RV.Net Open Roads Forum: Beginning RVing: TANK SENSORS
 > TANK SENSORS
Norm Payne
Livingston, TX
Posted: 05/17/02 05:20pm Link  |  Print  |  Notify Moderator
My motorhome came with sensors that stick on the outside of the tanks and they work great. You can buy that type and install them yourself.
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
hohiso
Florence, OR
Posted: 05/18/02 04:26am Link  |  Print  |  Notify Moderator
Norm - Any suggestions on where to look for them? Perhaps the motor home model you have them on?
Thanks
Regards, Allen
2005 Silverado SB, 2500HD Crew Cab, D/A, 42 gal aux tank, Garmin 1490T, XM Sat Radio,
2005 Alpenlite Valhalla, 16K Reese Manual Sliding Hitch,
Tonka the Rat Terrier guards the rig.
Lucky the Chihuahua guards Tonka.
camper guy
New Hampshire
Posted: 05/18/02 07:57am Link  |  Print  |  Notify Moderator
Looking into the toilet doesn't work on some of the newer models, there is a "shelf" of sorts that waste drops on and slides off so when you flush you don't see the rest of the tank.
Tried the ice trick with Pinesol, didn't work. Tried the guage level cleaner, didn't work.
Tried flushing the tank with water and more water and more water 4 times, didn't work.
Now I use enzymes or bacteria instead of chemicals and when I empty the tank, it says empty or 1/3, but it doesn't stay that way for long.
Even if your tank and sensor is clean, one piece of toilet paper lands on the sensor and it's all over for the weekend! I've given up on relying on the sensors.
2001 Sprinter 380BWS in a seasonal park.
Friend of Bills.....
juanito28
Camp Verde AZ USA
Posted: 05/18/02 09:45am Link  |  Print  |  Notify Moderator
Thank you RichB, that's the type of response I appreciate - thoughtful, informative and right to the subject. Will be visiting MN later this year.
New Full Timer
'91 Bounder 34J Towing '89 Merc Topaz Sedan
Norm Payne
Livingston, TX
Posted: 05/18/02 10:52am Link  |  Print  |  Notify Moderator
I have a Newmar Dutch Star and I think Newmar uses outside the tank sensors on all their RVs. I have seen that type advertised in RV magazines as add on units.
LAdams
Northern Illinois
Posted: 05/20/02 10:58am Link  |  Print  |  Notify Moderator
Hohiso,
The tank sensors in question are called Accu-Gauge and can be purchased from Camping World or Campers Choice and probably a few other outlets as well...
The gauge set is about $100 and can be installed by yourself if your handy... I installed them on my previous, older KIT 20' Road Ranger that didn't have any gauges at all... The Accu Guage setup worked very well and as far as I know, is still working without problems...
Best Regards,
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
HRperson
Rochester, NY
Posted: 05/20/02 11:08am Link  |  Print  |  Notify Moderator
I suggested the ice trick direct from the main post without reading the threads. Won't do that again....
*This Message was edited on 20-May-02 11:12 AM by HRperson*
Holiday Rambler Endeavor LE
FMCA #F311018
fishwar
Salem Virginia USA
Posted: 05/26/02 12:38pm Link  |  Print  |  Notify Moderator
The biggest reason that sensors stop reading is the crud get dried on them because when we get to a camp, we hook up the hose, dump and use the tank like a sewer pipe instead of a tank!!
If you will wait until the tank is nearly full, dump, close the valve again and let it fill up again, the crud doesn't get dried on. That goes for grey water also.
Warren Fisher - Titanium alumnus
'08 Lance 915, propane 2400 watt genset,fantastic vent w/rain cover, rain proof window louvers, 2 batteries
98 2500 Dodge CTD,Auto,SRW,BD Exhaust Brake,
EGT,TRANNY & BOOST GUAGES,4" PIPE AND ENGINE
POWER MODS
BG1811
Paducah, KY
Posted: 05/26/02 03:22pm Link  |  Print  |  Notify Moderator
You might wish to visit this site, they have some good information in re sensors. Of course, they would like to sell you their products. I have been very happy with the bacteria product.
http://www.rvchem.net
2004 Monaco Diplomat 40DST (Bath and half) - 2007 Mercury Mariner Hybrid FMCA F288615
AND Our Wonderful Norwegian Forest Cat, Mackenzie
 > TANK SENSORS
