Open Roads Forum |
Print | Close |
Topic: Using self stick kitchen plastic wrap as window insulation? |
Posted By: Admiral
on 12/19/10 10:38pm
I was thinking of giving this a try but I don't think they make it big enough for an rv window w/o using multiple pieces. I have one small window it will fit on and, of course, the little window in the door. Let's hear your suggestions and experiences please.
2004 Damon Daybreak 2960F V-10 05 Honda Element LX Compassion should be voluntary, not mandatory. ![]() |
Posted By: hershey
on 12/19/10 11:10pm
The dollar stores sell some 1/8" thick poster board. It has foam in between the outer surfaces. Its about 3' square and easy to set in the windows when needed and easily stored under the mattress when not. Comes in colors and white.
hershey - albuquerque, nm Someday Finally Got Here My wife does all the driving - I just get to hold the steering wheel. Face Book Group: All About RVing and We Fly RC's Expedition - Chevy Equinox ![]() |
Posted By: christopherglenn
on 12/19/10 11:12pm
Poor mans double pane windows. Check the hardware store for larger pieces. Use a hairdrier (be VERY careful) to shrink the film after applying (works with the hardware store stuff), makes it harder to see. I have used double sided foam tape + plastic stretch wrap with good results.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64 2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614 ![]() |
Posted By: skipnchar
on 12/20/10 03:52am
I wouldn't think a sheet of a few millimeters thick plastic is going to do much to insulate anything. Might stop a draft if your windows leak but won't do much insulating. Reflextix works reasonably well for the purpose due to the dead air space between it's layers and still allows some light to pass through.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR - 2004 F-150 HD (Traded after 80,000 towing miles) 2007 Rockwood 8314SS 34' travel trailer US Govt survey shows three out of four people make up 75% of the total population ![]() |
Posted By: Bumpyroad
on 12/20/10 05:12am
Lowe's/Home depot sell a kit of sheets of plastic to make temporary storm windows. and the advantage is that they won't cost you $733 apiece to replace them when they go bad. bumpy ![]() |
Posted By: blackf3504dr
on 12/20/10 05:19am
skipnchar wrote: ![]() I wouldn't think a sheet of a few millimeters thick plastic is going to do much to insulate anything. Might stop a draft if your windows leak but won't do much insulating. Reflextix works reasonably well for the purpose due to the dead air space between it's layers and still allows some light to pass through. It serves the same purpose as the old storm windows that people had before the advent of double pane windows. Mom , Dad , Scooter & K.C ( killer cat ) '96 F350 4dr. Dually, 7.3 5sp. '92 Holiday Rambler 34' REAL TRUCKS DON'T HAVE SPARKPLUGS ! |
Posted By: deltamaster
on 12/20/10 01:18pm
Wish this subject had come up a few weeks ago. had never considered plastic sheeting over the windows. I would like to know if sheeting the windows will reduce the moisture that builds up on the inside of the pane? It is amazing to me how much water collects on the window, in the channel and then runs down the wall! "> I ride it like I stole it! "> .......and I just may have....... I'm on "CB-13", are you? 2004 Fun Mover with a 1998 Road King and a 2002 Sportster tucked in the garage, Dragging a 2002 "RAM Tough" Dodge Dakota Crew Cab. Ohhh what a haul! TSgt(Ret.) USAF |
Posted By: B.O. Plenty
on 12/20/10 01:29pm
We did it! We were staying in our trailer a few weeks ago and it went down to 14 degrees. Kept feeling a draft from the small windows in the bedroom slide next to the bed. Just decided to try it before we went to bed to see if it would help. You bet it did...We also covered the roof vents in the bedroom and bathroom to help seal them. Worked like a champ. Won't travel with out the stuff now. B.O. Former Ram/Cummins owner 2015 Silverado 3500 D/A DRW Yup I'm a fanboy! 2016 Cedar Creek 36CKTS |
Posted By: mikestock
on 12/20/10 02:14pm
skipnchar wrote: ![]() I wouldn't think a sheet of a few millimeters thick plastic is going to do much to insulate anything. Might stop a draft if your windows leak but won't do much insulating. Reflextix works reasonably well for the purpose due to the dead air space between it's layers and still allows some light to pass through. That is the key and I think was the OP's original thought. A dead air space must be established to make a difference. Cardboard box material also makes a good insulator. I made pieces in the shape of our bedroom windows for insulation and also to keep out the early light. When the temperature drops it really makes a difference. Spray painted them black and pretty much leave them there full time. |
Posted By: Gdetrailer
on 12/20/10 05:44pm
Might work but with larger windows you would have to piece it together. A better idea would be packing bubble wrap, gives addition dead air space. For bubble wrap idea (and many more ideas) check out BUILDITSOLAR.COM |
Posted By: tktplz
on 12/20/10 05:19am
That plastic wrap stuff that you use for the windows that shrinks when you heat it with a blow dryer is so cheap. $7.00 or $8.00 a kit that in a camper, 1 kit will probably do the windows for 2 winters.
