Eric212
Western Mass
Hi, I've been looking for a PSW inverter that'll put out around 1000W and came across this one: Sunforce Model # 11240 This seems like a pretty low price for a 1000 Watt PSW inverter, does anyone have one of these? Is it a screamin deal or just a cheap-o inverter? Or a little of both? I don't necessarily have to have the highest quality one out there, but I don't want one that's so cheap that it'll break after a year of minimal use either.
Thanks,
Eric
1999 Coachmen 115RD
1983 Chevrolet K30
Timbren SES, Stable Loads, Hellwig Rear Sway Bar
2oldman
south
If I were you I'd visit amazon and read the reviews. this unit has no mounting feet, annoying fan and not as clean power as you'd expect. Buyer beware..
BFL13
Victoria, BC
No knowledge of product quality. Check the specs though--they do their 110v outlets funny. Most inverters you can get the full watts from each 15amp outlet, but that one has two outlets that are limited to 500w each. Sunforce tech support replied to me confirming that.
They were selling these at Can Tire as "1,000 watt" inverters and I e-mailed Can Tire saying this was misleading, but never got an answer.
So if you want to run a 900 watt kettle with this "1,000 watt" inverter you can't.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Eric212
Western Mass
BFL13 wrote: No knowledge of product quality. Check the specs though--they do their 110v outlets funny. Most inverters you can get the full watts from each 15amp outlet, but that one has two outlets that are limited to 500w each. Sunforce tech support replied to me confirming that.
Interesting, I never thought of that. I will be wiring this up so it powers all of the outlets in the camper... to get the full wattage could I just have power coming from both outlets (2 sets of wires) and connect them together before connecting to the house wiring? I don't have anything that will draw the full 1000W right now but I'd like to have that capability available.
BFL13
Victoria, BC
My understandiong is that each outlet has the 500w limit so you can plug a 500w appliance into each one for 1,000w limit on the whole supply. It has something to do with series or parallel of the outlets--can't remember the details.
I don't think you can blend them downstream as suggested. Isn't that like where guys want to make a 30amp out of two 15amp receptacles? Perhaps there is a way that somebody else can suggest.
If you already have it will they take it back? There's lots of other inverters out there. It seems they are coming down in price a bunch lately too. I wonder if there is something new coming out or if it is just an over-supply in the market.
2oldman
south
Eric212 wrote: to get the full wattage could I just have power coming from both outlets (2 sets of wires) and connect them together before connecting to the house wiring Before trying anything like that I'd read the owner's manual. I have serious doubts that will work. You'd likely have to run some outlets on one branch and some on the other.
Eric212
Western Mass
BFL13 wrote: If you already have it will they take it back? There's lots of other inverters out there. It seems they are coming down in price a bunch lately too.
I didn't buy it yet, I'm glad I asked about it here first because I'm not crazy about that 500W per outlet idea.
Can anyone suggest another PSW inverter at 1000W (or more) that would be in the less than $400 price range?
I did some more looking and found This One never heard of that brand though.
MrWizard
Traveling
I like this one
http://www.tripplite.com/en/products/model.cfm?txtModelID=3056
Radiate The Happy
1997 F53 Bounder 36s
Gdetrailer
PA
Mr Wizard, that Tripplite is an great choice but it is MSW, the OP was asking about PSW. Many people are scared to death to run MSW but my experiences tell me most fears are un founded IF you buy a GOOD QUALITY MSW inverter built by a reputable manufacturer.
I have that same model of Tripplite inverter, extremely heavy duty, has no problem starting and running my 10 cu ft home fridge that I installed in my TT.
I would trust that inverter over any cheapy MSW or even no name PSWs.
OP depending on what you are planning to power that Tripplite will provide lots of power for many years. The only issues you will run into is if you are planning to power a microwave (tend to run slow), any heating pad or electric blanket with electronic temp controls.
Couple of things when considering high power inverters. You must plan out your setup so the inverter is as close to the batteries as possible without having them in the same compartment. The PV1250 is rated up to 3,000W surge, minimum fuse is 200-225A, this also requires very heavy gauge of wire. I used 1/0 extra flex wire and inverter is under 6ft of wire from the batteries. Don't plan to plug 1000W inverter into a cig lighter and expect it to work, in fact don't consider hooking it up to the 12V fuse panel, it must connect directly to the batteries..
Don't skimp on the 12V DC wire. I bought my 1/0 extra flex wire HERE which has the best price on this earth for this size of wire ($2.50/ft). (while you could use common building wire from Home Depot or Lowes, extra flex wire has very fine wire that flexes or bends easily which will make for easy installation)
By the way a better price on the PV1250 can be found HERE for $295
You can view my MY RV HINTS AND TIPS document for some pictures of my inverter and power setup.
OhioRVers
Central Florida
Go to DonRowe.com and check out his stock of PSW inverters. I just bought a Samlex 300 watt inverter from him. It appears that he has a sale price on an inverter each week.
I am happy with the buying experience and the inverter, a Samlex PST -30S-12A works great.
