply a minimal amount of pressure with a hydraulic jack while you attempt to move it. If you do manage to move it then, at least you will know which way the bend might be.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
devildog1971
Rome
Posted: 03/20/21 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have the happy jacks with the motor on top not the side
* This post was edited 03/20/21 09:54pm by devildog1971 *
2019 Northern Lite 10-2 EXCDSE Dry Bath 2007 G M C dually crew cab and 2018 Harley Davidson Limited Low
Page of 23