"Confidence is the feeling you have before you fully understand the situation" 1999 Toyota Tacoma Pre-Runner TorkLift Tie Downs 2010 Travel Lite 690FD 1996 ZX11 Ninja 2000 ZRX1100 2008 Yamaha Zuma 50 Scooter 2010 "Blue" Bulldog, "Luna" ![]() |
Posted By: Dutch_12078
on 12/20/10 06:53am
skipnchar wrote: ![]() I wouldn't think a sheet of a few millimeters thick plastic is going to do much to insulate anything. Might stop a draft if your windows leak but won't do much insulating. Reflextix works reasonably well for the purpose due to the dead air space between it's layers and still allows some light to pass through. The plastic film has the same effect as the Reflectix in that it creates a dead air space. It's the still air that provides the insulation, just as it does in most other insulation. Dutch 2001 GBM Landau 34' Class A F53 chassis, Triton V10, TST TPMS Bigfoot Automatic Leveling System 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/Blue Ox baseplate ![]() |
Posted By: hitchup
on 12/20/10 07:59am
The self-stick kitchen wrap isn't very wide. As suggested by others, look at your Home Improvement store to get better quality. Years ago, we used standard visqueen stapled over a sliding glass door in our home. Now in our RV, even with dual pane windows, it doesn't block out the cold. We have dual cell blinds and curtains to block out the cold. Together, both help when temps warmed up to 25 deg last night.... 2014 DRV Mobile Suite Estates 38RSB3....our custom home 2014 Ford F450 KR CC 4x4......his office 2015 Lance 1172 TC.....mobile Motel FOR SALE Working Fulltimers since 3/2005 "Shoot for the Moon! Even if you miss it, you will land among the Stars." ![]() |
Posted By: Admiral
on 12/20/10 11:47am
OP here...I considered the posterboard (can't see out) and have used reflectix (can't see out and NO light comes in) in the past. OK for the bedroom but not in the rest of the RV. Not that I'm nosy but I do like to see what's going on if for nothing else, security while traveling, that's why I was considering the clear. I'm going to look into the Home Depot stuff. Thanks for the responses |
Posted By: eto1
on 12/31/10 04:48pm
I'm in South Dakota for the winter and have single pane windows. Without insulation, I was getting sheets of ice on the inside of my windows when it got down into the single digits. I bought one of the plastic shrink wrap kits from Wal-Mart and installed them and the difference is night and day. No ice and I still get to keep my view. It's currently -1 degrees and they seem to be working fine, so fingers crossed.
