RV.Net Open Roads Forum: Truck Campers: Flush Mount Electric Heater for Campers?
 > Flush Mount Electric Heater for Campers?
fishfinder
Colorado, USA
Posted: 01/02/10 08:57pm Link  |  Print  |  Notify Moderator
We just returned from an ice fishing & camping trip in Central CO. This time, I brought a portable electric heater and got a site with 110V. The electric heater held the camper at 55 degrees overnight on the 1000W setting, even though the outide temp was 11 degrees. We slept great because we never had to listen to the noisy propane heater cycle.
So, I'm now wondering, can I buy a flush mount electric heater to install so I can get the portable heater out of the limited floor space?
BTW, I've done a lot of insulating on this camper which has helped significanly. Also, I always keep one roof vent partially open at night.
fishfinder, Colorado
'08 Chevy K1500 Ext.Cab 5.3L/3.73
'03 Phoenix Pop-Up Truck Camper
'98 Four Winns 18' Fish & Ski Boat
Hook
Kenai Peninsula, Alaska
Posted: 01/02/10 09:27pm Link  |  Print  |  Notify Moderator
Dayton and Broan are a couple brand names off the top of my head, I sure there are more. When flush mounting on the wall they need several inches of space behind the wall. A source for them is Graingers, there are several of them located thru out Colorado.
I myself use a Wave 3, but it is not quite flush mounted.
Hook
Chevy 2500 4x4 CC D-Max/Allison
Summerwind 806
Winnebago 2014 30T
"Kik-n-but" 23' modified Atec, twin Yamaha 60's,
Hewes 20' Kenai River Special 50hp Yamaha,
Polaris RZR
27' Bayweld Offshore Boat, 300 HP,the "Bernie C"
Spott
SE Michigan
Posted: 01/02/10 09:36pm Link  |  Print  |  Notify Moderator
I installed one similar to this one
Me - Kim - Spot
JoeChiOhki
Sauvie Island, OR
Posted: 01/02/10 11:32pm Link  |  Print  |  Notify Moderator
Spott beat me to it, but I was going to suggest a Cadet 1500W in-wall heater, but they're a tad harder to find than they used to be. Home Depot only carries the 1000 Watt/120 volt units nowadays.
Cadet Com-Pak CC151TW Wall Mount Fan Heater
Here's Netboy's electric heat project:
Adding Built-in Electric Heat
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
Golden_HVAC
Fulltime, CA, USA
Posted: 01/03/10 12:12am Link  |  Print  |  Notify Moderator
I looked at the picture of this heater, and it might be possible to mount this on something like the bathroom door, or a cabinet door. Then run the wiring inside to the channle that leads to the circuit breaker box, or a receptacle.
You might also be able to find a flush mount "Kickspace" heater, designed to go under a kitchen cabinet. They are recesed into the kickspace under the cabinet, and are only 4" tall. Some have 500 - 750 and 1,000 watt settings.
While that will not heat your camper enough in 11F weather, along with the portable one, you will be toastey warm. I don't know if they have an automatic thermostat though. You can buy a line voltage thermostat, rated at 120/240 volts for about $40, it fits into a single gang handybox.
I always have 3 heaters with me, so I can turn on the heat as required in different sections of the RV. With two heaters, and a 30 amp service, you would have been toasty warm. I can not sleep below about 60F.
Good Luck,
Fred.
Alpenliter
Fulltimer: Wherever we are!
Posted: 01/03/10 12:35am Link  |  Print  |  Notify Moderator
The Perfectoe by Cadet is the one I installed and it is one of the best mods I've done. I installed it on the stair riser going up to the bath/bedroom. I wired in a dedicated circuit for it, so no worries and it runs all night long. We start the furnace to warm the cold trailer up, then turn it off and the Perfectoe maintains the temperature. I will tell you though that ice houses are insulated better than 99.9% of RVs!!
My first Wife Linda, 45+years 2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade Bulletproof Diesel upgrades 1997 33' Alpenlite 400 Watts Solar Lifetime Good Sam Member #39644174 Escapees SKP#89882 Vietnam Vet '67-'68 [
Note: Due to invalid formatting, all formatting has been ignored.
hotbyte
Barnesville GA
Posted: 01/03/10 07:34am Link  |  Print  |  Notify Moderator
Are these units more durable than the portable heaters? I've found after 3 or 4 years of use the portables don't seem to get as hot or the fan gets very noisy. I'd hate to put in a built-in and it fail a few years later [emoticon]
2018 Minnie Winnie 24M
Zig
Indiana
Posted: 01/03/10 07:50am Link  |  Print  |  Notify Moderator
I dont have one,... but I like the flatness of one like this. Eco-heater 602 High-Efficiency Electric Panel Whole-Room Heater
Better to Zig then Zag!
Go To "MY PICTURES"
My other Pictures and add a Comment!
fishfinder
Colorado, USA
Posted: 01/03/10 08:35am Link  |  Print  |  Notify Moderator
All,
Thanks for the great suggestions and links.
It looks like the Broan model #170 (1000W) is my favorite. The dimension are just right for available space that I have, and it has the thermostat built-in.
medic76
Washington, Indiana
Posted: 01/03/10 06:51pm Link  |  Print  |  Notify Moderator
I got a Broan 1500 watt model. Have used it in about a dozen ambulances over the years. The 1500 watt model is same physical size as 1000 watt, I think. The 1500 is actually 2--750 watt heat strips. I installed a switch and have 750 or 1500 whichever I want.
Also the portable heaters do get weak on output after a year or so but these don't.
Get the mounting kit as it controls the amount of cold air getting to the thermostat from the back.
Wayne
