RV.Net Open Roads Forum: Truck Campers: Fighting TC Slide Room Demons
 > Fighting TC Slide Room Demons
MrPhelps
Huntsville, AL
Posted: 03/31/10 02:35pm Link  |  Print  |  Notify Moderator
UPDATE... 31-Mar
We are cautiously optimistic a solution has been achieved, but will reserve judgement until more testing is conducted.
Using a mirror, one tech observed the movement of the slide while the other actuated the slide. It was discovered that the front Powergear slide mechanism was deflecting upward partially through the stroke. I did not see it myself, but they said they thought it had to do with the motion and weight of the room. Anyway the area was shimmed and the next series of tests were begun. We drove the truck around some and then (after removal of the Torklifts) elevated individual jacks to impose some different bending loads into the slide opening. The slide continues to work without incident.
We will drive it a couple of days around town and , if there are no repeat problems, take it on a weekend test trip. Hope this is the end of this saga. The exterior graphics are nearly dead on now too. [emoticon] Final check will be offload on return.
This whole series of problems in my opinion has been an example of how compound problems can result from multiple individual (and sometimes temporary solution) repairs.
* This post was edited 03/31/10 03:01pm by MrPhelps *
- 2018 RAM 3500 Laramie DRW
- 2018 Host Cascade Dual Slide
sleepy
Oak Ridge,Tennessee
Posted: 03/31/10 03:02pm Link  |  Print  |  Notify Moderator
Congratulations...
... these things are often simple in hind sight!
Just curious... are the graphics aligned now... or has all of the previous adjustments changed their alignment?
Sleepy
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
BradW
Mayor of Flat Rock
Posted: 03/31/10 03:36pm Link  |  Print  |  Notify Moderator
Good to hear you may have a solution.
Brad
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
MrPhelps
Huntsville, AL
Posted: 03/31/10 03:55pm Link  |  Print  |  Notify Moderator
sleepy wrote:
Congratulations...
Sleepy
Yes, they are very close to where they were originally.
Mooney
Santa Barbara, Ca
Posted: 03/31/10 05:46pm Link  |  Print  |  Notify Moderator
Glad to hear the positive outcome!
'08 Ford F550, Lariat, Link Air Suspension, Roll-A-Long Conversion, Twin Turbo 6.4, TorkLifts, SuperHitch, "Monster Duty Truckasaurus"
'09 Host Everest, Dual Pane, AM Solar, Link 1000,Prosine2.0,Tank Htrs,Honda EV4010,HD Motosat,Wave 6.