Posted By: JBarca
on 12/29/10 06:31am
FiverDragger wrote: ![]() Here is something to try for interior storm windows. Make the windows as you said with a wood frame to fit with plexglass panel. Rout a dado in the wood frame for the window frame so the wood sit tightly against the wall and also the window frame. Put a strip of stick on magnetic gasket material on the aluminum window frame and the wooden storm window frame. When needed stick storm window to the frame. When not needed pull it off and store until next winter. If we full timed this is what I would do. Ron Ron, H'mm OK I'm following right there with ya. I like the magnetic idea ![]() I just have to figure out in my case how to apply the magnetic strip concept. I suppose I could make the wood frame wide enough to 1st bottom out on the wall to seal off then maybe do something on the aluminum frame with a nice looking metal (iron) insert. Embedded in the wood would be 4 , 6 or 8 rare earth magnets or the magnetic strip to line up with the metal strip on the aluminum. Or just move the whole thing slightly outboard of the window frame and put the nice looking metal inserts on the wall. Like 4, 6 or 8 round nice silver dots of steel. I like it. Will refine the idea between now and when ever I make it to the construction phase. Thanks a million of the idea!! John John & Cindy 2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 CC, SB, Lariat & FX4 package 21,000 GCWR, 11,000 GVWR Ford Tow Command 1,700# Reese HP hitch & HP Dual Cam 2 1/2" Towbeast Receiver 2004 Sunline Solaris T310SR (I wish we were camping!) ![]() |
Posted By: FiverDragger
on 12/28/10 07:31pm
Here is something to try for interior storm windows. Make the windows as you said with a wood frame to fit with plexglass panel. Rout a dado in the wood frame for the window frame so the wood sit tightly against the wall and also the window frame. Put a strip of stick on magnetic gasket material on the aluminum window frame and the wooden storm window frame. When needed stick storm window to the frame. When not needed pull it off and store until next winter. If we full timed this is what I would do. Ron 2002 Chevy 2500HD 6.0 4.10 axle ext cab longbox 36' Carriage Lite Dbl Slide Fifth Wheel Ron, Barb and Scooter the watchmop |
Posted By: JBarca
on 12/24/10 04:19pm
I have used the shrink wrap kit with good results, but some things learned as well. Here is the stuff ![]() Here it is installed. I put it in the 1/2" wide aluminum channel so it is not sticking it to the walls. ![]() Here is the back windows, but we have done the entire camper. NOTE: The windows are much more clear. However when I was doing this and taking the picture there was moisture on the windows that later evaporates off. ![]() Some learn'ings. 1. This for sure helps, a good 90% better. If done air tight there is no sweat on the glass. 2. It's cheap, about the cheapest one can do this for. 3. Apply the windows treatment before it gets cold. If not the 2 sided tape has a hard time sticking to very cold aluminum. 4. Each spring remove the plastic and clean off the metal flange so the double sided tape does not weld itself on. 5. Metal sweat, the aluminum edge still sweats. Each morning I go around with a dry dish cloth and wipe up the excess. Not that bad to do but should be done so the water does not drop off and soak something. Be care full and just lightly press the cloth to not accidentally pop the shrink wrap off. See here for metal sweat ![]() Now to combat the metal sweat I have tried this. I insulated the space between the wall frame and the aluminum. Here is one window. ![]() Cut the insulation to the width needed and inserted into the air space ![]() The holding flange off showing the large hole. CAUTION when you remove this flange. It is what holds the window into the camper. ![]() Used pipe insulation to fill that space ![]() And put the flange back on. ![]() Results, well not at all what I was hoping for, it helped maybe 10% better on the metal sweat. So from this thought I figured out the problem. While the shrink wrap helps keep the window dry and stops the heat leaving and cold coming in, the metal frame conducts heat and cold in this case. Since the metal is cold from the outside the moisture inside condenses on it. Not that someone did not discover that moisture forms on cold surfaces when it is warm inside eon's ago but it now dawned on me how to help it once I understood the problem. Just stop the cold conduction problem. So I made up an insulating gasket for the flange and the screw heads. As a test for the 1st one used a white piece of construction paper board. ![]() ![]() Made up gaskets for the screw heads too ![]() ![]() And the one test window all done. This also had the pipe wrap insulation in the air space. ![]() So I used the shrink wrap over this as before. The result. Well this did help, at least a 75% reduction in metal sweat over not having it. The bad news that was a lot of work to still have 25% left... The gasket I used was not effective enough to stop the heat conduction. Now to the next option that I feel (hope) will solve the issue. Make interior storm windows. They will have a thin wood frame that will be glazed with thin Lexan or plexiglass and the storm outer frame will go over the entire inside metal flange area and rest on the camper wall. May need to put some type of gasket on the storm frame to softly seal to the wall. This will then an be easy on and off storm window. No more stretch wrap and no more metal sweat. Yes it may take some time building storm windows but it is therapeutic for me and one set will last the life time of the camper. So if you want the cheap way out, use the shrink wrap and wipe the metal edge each morning. Hope this helps and if anyone has made storms for a camper, I be glad to see how you did it. John * This post was edited 12/24/10 09:08pm by JBarca * |
