RV.Net Open Roads Forum: Travel Trailers: Downsizing to Lightweight Trailer
 > Downsizing to Lightweight Trailer
GBlack
Evansville, Indiana
Posted: 10/04/09 10:04pm Link  |  Print  |  Notify Moderator
Thanks again for the info! I did think of two more questions:
1) Other than popups, do any other trailers "fold down" to fit under a 7 foot garage door (22 ft long x 8 ft wide stall)? Although I like the idea of hard sides, I assume they precludes trailers from folding down to fit in a standard height garage door.
2) I found out that if I order the Toyota "Tow Prep" package along with the "Trailer Hitch and Wiring Harness" accessory, that I will only get a 4-pin connector and no brake controller. Do all lightweight trailers have brakes? If so, I'm guessing I'll need to modify to a 7-pin connector and add a brake controller.
Thanks!
gregrc75
Fairhaven, Massachusetts
Posted: 10/05/09 09:25am Link  |  Print  |  Notify Moderator
[quote=GBlack]
Yes, try Trailmanor and HiLo
Greg and J
Ben - Yellow Lab. Charley - Red Lab
2018 Keystone Bullet Premier 30RIPR
2016 Nissan Titan XD SL 5.0
tr4
NY
Posted: 10/05/09 09:55am Link  |  Print  |  Notify Moderator
Thanks!
there are no factory brake controllers. You will have to run some new wires to make up the other connectors in a 7 pin.
brakes will depend on the model
BigPackFan
Endicott, NY USA
Posted: 10/05/09 09:59am Link  |  Print  |  Notify Moderator
Also, A-liner/Chalet trailers (hard side, A frames).
BPF
Searching for the right RV
2007 GMC Envoy
stpauligirlmn
St. Paul
Posted: 10/05/09 04:58pm Link  |  Print  |  Notify Moderator
First, don't feel too badly about making a mistake. I bought a pop-up when I really wanted a hardside trailer. Even though the pop-up was cheaper, I just wasn't content. I went out and bought a hardside the very next camping season.
Second, I would also suggest buying the vehicle with the highest tow rating. Some folks say that you only want to tow 80% of your towing capacity. 80% of 3500 = 2,800 lbs. That is pretty limiting for a hard side travel trailer.
Finally, I suggest that you look at many different trailers. It would be a shame to make the same mistake twice. Do you really want canvas and all the work of a pop-up? If so, perfect! Do you really want a bathroom with a black tank, or would you be content with a porta-potty or cassette toilet?
You might consider making a list of "wants" (I wanted A/C, but could live without it) and "needs" (I needed a furnace for Minnesota camping). Then look at as many trailers as you can that are WITHIN both your towing capacity and your budget.
Good luck in your hunt for the perfect trailer for you!
Tom Trostel
Arlington, TX
Posted: 10/05/09 06:43pm Link  |  Print  |  Notify Moderator
Yes, a few hard-sided trailers have been made that fit into a standard garage. But, mine was made in 1973 and I don't know of any that are currently made.
Compact Jr.
