RV.Net Open Roads Forum: Truck Campers: Refrig NOT as cold as before!
 > Refrig NOT as cold as before!
Page of 6
aztecaa
USA/Baja
Posted: 01/12/11 02:21pm Link  |  Print  |  Notify Moderator
Referring to cold as before, meaning working with temperature where it should be.
Yes, always level and when I start my engine once a month and let it run for 10 minutes, I check the hydraulic levelers to insure level.
I did notice the Therm was slide down and so I raised it up!
I do need to find my temp gauge I used to have hanging on the inside to see where the temp is.
Thanks![emoticon]
1994 Fleetwood Pace Arrow 37' 460 Engine
2 Solar panels
2005 Four Winds Express Lite 25'
aztecaa
USA/Baja
Posted: 01/23/11 08:58pm Link  |  Print  |  Notify Moderator
Back to where it was before! Meaning 45 degrees on the lowest setting.
Thanks for the advice on raising the thingy majingy!
[emoticon]
Raften
Northern Calfornia
Posted: 01/23/11 11:28pm Link  |  Print  |  Notify Moderator
bigfootford wrote:
Here's what Wayne and I have for thermometers. I liked them so much I put one in my house fridge too.
It records the highest and the lowest temp....You can, with the push of a button, reset those readings and obtain new high and lows.
These folks are great and have the best price for this combo remote sensing 2 sensor fridge thermometers:
http://www.partshelf.com/ci00985.html
Jim
10-4 on a wireless outfit. I always know what temp it is inside. Always pre chill the contents when you can before you load for a trip.
Reddog1
El Dorado, CA
Posted: 01/24/11 09:07am Link  |  Print  |  Notify Moderator
[emoticon]
I wish you luck on the temps staying there.
My TC fridge will go up and down, for no obvious reason. I have a regular home fridge in my basement. The freezer bounces from 1-degree to 34-degrees. I use a remote thermometer on both refrigerators.
Wayne
mkirsch
Rochester, NY
Posted: 01/24/11 10:41am Link  |  Print  |  Notify Moderator
Wayne, either you have bad luck with refrigeration equipment, or you're a closet pyrokinetic. (i.e. a guy who can create fire with his thoughts, and it's manifesting itself in your refrigerators)
2002 Chevy 3500 DRW/8.1/Allison & 2000 Palomino B1500 popup TC
-Yes, I haul a popup with a dually. No, I don't think I need a dually to haul a popup.
bigfootford
Fair Oaks, California
Posted: 01/24/11 12:22pm Link  |  Print  |  Notify Moderator
Ummm I too have dual thermometers in my camper and home...
Right now the low high for my freezer in the house, since the last time I reset it now reads: -9 +13 and the temp is -1
My fridge section recorder reads 30 to 52 and the temp is now 36...
My RV fridge freezer section varies from :-6 to 16 and the fridge section 34-45...
I use the remote thermometers that I linked to...
So I don't know what you are trying to say...
When my fridge is off in the camper the thermometer stays at the ambient temp of the fridge...54 deg in both F and R....for days.
My meters are reading solidly.
Just because the temp varies...especially in a home frost free fridge does not mean that the contents are varying that much.
Wayne's thermostat in his camper is an old style mechanical type..It is not electronically controlled. It does vary more than the newer electronic controlled temp control.
Looks kind of like this:
[image] .
If you guys are interested about this go read about fridges here:
http://www.rvmobile.com/Tech/Trouble/gassys.htm
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
Reddog1
El Dorado, CA
Posted: 01/24/11 01:56pm Link  |  Print  |  Notify Moderator
I guess it could be either or both. Another possibility is it is more common than most people realize. The only way to know for sure is with thermometers that allow you to monitor.
Wayne
aztecaa
USA/Baja
Posted: 08/29/11 09:59am Link  |  Print  |  Notify Moderator
I have a block wall which the Refrigerator side is about 3-4' from. So there is not much ventilation. I believe that is my problem here. It works fine in the winter but not in the summer.
So I will have to make some sort of funnel type tubing since the wind blows from that side and up the Refrig vents.
[image][/img]
* This post was edited 08/29/11 12:05pm by aztecaa *
JoeChiOhki
Sauvie Island, OR
Posted: 08/29/11 02:25pm Link  |  Print  |  Notify Moderator
Here's both yer pics, the bbcode on one was broke.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
aztecaa
USA/Baja
Posted: 10/11/11 10:51pm Link  |  Print  |  Notify Moderator
OK....I'm Back with the refrig issue again!
Have had the RV parked and running on propane for 4 years straight.(no electric) I start the engine at least once a month and let it run for 10 minutes, checking the level always.
I have the frig set to level 5 which is the highest setting.
The temp inside the Frig is 58, NOT good!
The Freezer works excellent which is above the frig.
So any suggestions on what I can tinker with to get it colder in the frig.
Page of 6
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
