RV.Net Open Roads Forum: Tech Issues: Winter RV camping
 > Winter RV camping
Page of 19
pianotuna
Regina, SK, Canada
Posted: 09/02/19 11:52am Link  |  Quote  |  Print  |  Notify Moderator
LI designed with heater for winter use. (Not perfect--but getting there):
https://relionbattery.com/blog/lithium-battery-cold-weather
Regards, Don
dave17352
Ne
Posted: 09/03/19 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
I called them about this battery. There tech guy said this is fine for occasional use but you are still better off keeping these batteries in a controlled temperature environment. Those were not his exact words but that's what he was getting at. I asked about leaving the battery in my truck camper year around here in Nebraska.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
Ansings
Ohio
Posted: 11/09/19 11:00am Link  |  Quote  |  Print  |  Notify Moderator
***Link Removed***
Yeah, not bad.. I'm going to try camping this winter. I will try it as well. thx
pianotuna
Regina, SK, Canada
Posted: 11/07/20 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Ansings wrote:
***Link Removed***
Hi Ansings,
You may want to go to SiO2 batteries instead of LI. about 1/2 the price and able to be used at -40
time2roll
Posted: 11/07/20 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
My wheels will be turning before it goes to -40 [emoticon]
I like to visit the snow but that is just too chilly for me.
675w Solar pictures back up
Moving-on
mobile
Posted: 02/09/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I wish I had found this before our involuntary cold weather camping. I didnt know about the effects of the cold on refrigerators. And I hope ours is ok. As I said in the other thread, we coasted along in the 20s for awhile, but our pump feed line froze up on the second night of about 8 degrees. We had a full fresh water tank, with the tank heaters running. But I believe where I screwed up was running a space heater upstairs. I believe that it made the furnace cycle less, allowing the cold to creep into our belly. Since ours bleeds furnace heat between the floor and belly cover. I hope the fridge survived and that we never have to go that low again.
SteveAE
Bend, Oregon
Posted: 02/09/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
It's probably just fine.
mmiille
Iowa
Posted: 02/09/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
The refrigerator is just not effective in cooling when the temps drop down below zero. It should still work fine when temps rise. If you have an ice maker, it may freeze and break. We put heat tape on ours in the winter.
Also only used space heaters in rooms with no thermostat. Let the room with the thermostat control the furnace. But when it was 6 degrees Fahrenheit or less, the furnace never shut off. We used 200 gallons of LP a month in 2015. But we stayed warm.
Martin & Cheryl
40 Foot 2009 Damon Tuscany 4076
Cummins 360, Hyundai Santa Fe
Full timing since 2010.
pianotuna
Regina, SK, Canada
Posted: 02/09/21 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
-39 C last night.
24/7onroad
United States
Posted: 06/10/21 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Hi, do you think it's a good time to live a full RV lifestyle in Europe now?
Do you have any experience in the last year due to the world's current situation?
Thanks!!
Page of 19
 > Winter RV camping
