Open Roads Forum |
Print | Close |
Topic: Air Con and 15 amp |
Posted By: Lynn608
on 05/01/10 04:48am
Good morning! we are waiting to leave for our long cross country trip and stuck here for a couple of hot days. We only have access to 15 amp so my question is... am I going to do harm to my airconditioner if I use it on 15 amp? it would be the only thing running of course. Hope the answer is no as it's going to be 86 in Mass. today!! Thanks Lynn |
Posted By: s.lawson
on 05/01/10 05:00am
I've done it with mine many times with no problems. I am led to believe that low voltage rather than low amperage is the killer for ac units. Other's may say different, but we have run ours off the 15 amp outlet from the garage as well as the generator, as long as other appliances weren't running as well, it did fine.
Posted By: JoeGood988
on 05/01/10 05:00am
Not knowing how large an air conditioner you have, most units pull at least 20 amps if not more to operate...15 will only blow the breaker.
2003 3330 Jayco Legacy |
Posted By: Lynn608
on 05/01/10 05:07am
Thanks guys.. I pulled out the manual (amazing I found it) it's a Carrier and it says "this air conditioner is designed to operate from a 115v AC 60Hz 1 phase power supply".. hmmm.. any comments? I think I'm going to risk it if all it does is blow the breaker. 86 degrees in a trailer is not fun. ![]() |
Posted By: tvman44
on 05/01/10 05:09am
The worst you can do is trip the breaker, make sure your power converter is turned off as you will need all of the 15 amps to run the A/C.
Papa Bob 1* 2008 Brookside by Sunnybrook 32' 1* 2002 F250 Super Duty 7.3L PSD Husky 16K hitch, Tekonsha P3, Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540 "A bad day camping is better than a good day at work!" |
Posted By: jetcare
on 05/01/10 05:35am
JoeGood988 wrote: ![]() Not knowing how large an air conditioner you have, most units pull at least 20 amps if not more to operate...15 will only blow the breaker. Start up amperage will be higher, but, RV AC units use 10-15 amps and will run on 15 amp service. If you pop the breaker, make sure the electric water heater is not on. Put the fridge on LP instead of Auto or AC. Matt the Mobile RV Tech 2016 F-250 Crewcab 6.2L 4x4 2012 Palomino Sabre 32' Travel Trailer |
Posted By: I am still wayne_tw
on 05/01/10 05:47am
Lynn608 wrote: ![]() ...a 115v AC 60Hz 1 phase power supply". That is the standard North American electrical standard. It has nothing to do with the amount or amps of electricity available. To answer your question, if you plug your RV directly into that 15 amp plug, nothing else is on in the RV (don't forget the refrigerator and convertor), and nothing else anywhere elseis running on the circuit, then your air conditioner should run without a problem on 15 amps. |
Posted By: MyakkaTT
on 05/01/10 06:06am
Used to do it all the time. The Carrier is pretty efficient you should be ok.. To high amperage draw and the unit will not run or blow breaker. To low voltage is hard on the componenets. Voltage meters are inexpensive that plug into an outlet to allow you to monitor for low voltage. 2002 Winnebago Itasca Sunrise 32V Towing a 2013 Jeep Wrangler My Wife: Dawn Myself: Scott Our Dog: Our new Fur Kid, Kylee Our Photos "Quietly Making Noise" ![]() |
Posted By: dboliek1112
on 05/01/10 06:09am
