RV.Net Open Roads Forum: Truck Campers: polar cub 9200 and honda 2000W
 > polar cub 9200 and honda 2000W
Flashman
Tucson, Aizona, USA
Posted: 06/24/10 06:04pm Link  |  Print  |  Notify Moderator
As others has stated will run it but need to watch the frig and the battery charger.
Reddog1
El Dorado, CA
Posted: 06/26/10 02:27pm Link  |  Print  |  Notify Moderator
I have a Polar Cub 9201D, and run it with my Honda 2000, without a problem. It does not run the Honda at full RPM. The specs on the Cub, says it requires AMPS: 8.5-amps(low) to 8.9-amps (high). I have not had the need to disconnect my 55A Iota charger, while running the A/C.
Edit: I do not run my Refer on 12-volts, and do not run my microwave while running the A/C.
Wayne
* This post was edited 06/26/10 02:42pm by Reddog1 *
Adacas
Abbotsford BC
Posted: 07/01/10 10:42am Link  |  Print  |  Notify Moderator
Thanks for all the input. Its installed and works great with the 2000W Honda. Just like you all said it would.
Its interesting how everyone who uses this equipment says it works fine (not one who said it doesn't) yet the tech's at the Dealer RV Parts dept's say it won't work.
'05 F350 6.0L PSD DRW 4x4 LB CC
'06 AF 990
BradW
Mayor of Flat Rock
Posted: 07/02/10 04:37am Link  |  Print  |  Notify Moderator
Good info; added to the TCU page.
BradW
Mayor of Flat Rock
Posted: 07/01/10 11:14am Link  |  Print  |  Notify Moderator
Which model Polar Cub did you end up getting?
Will it run on econo mode?
What the altitude at your location?
Thanks,
Brad
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
Adacas
Abbotsford BC
Posted: 07/01/10 11:56am Link  |  Print  |  Notify Moderator
Thanks,
Brad
Brad. The model is 9201A 776 (I'm not sure what the 776 designates)
Yes it runs on econo mode. I live near the coast so my elevation is near sea level. I understand that can make a difference so I'll post soon as I know about running it at higher elevs.
Reddog1
El Dorado, CA
Posted: 07/02/10 12:10am Link  |  Print  |  Notify Moderator
Are you sure it is 776? I think maybe it is a 876. If so, I think the 876 is the color, ARC WHT. If it was a 879, the color is BLK.
This link, Model Number Changes, is how I came to that conclusion.
Wayne
Reddog1
El Dorado, CA
Posted: 07/02/10 12:37am Link  |  Print  |  Notify Moderator
The fan (hi-1.4 amps or low-1 amp), will run in the econo mode. When the compressor (7.6 amps) kicks in the Honda will go out of the econo mode.
This is the data sheet for the Polar Cub 9201B876. I think this is the same for all of the 9200 series.
Data sheets can be found here.
Wayne
FredAr
Arizona
Posted: 07/02/10 07:15am Link  |  Print  |  Notify Moderator
This very important question/subject has been coming up on and off for the last 4 years in this forum. The absurdity of those huge 13.5 and 15 BTU A/C units that manufacturers blindly put in TCs, surely added to the fire.
As the above readers have said it will work, and just be considerate of other high-wattage appliances running at the same time. One thing I have found with this combination: I like to put the H2000 in NON-Eco mode, start AC, and then after a minute, manually put Eco Mode on, the generator then tends to go more into Eco Mode this way than 'automatically'. Minor point, but perhaps useful, since to many, the less generator noise the better.
2006 Dodge RAM 2500 Mega Cab
2007 TC (Pastime 880ST) / 2005 TT (Montana 335 RLBS)
Monster Maker
Seattle, WA, U.S.A.
Posted: 07/04/10 08:54am Link  |  Print  |  Notify Moderator
13.5 and 15k BTU A/Cs aren't absurd when you like to go to Black Rock Desert, Nevada in August!
