RV.Net Open Roads Forum: Truck Campers: Spare Tire
 > Spare Tire
Rawhyde
Posted: 08/04/09 07:52am Link  |  Print  |  Notify Moderator
Here's something I never thought of........
With the Camper on, how do you get your spare tire down if you have a flat?
Obviously this only pertains to those with campers that over hang and those with the spare tire under the truck and the little cable crank gizmo that lowers it.
Thanks!
msiminoff
Silicon Valley, CA
Posted: 08/04/09 08:07am Link  |  Print  |  Notify Moderator
I realized that I couldn't get my spare out with the camper on so I did this:
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
Matthew_B
The boonies near Dallas, Oregon
Posted: 08/04/09 08:15am Link  |  Print  |  Notify Moderator
I have a camper with a low overhang. I have had to retreive the spare with the camper on. It was farther to slide to get to it, but the camper was no lower than the bottom of the truck.
Since I have a DRW, the back of the truck didn't drop with one flat tire.
Geewizard
E. Washington
Posted: 08/04/09 09:17am Link  |  Print  |  Notify Moderator
The only issue I've had with getting the spare tire out from under the truck when the camper is on....is the crank not being long enough. So, I got some handle extensions from the wrecking yard and solved that issue.
And, I put on a front receiver hitch so I can carry another spare tire as well.
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
Mary Kitchen Roast Beef Hash
220W solar, MPPT controller, LED lights
Library Books
Wave 3 Heater
mranger1911
Sitka, AK
Posted: 08/04/09 09:38am Link  |  Print  |  Notify Moderator
Ive always wanted to carry mine in the front receiver but have yet to fabricate the mounting bracket. I actually just carry it in the back seat area. But it takes up soooo much room. Does anyone know where they might sell brackets for the front reciver to carrier my spare or do I have to fabricate one? Sorry Rawhyde not trying to still your thread.
06 F-350 PSD crew cab w/ 07 AF 990
bldrbuck
one or the other
Posted: 08/04/09 09:50am Link  |  Print  |  Notify Moderator
When we had a camper and a single rear wheeled pickup If a back tire went I would unhook the camper and then jack it up so I could jack up the truck and get the spare out. Not a pleasent operation but only happened once in many years. I tend to keep good tires on my vehicles. I don't know why I didn't call for Emergency Road Service. I would now.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 35' King of the Road 5er, 192 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 2 Trogan T105 Batteries, Me, my wife and 2 maltize furkids.
luv2skyski
Stockbridge, Georgia
Posted: 08/04/09 10:44am Link  |  Print  |  Notify Moderator
I did this but a lot of others have rotated their lift mechanism under the truck so they could access the crank tube from the wheel well. Happy camping, Dave.
2004 Northern Lite 10-2000RR, 1999 F250
luv2skyski.com
Northern Lite Owners
Truck Camper Enthusiasts Map
4 out of 3 people have trouble with fractions.
A Wallace
Florence, Al
Posted: 08/08/09 06:35pm Link  |  Print  |  Notify Moderator
I had the same problem. About 4 years ago I had a blow out I mean a good one $1700 damage on my truck but that's another story. I also have a 5er and had made a 1" bed out of treated wood where my TC would not set down on my hitch rails. I never thought about the spare until then. I had to raise the camper up get the spare down and then jack the truck up. When I got home I built another bed out of 2x4's and I could just barely get to the tube so I found a bolt 2 and a half inch's long and nut that fit the tube. I welded the nut on the bolt.I carry a socket, swivel and speed handle at all times. It works great.
Travelers
petekerwien
Camano Island, WA
Posted: 08/09/09 12:21am Link  |  Print  |  Notify Moderator
There was a thread a few years ago. You cut your jack handle down and weld a socket on the end and it will fit in the opening so you can lower the tire. Others have gone in from the wheel well. I cut my jack handle, welded a socket and it works fine.
famousperson
Pittsburgh, PA
Posted: 08/09/09 03:55am Link  |  Print  |  Notify Moderator
All it takes to get to our (cable drop) spare is releasing the tie-downs and raising the camper. It's a little bit of a hassle but not a huge deal.
2006 Dodge Ram 3500 Laramie, QC, CTD, auto, 4X4, LWB, DRW, Jake brake.
2005 Lance 1121
2003 Jeep Wrangler Rubicon (toad)
2007 BMW R1200R (motorcycle)
Sierra Designs ASP 2 tent
Mountain Hardware sleeping bag
Thermorest 1 1/2" sleeping mat.
 > Spare Tire