s.lawson wrote: ![]() I've done it with mine many times with no problems. I am led to believe that low voltage rather than low amperage is the killer for ac units. Other's may say different, but we have run ours off the 15 amp outlet from the garage as well as the generator, as long as other appliances weren't running as well, it did fine. x2. We plug into our home shore power a lot, run A/C. You may not be able to run much else without tripping the breaker. "The only thing more expensive than education is ignorance." Benjamin Franklin Dave and Missy Boliek Roxeanne, Bell and MaggieMoo 2000 Winnebago Chieftain 2007 Saturn Aura ![]() |
Posted By: VintageRacer
on 05/01/10 06:11am
I have a 15K btu Briskair, and it will run on a 15 amp circuit. You do run the risk of blowing the breaker, my unit is rated to draw 13 amps continuous or thereabouts, which is higher than the 15 amp breaker is rated for continuous load. But that is high speed, highest cooling setting. Just keep it on low. Brian 2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears. 20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer 1980 MCI MC-5C highway coach conversion 2004 Travelhawk 8' Truck Camper |
Posted By: wolfe10
on 05/01/10 06:47am
Actually there are TWO issues: Voltage as well as available amperage. If voltage is OK, indeed if the A/C draws too much power it will just trip the house breaker. No big deal. BUT, the more important issue for the A/C is whether the house wiring and any extension cords you ran in addition to your shore power cord caused a VOLTAGE DROP. Running your A/C below 108 VAC will hurt it (120 VAC is "normal"). Turning off all other 120 VAC breakers, such as converter, putting refrigerator on propane, etc all insure a better chance of being able to run the A/C. Brett Wolfe Ex: 2003 Alpine 38'FDDS Ex: 1997 Safari 35' Ex: 1993 Foretravel U240 Diesel RV Club:http://www.dieselrvclub.org/ |
Posted By: Dave H M
on 05/01/10 07:20am
I have been doing it for 8 years at this house. The ac is 13500. I even run the fridge on elec at the same time. I have been one of those plug it in and set her rip guys so i don't have any stats on the draw. |
Posted By: dougrainer
on 05/01/10 07:30am
1. RV AC units require a 20 amp breaker IN THE RV. That means they require GOOD 20 amp minimum service. 2. When these type posts come up, everyone forgets one thing---IT IS THE SUPPLY CONNECTIONS NOT THE RV THAT IS THE PROBLEM. That means YOUR supply is a 15 amp rated WALL outlet and THAT outlet is supplied with a smaller feed Romex 120 wire. So, you are probably overloading your HOUSE wiring and wall outlet which will cause heat build up 3. When you run your RV AC, that is NOT the only 120 appliance running. Your Power Converter will be on and pulling anywhere from 1 to 4 amps. 4. Most RV AC units pull a surge of 17 to 19 amps (less than 2 seconds) on start up. Most RV AC units will pull an average of 12 to 14 amps while running on Hi fan. That means on a 15 amp connection you are at the limit of the supply. 5. It is NOT a safe practice if you will not be in the RV at the time the RV is running. 6. LAST--The BIGGEST misconception is that IF I OVERLOAD THE SYSTEM, THAT IS WHAT THE 120 BREAKERS ARE FOR. WRONG, overloading will not always trip the breakers, that is how 120 electrical fires start. Overloading cause a dangerous heat build up that can cause melting and a fire. Doug |
Posted By: John / Angela
on 05/01/10 07:50am
Won't comment on your AC as I don't don't know what it is but to date have never found 13500 AC that draws more than 11 amps once running. i have never seen a 15 amp breaker pop if the AC is the only thing on it...and why should it. It is designed to be run on a single 15 amp 120 volt plug as that is the end that is on the cord. We do it routinely.
