RV.Net Open Roads Forum: Towing: Tow Tube Extension
Search only in Towing
Open Roads Forum  >  Towing
 > Tow Tube Extension
jasoncw
Brownstown, MI
Posted: 04/07/10 04:09pm Link  |  Print  |  Notify Moderator
Does anyone currently or have experience using an extension tube for towing a TT (like this)? I'm not sure if it would handle the load or not. It would be nice to be able to open my tail gate to let the dog in/out without unhitching the TT.
Thanks,
Jason
2016 Jayco Eagle 324BHTS
2005 Ford Excursion 6.8L 4.56's, V/C Springs, PP 3P, P3
Past:
2011 Keystone Bullet Premier 31BHPR
2009 Forest River Flagstaff 830RBSS
jasoncw
Brownstown, MI
Posted: 04/07/10 04:13pm Link  |  Print  |  Notify Moderator
lol Never mind. I found one by Roadmaster.
"The Hi-Low Drops and 12-inch extension are 6,000 lb. GVWR, and rated at 100 lb. tongue weight."
Chuck&Gail
In the Colorado Mountains
Posted: 04/07/10 04:15pm Link  |  Print  |  Notify Moderator
Just one point to remember. Most receivers are spec'd for a tongue load of 10" from center of ball to hitch pin for max weight. If you double the distance by adding a 10" extension, the tongue weight rating HALVES.
So, can you do it? Maybe, what is tongue weight now, and what is TT receiver rating. Looks like as big TT, so short answer is probably you should not.
Just my two cents.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
TXiceman
Full Time RVer
Posted: 04/08/10 06:24am Link  |  Print  |  Notify Moderator
Extending out past the normal draw bar position will LOWER the raqting on your receiver hitch. Same force on it, but a longer moment arm results in more torque and stess on the receiver and truck frame.
ken
Amateur Radio Operator.
hot rod
muskegon,mi
Posted: 04/08/10 04:24pm Link  |  Print  |  Notify Moderator
Some shanks are long enough to allow the tailgate to open. I wouldn't use that extension for a TT
LarryJM
NoVa
Posted: 04/08/10 04:45pm Link  |  Print  |  Notify Moderator
Just my two cents.
I've seen this number or others and what I can only call an internet myth. Please provide some concrete length to a receiver manufacturer that has this limitation. Now if you could get a 2' or 3' drawbar, then I could see that being a potential issue, but 5 or 6" NO WAY IMHO.
You can get longer drawbars up to around 16" and non of those indicate they effect your receiver capacity.
I just don't buy this 10" figure unless I see something concrete that I can rely on vs. just opinions or unsupported statements like yours.
Now actual tube extensions are a different story.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
mowermech
Billings, MT
Posted: 04/08/10 10:02pm Link  |  Print  |  Notify Moderator
I haven't used one for a TT, but I used one to tow my Jeep, and my boat (separately, not doubled), that was 41 inches long.
It was well braced, and I had no problems with it.
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toad: '05 Wrangler Unlimited
Toy: 1999 Dodge QC LWB, Cummins, Auto, 4X4
Other toys: 2 Kawasaki Brute Force 750 ATVs.
carringb
Corvallis, OR
Posted: 04/08/10 11:41pm Link  |  Print  |  Notify Moderator
Every 8" extension I've seen says that receiver capacity is reduced by 1/3rd. I use an extension for heavy trailers, but my receiver is rated for 6,000 pounds tongue weight
It can also be done with the TorkLift Superhitch, and their extension:
http://www.torklift.com/p.php?w_page=supertruss
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
TXiceman
Full Time RVer
Posted: 04/09/10 06:19am Link  |  Print  |  Notify Moderator
Where do we get the internet myth theory.
A first year engineering student can figure this one out. The longer draw bar and the farther back you get from the tow vehicle, the more stress you put on the hitch attachyment points and truck frame.
My Reese dual can has two ratinfs and the hole in the draw bar is only about 1.5" farther back than the close hole. It is a substantial drop in hitch capacity.
Ken
MitchF150
Puyallup, WA
Posted: 04/09/10 02:53pm Link  |  Print  |  Notify Moderator
Think of why you use a 'cheater bar' to bust loose some stubborn bolts.... You get that much more leverage on the bolt, so it turns easier... Same kind of thing is happening to the hitch on your truck... Stick that ball out farther from the hitch and it's just that much more force being applied to the hitch mounting points...
Unless you also beef up the hitch and it's mounts, I wouldn't do it...[emoticon]
Mitch