Posted By: Wife'nHubby
on 12/24/10 08:31pm
John, Very well documented! Thank you! Do you think very thin rubber gasket material would work better than the construction paper you used? Shari Wisconsin - the best place to be! ![]() |
Posted By: smthbros
on 12/24/10 08:33pm
Hope this helps and if anyone has made storms, be glad to see how you did it. Aluminum storm window frame kits are available at some home centers. |
on 12/25/10 04:56am
excellently done JBarca bumpy |
Posted By: JBarca
on 12/25/10 10:25am
Wife'nHubby wrote: ![]() John, Very well documented! Thank you! Do you think very thin rubber gasket material would work better than the construction paper you used? Shari Hi Shari Thank you. Rubber will work too however I do not know if I can find white and the type of rubber that will not crumble over time in the sun. H’mm maybe a clear vinyl sheet to cut it out of? Never thought of that. Thanks for the inspiration! Part of the issue I was working thru is the thickness of the gasket. Thicker will provide more insulating effects even if made from paperboard. Sort of like the thickness of the backing board on a pad of paper. However when I go thicker it also changes the metal flange clamping tightness to the inside wall preventing the window from falling out. I could create a thick gasket both in the joint where the flange joins to the window frame and then also where the metal flange presses against the wall. That way the clamping distance to hold the window in is the same. This then means 2 large gaskets per window. And in my floor plan I have 16 windows…. These windows are not made to be winter windows that is for sure. The gasket test on the one window helped show me the problem I was up against. Even if I went the gasket route I still then need to deal with the shrink wrap each year. Which is doable. I have sort of resided to making inside storm windows and then can take them on and off at a moments notice. We leave the window film on some times a pretty long ways into the season. And last year thru the summer as well as it keep the AC in better as we went from winter to full on summer….. If I ever buy another camper it will have insulated windows on it. smthbros wrote: ![]() Aluminum storm window frame kits are available at some home centers. Thanks smthbros. Didn’t realize that. I’ll look next time I’m there to see what they have to work with. Bumpyroad wrote: ![]() excellently done JBarca bumpy Thanks Bumpy. Figured the pics would help show what you and the other folks where talking about with the shrink wrap. Pics go a long way on these kinds of things. John |
Posted By: ralexis
on 12/23/10 09:07pm
Wally-World sells a film kit made just for what you want to do. Just use the included double-stick tape and adhere the film to it. Then heat it with a hair dryer till it's tight. We did this to ours four years ago and it's still as good as new. It's like having double pane windows. Cheep too!
LSU Tiger Fan Retired U.S. Air Force Pretty good Cajun Cook Fair Skeet Shooter Over-the-Hill Skiier NASCAR Bum One Lovely Wife Two Ugly Sons Six Beautiful Grandkids One Lucky Dog |
Posted By: ralexis
on 12/24/10 09:12am
deltamaster wrote: ![]() ralexis wrote: ![]() Wally-World sells a film kit made just for what you want to do. Just use the included double-stick tape and adhere the film to it. Then heat it with a hair dryer till it's tight. We did this to ours four years ago and it's still as good as new. It's like having double pane windows. Cheep too! I will check out the Hardware department at Walmart on your suggestion. Thank you. Only bad thing is that this will not prevent the window frame from transfering cold inside. The aluminum frame will still become cold. |
on 12/24/10 09:31am
that reminds me. years back I had a house with slider windows and aluminum frames. I just glued wooden screen door? molding on them to insulate them and to prevent condensation. bumpy |
on 12/24/10 02:20am
ralexis wrote: ![]() Wally-World sells a film kit made just for what you want to do. Just use the included double-stick tape and adhere the film to it. Then heat it with a hair dryer till it's tight. We did this to ours four years ago and it's still as good as new. It's like having double pane windows. Cheep too! I will check out the Hardware department at Walmart on your suggestion. Thank you. |
Posted By: Alpenliter
on 12/20/10 09:03pm
I used the Frost King kit on my windows first thing this fall. Before installing, I could feel a draft near my window and had lots of condensation. After installing the kit, no drafts, no condensation. It's certainly worth the price, about $8 and getting rid of the condensation is a bonus.
My first Wife Linda, 45+years 2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade Bulletproof Diesel upgrades 1997 33' Alpenlite 400 Watts Solar Lifetime Good Sam Member #39644174 Escapees SKP#89882 Vietnam Vet '67-'68 [ Note: Due to invalid formatting, all formatting has been ignored. ![]() |
on 12/29/10 07:31am
Many of these ideas have merit. But remember if you are a full timer, you have to have someplace to store these frames when not needed.
Print | Close |