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer Life is not measured by the number of breaths we take but rather by the moments that take our breath away. |
Posted By: MEXICOWANDERER
on 05/01/10 08:27am
dougrainer perhaps is the closest. IF the 120vac wiring is in good condition to the receptacle. IF the wiring to the receptacle is 12 gauge and NOT 14 gauge IF the receptacle is a specification grade 15 amp receptacle IF your 30/15 amp shore power connector is in good condition You stand a chance of not having a problem for awhile. Eleven amps once running is not 25+ amps while starting and not 35+ amps while starting against high head. |
Posted By: time2roll
on 05/01/10 09:12am
Low voltage will hurt the air not the limit of 15 amps. Check voltage in the RV stays above 105 once the air is running. Ignor any dip during start up. And if the circuit breaker opens, no harm but no air. 2001 F150 SuperCrew 2006 Keystone Springdale 249FWBHLS 675w Solar pictures back up |
on 05/01/10 04:28pm
John & Angela wrote: ![]() Won't comment on your AC as I don't don't know what it is but to date have never found 13500 AC that draws more than 11 amps once running. i have never seen a 15 amp breaker pop if the AC is the only thing on it...and why should it. It is designed to be run on a single 15 amp 120 volt plug as that is the end that is on the cord. We do it routinely. John, click this link. NOW YOU HAVE HEARD WANT AMPS A 13.5 DRAWS. Go to page 3. The Dometic units pull anywhere from 13.6 amps to 14.6 amps. HOW did you come to state YOU have never seen a 13.5 pull more than 11 amps????? You work on them like me?? You accessed the specs like me?? There are some RVP low amp units out there but don't state for a fact that they all do that. They are NOT designed to run on a 15 amp plug. As I stated, they are designed for a 20 amp circuit. This is from the installation for both RVP and Dometic AC units. Doug "Route a copper 12 AWG, with ground, 115 VAC supply line from the fuse or circuit breaker box to the roof opening. a. This supply line must be located in the front portion of the 14-1/4" (±1/8") opening. b. The power MUST be on a separate 20 amp time delay fuse or HACR circuit breaker" http://www2.dometicusa.com/pdf/3109395.032.pdf Last, just because you can do something, does not mean it is correct and/or safe. |
on 05/01/10 05:13pm
dougrainer wrote: ![]() John & Angela wrote: ![]() Won't comment on your AC as I don't don't know what it is but to date have never found 13500 AC that draws more than 11 amps once running. i have never seen a 15 amp breaker pop if the AC is the only thing on it...and why should it. It is designed to be run on a single 15 amp 120 volt plug as that is the end that is on the cord. We do it routinely. John, click this link. NOW YOU HAVE HEARD WANT AMPS A 13.5 DRAWS. Go to page 3. The Dometic units pull anywhere from 13.6 amps to 14.6 amps. HOW did you come to state YOU have never seen a 13.5 pull more than 11 amps????? You work on them like me?? You accessed the specs like me?? There are some RVP low amp units out there but don't state for a fact that they all do that. They are NOT designed to run on a 15 amp plug. As I stated, they are designed for a 20 amp circuit. This is from the installation for both RVP and Dometic AC units. Doug "Route a copper 12 AWG, with ground, 115 VAC supply line from the fuse or circuit breaker box to the roof opening. a. This supply line must be located in the front portion of the 14-1/4" (±1/8") opening. b. The power MUST be on a separate 20 amp time delay fuse or HACR circuit breaker" http://www2.dometicusa.com/pdf/3109395.032.pdf Last, just because you can do something, does not mean it is correct and/or safe. Sorry my friend and with all due respect, I have not seen a 13500 BTU AC unit draw more than 11 amps. I never said there were not AC units that draw more than 11 amps, just that I have not seen one...and I have seen a few as well. Under the right conditions I am sure it can happen but like I said I haven't seen it. I have had RV some RV techs tell me I am wrong and have simply said "OK, lets check one, we'll use your meter' ![]() * This post was edited 05/01/10 05:19pm by an administrator/moderator * |
Posted By: gmachine
on 05/01/10 08:07pm
Our Coleman 15,000 btu a/c pulls 17 RUNNING AMPS @ 900' alt & 80/85 F. Jim Bering MD23(Cummins ISB)w/60" flattop Kenworth sleeper & 2005 Excel 35MKO Limited, 2006 Scion XA. |
Posted By: tmoo
on 05/01/10 08:21pm
FWIW: I just installed a Progressive EMS in my trailer today. I was curious to see how many amps I was pulling with the AC. According to the Progressive readout, the trailer was pulling 4-5 amps with the AC off which I assume is going to the converter. With the AC on it pulls 14-15 amps. I didn't see what the startup surge was or leave the AC on for more than about 5 minutes. I was also plugged into a 30amp circuit. My AC is a new 15K btu. YMMV. I ran my older trailer's 13.5K btu off 15amp household circuits for years without issues. To be fair those were quality circuits and I tried not to turn on additional devices other than the converter. |
Posted By: Wayne Dohnal
on 05/01/10 10:54pm
I had a Brisk Air model 57915 13,500 btuh air conditioner. The specs say the compressor draws 12.1 amps and the fan 2.5 amps for a total of 13.6 . Measuring it on multiple near 100 degree days with several devices, after the current draw had stabilized, the readings were between 11.0 and 11.5 amps. Yes, the specs say 12 awg wire and a 20 amp breaker. I also expect a 15 amp circuit to be able to provide 15 amps without causing a disaster. When running something like this on a 15 amp circuit I know enough to make sure the converter draw is low, or to shut it off, and monitor the voltage inside the RV. In a somewhat similar situation, the instructions for q-tips say to not insert them into the ear canal, yet I know of at least several people who routinely do this without any problems occuring.
