RV.Net Open Roads Forum: What did you do to your Toy Hauler today???
Search only in Toy Haulers
 > What did you do to your Toy Hauler today???
Page of 229
joebedford
Finally back home in the north
Posted: 12/13/18 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Repaired the water leak into the services cabinet from the outdoor shower.
joebedford
Posted: 01/13/19 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Dumped vegetable oil into the tanks to try to loosen up the dump valves.
mkisamore
Indian head
Posted: 01/13/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
stared at it setting in 8 inches of snow 2 1/2 months
2 1/2 months to go
deltabravo
Spokane, WA
Posted: 01/13/19 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Video of New tires and wheels!!!!!!!!!!!
2015 Nash 17k (bought pre-owned 5/23/18)
Rich Panganiban
Southern California, USA
Posted: 04/02/19 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Nice!
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
1320Fastback
Vista, Ca
Posted: 04/02/19 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
Was last weekend but fixed a propane leak where road debris cracked a fitting under the trailer, rotated the tires, lubed the bearings and adjusted the brakes. We just got back from a 5,200 mile trip and are leaving again soon for about another 1,000 round trip.
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
Flashman
Tucson, Aizona, USA
Posted: 04/03/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
I moved my rear scissors jacks forward on the frame a couple of feet - to give me better clearance in the rear when going through dips or over bumps.
MartyMoose
Worthington, OH
Posted: 04/10/19 04:34am Link  |  Quote  |  Print  |  Notify Moderator
"Dumped vegetable oil into the tanks to try to loosen up the dump valves."
First I've seen this.....work? Mine is sticky which makes me nervous....ha
Thanks
2014 Heartland 305RW Road Warrior
2012 Ford F250 Lariat
RTBabich
T.O., Ca
Posted: 06/29/19 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
1L243 wrote:
.... So I orderd a 7 Way 8' harness with junction box that is color coded. ....
I love those junction boxes, it makes trouble shooting wiring a lot easier.
For trailers with 4 electric brakes the wire gauge size is sometimes just adequate.
Ours ran one wire from the 7 way to the LF brake, on to the LR brake, crossed over to the RR then ended at the RF.
I ran a larger gauge wire for each brake from the post in the junction box to each brake.
Now if I want to test a particular brake I can pull its' wire for testing and I know each brake is getting a good voltage.
2009 Weekend Warrior, FB2100, 23ft, 7.5k, Maxxis ST225/75R15, Dexter EZ Flex, Equalizer 10k
rovyart
Duarte, CA, USA
Posted: 07/09/19 03:05am Link  |  Quote  |  Print  |  Notify Moderator
I installed a newfifth wheel hitch and did some cleaning on our cabinets today.
* This post was edited 07/09/19 09:50am by rovyart *
fifth wheel
Page of 229
