RV.Net Open Roads Forum: Tow Vehicles: First Tow With Tundra 2010 4.6L
Search only in Tow Vehicles
 > First Tow With Tundra 2010 4.6L
Bob Landry
Austin, texas
Posted: 07/09/10 04:57pm Link  |  Print  |  Notify Moderator
Pulled a Jayco 22FB, 4635 dry from Austin to Blanco. errain was slightly hilly with good straigt roads. Trannie seemed to shift a lot, but I suppose it's supposed to. Mileage was better at 12mpg than 9.5mpg pulling the same trailer with a 4Runner V6.And, the transmission temp guage never budged.
I may have done better mileage-wise with the 5.7L, but my towing time is small compared to overall driving time, so for in town economy, I think I made the right choice. I don't think I'm at 5000lbs with the trailer, but I don't have very far to go. The truck is rated to pull 8600lbs
2011 Keystone Outback 277RL
Ron3rd
Upland, CA USA
Posted: 07/09/10 05:00pm Link  |  Print  |  Notify Moderator
If you're happy the way it tows, then that sounds good to me.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
fivecodys
Central California
Posted: 07/09/10 05:11pm Link  |  Print  |  Notify Moderator
Sounds like a good fit.
Are you towing with the overdrive on?
If so turn it off and see if that helps with the tranny "hunting" all the time.
Enjoy your new rig.
Bill
2007 Tundra DC 5.7L V8
SuperGlide 14K
Prodigy Brake Controller
2009 Flagstaff 8528RKSS Ultralight Series
Air Lift 5000
We have enough youth.......... how about a fountain of "smart"? ">
Bob Landry
Austin, texas
Posted: 07/09/10 05:12pm Link  |  Print  |  Notify Moderator
The tow/haul function is supposed to turn off the overdrive.
~DJ~
Boise, Idaho
Posted: 07/09/10 05:54pm Link  |  Print  |  Notify Moderator
As long as you are happy with your outfit you have all ready pleased the most important person to deal with it!!! [emoticon]
'16 FORD F250 6.2. Air Bags
'16 Arctic Fox 25R. Xantrex 2000 inverter/charger, four Trojan 6 volts, 450 watts solar.
kknowlton
southeast Idaho, formerly IL/WI border
Posted: 07/09/10 06:03pm Link  |  Print  |  Notify Moderator
Which tranny do you have? If you have the 6-speed with semi-manual as well as fully automatic setting, try towing with the stick in the S position instead of D. Not sure if tow-haul disengages OD; I do know it makes the tranny shift less often - it revs up more before downshifting than with it off.
2007 Toyota Tundra CrewMax 5.7L V8 w/ tow pkg, Equal-i-zer
2013 Rockwood Mini-Lite 2502S
Bob Landry
Austin, texas
Posted: 07/10/10 12:45pm Link  |  Print  |  Notify Moderator
It must not disable OD.When it does shift into high, the tach is reading around 1500 rpms. it downshifts when it needs to and the trannie temp syas good, so I'm going to assume everything is working as it shout. I checked mileage going and returning and got 11-12MPG pulling through the Texas Hill Country.
E&J push'n wind
San Diego CA, The best climate on earth!
Posted: 07/10/10 03:15pm Link  |  Print  |  Notify Moderator
Bob,
You may want to check your owners manual about towing in OD. If it is shifting alot then you may be asking to much of it in OD. If you have the 6 speed then drive in 5th, I seriously doubt you'd notice any difference in fuel mileage. Might even do better shifting less, FWIW.
Wisdom is the right use of knowledge. To know is not to be wise. Many men know much, and are all the greater fools for it. There is no fool so great a fool as a knowing fool. But to know how to use knowledge is to have wisdom.
Charles Haddon Spurgeon
Bob Landry
Austin, texas
Posted: 07/09/10 07:01pm Link  |  Print  |  Notify Moderator
It appears that the tow/haul switch just changes the shift points but I'm not sure about disableing the OD. I'm just wondering if they are used together(toe/haul & "S").
E&J push'n wind
Posted: 07/09/10 10:42pm Link  |  Print  |  Notify Moderator
TV is a Nissan and TH does not disengage OD with mine, if Toy is anything like the Nissan it doesn't, just changes the shift points based on throttle input.