2009 Fleetwood Icon 24A Honda Fit dinghy with US Gear brake system LinkPro battery monitor - EU2000i generator |
on 05/18/10 07:17am
Finally had a chance to check three AC's on new RV's. Got between 10.6 and 10.8 amps on two different meters, one analogue and one digital. It was about 80 degrees so that may have affected the results. All were 13500 BTU.
Posted By: Beltone Magoo
on 05/13/10 05:53am
When doing all the checking on voltage and current etc. are you taking the accuracy of your measuring instruments into consideration? Just a thought. Good luck, safe travels and happy camping! Doug & Connie 2001 Holiday Rambler Imperial 2001 Subaru Forester toad |
Posted By: steveh27
on 05/13/10 05:55am
No comments on my earlier post re the High Efficiency Dometic AC?? I should get it installed in a few days. It should work well on 15 amp service. It draws less power than my previous 11k btu Dometic. I think most people concerned about the AC power draw would benefit with this unit. I don't understand why this unit is not heavily promoted.
Posted By: Dave H M
on 05/13/10 06:24am
lYNN So did you plug it in or not ![]() |
on 05/13/10 09:07am
Quote: For myself, I always consider a single measurement to have the possibility of being incorrect. I've got 4 ways to measure AC current: a clamp ammeter, a direct-connect ammeter, a kill-a-watt, and a residential electromechanical watt hour meter obtained from a power company. The watt hour meter result is calculated after applying the voltage and power factor. For the air conditioner measurements, all the current readings agreed within a 2% range. With even 2 measurements that agree I get pretty confident about it, yet acknowledge the possibility of both being wrong.
![]() When doing all the checking on voltage and current etc. are you taking the accuracy of your measuring instruments into consideration? |
Posted By: Heir Max
on 05/13/10 12:06pm
Brett has it right. Make sure you turn everything else off, put on gas, and plug directly into house receptical or make sure your cord is large enough. I do it all the time at my sons house. The fixation applies here as it does to tire pressure. Man! 99 Tradewinds 2000 Explorer Toad |
on 05/12/10 08:19am
Wayne Dohnal wrote: ![]() Quote: I admit to the math error. I measured the draw with a direct-connect ammeter, clamp-on ammeter, and watt-hour meter. The unit was running more than 15 minutes. The measurement never exceeded 11.5 amps. If my Brisk Air wasn't running correctly I have the comfort of having a lot of company, thus Dometic must have had a run of bad air conditioners. I've participated in a lot of "can an eu2000i run a 13.5k air conditioner" threads and a lot of owners have reported exactly the same results. It was these threads that led to the careful measurements by myself and others. I don't have any personal stake in these technical threads, just reporting the facts as I see them.![]() Well lets see, 12.1 PLUS 2.5 === 14.6 in my book, not 13.6. HOW did you measure the amp draw on that 100 degree day??? The spec sheet is the actual amp draw for that unit at 95 degree outside temp, so, at 100 degree the correct actual amp draw will be 15.1 amps on hi fan. If yours was NOT pulling 15.1 amps, then the AC is NOT operating to its full specs and is NOT cooling as it should. The amp draw does NOT go down after running. The amp draw is taken after a minimum of 15 minutes running to get the compressor system pumped to full load. Wayne, do you understand that the outside ambient also must be taken into account for amp draws??? For instance, the amp draws are based on 95 degrees ambient. So, if you have a unit that pulls 14 amps at 95 (Hi Cool), then at 75 degrees it will pull 12 amps. So, when you take these tests and readings, when it gets HOT outside, then the AC will have to work harder and will pull more amps. In my example, at 105 degrees it will pull 15 amps. Doug |
on 05/12/10 08:42am
dougrainer wrote: Doug, I understand! I believe you are basing your statements on the published specs, adjusting for temperature by applying a correction factor that you believe to be correct. I am reporting actual measurements in a specific situation that applies to my use and to a lot of others. I think the specs are a good starting point, but nothing is better than actual, live data. When the data disagrees with the specs, I go with the data. If I were running at 105 degrees, the minimum 103.5 voltage, and had the bad luck to have the unit with the worst-case motor and compressor, maybe I'd see those worst-case current draws. Based on comparisons with other reports, my unit was pretty typical.
