RV.Net Open Roads Forum: Truck Campers: Thermostat upgrade in my AF811
 > Thermostat upgrade in my AF811
deltabravo
Spokane, WA
Posted: 05/12/10 10:13pm Link  |  Print  |  Notify Moderator
AF Truck campers use a thermostat which only controls the heat, not the heat and A/C, so there's far less wires to figure out where to connect when doing a t-stat upgrade, unlike the DF toy hauler I did a similar upgrade on a few years sgo.
I remember reading Ken Lenger's t-stat upgrade years ago, and eventually did it on my Desert Fox.
The challenge here is most t-stats are too wide to fit in the narrow space where the stock t-stat resides.
I found a Honeywell RTH221B from Home depot. It fits perfect, and it's inexpensive: $19.83. It uses 2 AAA batteries
http://hbctechlit.honeywell.com/Home/Pro........rmostats/1-Week-Programmable/RTH221B.htm
The stock t-stat barely fits between the edge of the wall and the stereo:
New t-stat:
(someone had bought and returned this one and cut the top of the package off)
I bought the "open package" because I wasn't really sure if this unit would work in this application or not, so if it didn't work, I didn't feel bad about returning something that was "already open from a previous purchase" since the HD store I went to had one that was open. Had they all been sealed, I would have bought one anyway.
Remove cover from old t-stat
2015 Nash 17k (bought pre-owned 5/23/18)
deltabravo
Spokane, WA
Pull it off the wall. Top wire, red, is the R terminal, bottom terminal labeled W has the white wire and a larger black wire.
Small screw on bottom of new unit holds the unit to the base plate
Terminals on the base plate:
Right side: Rh and W terminals - that's what we'll use:
deltabravo
Spokane, WA
I pulled a little more wire out of the wall:
Connected the red wire to Rh:
White and black wire to W terminal:
This picture also shows where I drilled a new upper mounting hole, located between the terminal wiring diagram. The object was to "cover the original mounting holes with the new t-stat, but not need to drill NEW holes that could not be concealed if I reinstall the old t-stat years down the road."
I covered the original holes with foil tape, but anything will work. I just wanted to cover them to eliminate air intrusion from behind the t-stat.
deltabravo
Spokane, WA
Posted: 05/12/10 10:14pm Link  |  Print  |  Notify Moderator
I shoved some foam in the hole as I stuff the wires back in to the wall:
Mounted the base plate:
Pop the main unit on to the base plate and secure the screw to keep it in place.
Control buttons are on the right side - there's master switch that turns the heat on or off, and a fan control switch that does nothing since we aren't controlling an A/C unit.
The master switch also has a "cool" position, but again, since the truck campers don't have A/C controlled by the t-stat, all we use in campers will be the "heat" function.
It is a "programmable" t-stat, so you can set heat to various temps during the day (wake, leave, return, sleep"
Done:
Display shows room temp and time of day. When you press an up or down button, then it will show the "set point".
time2roll
Posted: 05/12/10 10:18pm Link  |  Print  |  Notify Moderator
Cool job [emoticon] I mean it shows 58 so get the heat on already [emoticon]
675w Solar pictures back up
deltabravo
Spokane, WA
Posted: 05/12/10 10:27pm Link  |  Print  |  Notify Moderator
Admins/Mods, could you link this in the TCU?
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 05/12/10 11:00pm Link  |  Print  |  Notify Moderator
Nice job.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
sdavis622
Puyallup, WA
Posted: 05/12/10 11:07pm Link  |  Print  |  Notify Moderator
Very nice! Good work.
-2007 Ram 2500 Laramie CTD
-2006 Arctic Fox 25S
Trailer Mods! Trailer! Truck!
capeangler
Massachussetts
Posted: 05/13/10 05:49am Link  |  Print  |  Notify Moderator
nice job and great tutorial . thanks for sharing ,
I will be doing this to mine for sure
thanks again
Thanks
capeangler
1 wife , 3 kids , 1 dog , 2 cats , too many fish to count ">
2008 Chevy 3500HD, CC, Duramax, Allison,DRW ,Timbrens, Bilsteins,Hellwig sway bar
2007 ZT300BHS Crossroads
2007 Adventurer 10T Torklifts , Fast Guns
capeangler
Massachussetts
Posted: 05/17/10 04:15pm Link  |  Print  |  Notify Moderator
thanks again
Just did my upgrade with the same unit that you purchased. Love the new look and I can actually see the settings with out having to find my glasses. Plus I have a nice clock now [emoticon]
Interesting thing is my existing t-stat only had 2 wires ? What was the big black wire for? Do you think I need it? ,, I tested the system and all seems okay .
Thanks