![]() Wayne, do you understand that the outside ambient also must be taken into account for amp draws??? For instance, the amp draws are based on 95 degrees ambient. So, if you have a unit that pulls 14 amps at 95 (Hi Cool), then at 75 degrees it will pull 12 amps. So, when you take these tests and readings, when it gets HOT outside, then the AC will have to work harder and will pull more amps. In my example, at 105 degrees it will pull 15 amps. Doug |
Posted By: plauterer
on 05/12/10 09:48am
I have plugged into 15 amp outlets many times over the last 15 years and ran the air conditioner. Never had any problem, but I do check the voltage in the trailer too see that it is not 108 volts or lower.110 or higher is OK for running the air.108 volts or lower Just turn off the air conditioner and enjoy the heat. My current trailer has a 20 amp breaker the previous one had a 15 amp.
on 05/12/10 09:52am
Wayne, you miss the WHOLE point. Those "published" specs ARE the actual correct specs to check out and diagnois a AC. NOT "maybe" specs. IF you checked out an AC using your criteria and the "Specs" said 14 amps for the ambient conditions and YOU found 12 amps, you state YOU are the correct. Not true, your measurements would be wrong regardless of how many you checked. 2 + 2 ALWAYS equals 4. BTW, I suspect you are an Engineer? True? Doug
Posted By: tpi
on 05/12/10 03:57pm
Try it. Make sure the voltage stays in normal range. If you're on the margins, run the refrigerator on gas to save a couple hundred watts. Also be sure your batteries are fully charged before doing this to minimize draw from the power converter. BTW the AC units I've checked use a little less power at low fan speed. ![]() |
on 05/12/10 07:21pm
dougrainer wrote: True. My attitude is that when reality doesn't match the specs or theory, there's something wrong with the specs or theory. I've measured a lot of devices like TVs and refrigerators, and I don't recall any of them coming close to their spec'd current draw. I always consider specs to be suspect until an actual measurement is made.
![]() Wayne, you miss the WHOLE point. ...snip... BTW, I suspect you are an Engineer? True? Doug |
Posted By: steveh27
on 05/12/10 06:56am
My Xplorer Class B Dometic 11k btu unit died after 1 year. Don't know why, but I had installed the Suppco hard start capacitor when that unit was installed. It never worked right. The installers may have screwed it up. Dometic no longer makes the 11k unit, but does make a high efficiency 13.5 unit, model 459530. http://www.campingworld.com/shopping/item/high-efficiency-brisk-air-13-500-btu-air-conditioner/17965 According to Dometic it has a 15 amp need & draws only 8+2=10 amps when running. I have this one on order. The only negative is that it weighs 20# more. I don't know why Dometic does not advertize this unit. They said I was the first customer to ever want this over the standard 13.5 btu unit. As I sometimes plug into homes outside receptacles & yet never stay at a campground I wanted the lower draw unit. Being a Class B, 20' long, I wished to get a smaller btu unit to cool properly my small space. |
on 05/02/10 07:29am
Wayne Dohnal wrote: ![]() I had a Brisk Air model 57915 13,500 btuh air conditioner. The specs say the compressor draws 12.1 amps and the fan 2.5 amps for a total of 13.6 . Measuring it on multiple near 100 degree days with several devices, after the current draw had stabilized, the readings were between 11.0 and 11.5 amps. Yes, the specs say 12 awg wire and a 20 amp breaker. I also expect a 15 amp circuit to be able to provide 15 amps without causing a disaster. When running something like this on a 15 amp circuit I know enough to make sure the converter draw is low, or to shut it off, and monitor the voltage inside the RV. In a somewhat similar situation, the instructions for q-tips say to not insert them into the ear canal, yet I know of at least several people who routinely do this without any problems occuring. Well lets see, 12.1 PLUS 2.5 === 14.6 in my book, not 13.6. HOW did you measure the amp draw on that 100 degree day??? The spec sheet is the actual amp draw for that unit at 95 degree outside temp, so, at 100 degree the correct actual amp draw will be 15.1 amps on hi fan. If yours was NOT pulling 15.1 amps, then the AC is NOT operating to its full specs and is NOT cooling as it should. The amp draw does NOT go down after running. The amp draw is taken after a minimum of 15 minutes running to get the compressor system pumped to full load. Doug |
on 05/02/10 07:34am
"Sorry my friend and with all due respect, I have not seen a 13500 BTU AC unit draw more than 11 amps. I never said there were not AC units that draw more than 11 amps, just that I have not seen one...and I have seen a few as well. Under the right conditions I am sure it can happen but like I said I haven't seen it. I have had RV some RV techs tell me I am wrong and have simply said "OK, lets check one, we'll use your meter' I have seen a 15K get close to 12.8. Sorry my friend, just calling them as i have seen them". John, what do you mean by "I have seen a few"? 2 or 4 or 10? I have seen probably thousands. The majority of RV roof AC units pull at least 13 amps on hi fan. Did you read the amp draws on the Dometic units from that link? What is your basis for proclaiming your expertise on this subject? I AM a professional and have been for 32 years. I doubt you have ALWAYS seen the Low amp Coleman AC units as you only basis for your erroneous claims on amp draws. HOW and what tools were used for these amp draw readings on your "few". Doug |
on 05/02/10 08:02am
dougrainer wrote: ![]() "Sorry my friend and with all due respect, I have not seen a 13500 BTU AC unit draw more than 11 amps. I never said there were not AC units that draw more than 11 amps, just that I have not seen one...and I have seen a few as well. Under the right conditions I am sure it can happen but like I said I haven't seen it. I have had RV some RV techs tell me I am wrong and have simply said "OK, lets check one, we'll use your meter' I have seen a 15K get close to 12.8. Sorry my friend, just calling them as i have seen them". John, what do you mean by "I have seen a few"? 2 or 4 or 10? I have seen probably thousands. The majority of RV roof AC units pull at least 13 amps on hi fan. Did you read the amp draws on the Dometic units from that link? What is your basis for proclaiming your expertise on this subject? I AM a professional and have been for 32 years. I doubt you have ALWAYS seen the Low amp Coleman AC units as you only basis for your erroneous claims on amp draws. HOW and what tools were used for these amp draw readings on your "few". Doug I am no expert and have probably seen no more than 30 or 40. Don't know what to tell you. Honestly you now have me questioning myself. I will check a few out this week time allowing. Anybody who knows me knows I won't have a problem eating humble pie if I am wrong. We'll get back to this thread in a week or so. I wish we could put a case of beer on this...still, now I'm gettin nervous. ![]() |
on 05/02/10 09:28am
![]() Well lets see, 12.1 PLUS 2.5 === 14.6 in my book, not 13.6. HOW did you measure the amp draw on that 100 degree day??? The spec sheet is the actual amp draw for that unit at 95 degree outside temp, so, at 100 degree the correct actual amp draw will be 15.1 amps on hi fan. If yours was NOT pulling 15.1 amps, then the AC is NOT operating to its full specs and is NOT cooling as it should. The amp draw does NOT go down after running. The amp draw is taken after a minimum of 15 minutes running to get the compressor system pumped to full load. |
Print | Close |
