RV.Net Open Roads Forum: How to delaminate the not yet delaminated. A rotten story.
 > How to delaminate the not yet delaminated. A rotten story.
Page of 7
MuddyPaws1
A State
Posted: 04/21/11 02:01pm Link  |  Print  |  Notify Moderator
Eric&Lisa wrote:
When I had to rebuild my skirts, I sealed the snot out of them. A sticky, messy job. But I guarantee water won't get in.
x2. I even went as far as to first coat the whole wing in fiberglass resin before I put it on the camper.
swarner123
usa
Posted: 04/21/11 04:01pm Link  |  Print  |  Notify Moderator
Hi im new to this forum I have a question. How do I post pictures of my TC rot project. The image button is wanting a url and my pics are in a folder on my computer any help please??
MuddyPaws1
A State
Posted: 04/21/11 05:21pm Link  |  Print  |  Notify Moderator
Tutorial is here: CLICKY
Bottom line is that you have to have a photo host like photobucket and upload the pic there and then link to it here.
This forum does not allow attached uploads.
Jumbo Jet
Ozark Mountains, Arkansas
Posted: 04/21/11 06:23pm Link  |  Print  |  Notify Moderator
xp8103 wrote:
Just got a reply from Lance. Replacement wings are $230 plus a $30 crate fee PLUS shipping. But it included everything new needed including caulking, moldings, etc.... I'm going to slice off the piece of filon this afternoon with my dremel and a cutoff wheel and see what is to be seen under it. Not sure which direction I'm going yet.
Unless they are sending you a new rot proof composite material wing, you can build better yourself!
2008 Dodge Ram 3500 CTD 4x4 SRW - 2007 Lance 1055 - Torklift Tiedowns, Stableloads, Derringers, Pigtail - Hellwig Anti-Sway Bar - Rickson 19.5" wheels - Michelin XRV tires - Lance Cabover shocks, 2003 Keystone Laredo 29BH
swarner123
usa
Posted: 04/21/11 06:40pm Link  |  Print  |  Notify Moderator
PICTURES ARE AT
http://s639.photobucket.com/albums/uu117/wvsw2/
copy and Paste
I bought this Truck camper this winter as a project for me and my 7yr old boy Evan. It had rot on left rear corner due to awning installation, and the right wing rot due to road spray and bad seal. The left sewer wing is good. The camper is very nice and has a generator. Botton line is I didnt want to spend alot of money on a camper, and we love projects. Ill have 4500.00 total price of camper and repairs. Now I did all of repairs myself. The picture of the camper on my truck was the day I brought it home. The rear wing was bad so I removed it and replaced it with 3/4 plywood and glued 1/8 plywood to it with liquid nails and brad nails. The fiberglass panel is PFR bought in 4x8 sheets at Lowes 35.00 sheet. Got latex PFR glue used v notch trowl and glued the PFR to the 1/8 plywood. Once glued use hand roller do roll the PFR into the glue start in the middle and remove the air. Ill reuse all trim pieces. Use old wing as pattern for the new 3/4, 1/8 and PFR pannel The slide out was bad also same thing rebuilt with 3/4 x 1 1/2 pine from Lowes some steel angle brackets and the 1/8 plywood. (mom pop lumber yards have old 4x8 1/8 ugly panneling that I bought for 5 bucks a sheet and use the BACK to glue the exterior to.) So far it has turned out great. Ill install the slide out tomorrow. Ill put the laminate floor in the camper and the slide out. Lowes usually has 2-3 boxes of the lamanate floor on clearance. Evan and I will be camping at hit miss engine shows this summer in style. Ill post more pics later thanks for looking, pictures are not in order
steven warner west virginia
[image][image][image][image][image][image][image][image][image][image][image]
MuddyPaws1
A State
Posted: 04/21/11 10:28pm Link  |  Print  |  Notify Moderator
Nice.
spacedoutbob
SF Bay Area
Posted: 04/22/11 12:06am Link  |  Print  |  Notify Moderator
Wow! Very Impressive Repair Job. I can't wait to see it finished. I wish I had your skills. Thanks for posting, you give the rest of us hope in repairing our campers.
Bob in Calif.
* This post was edited 04/22/11 12:21am by spacedoutbob *
Good Sam Club Life Member
xp8103
Maine
Posted: 04/22/11 07:20am Link  |  Print  |  Notify Moderator
Excellent work there. Interesting that the filon is much more flexible than I thought it was to see how far you've curled it back. How did you separate your flion from the underlayment under it?
Nik
2011 Dodge Ram 3500 CTD "Outdoorsman"
CC, LB 4x4, SRW, 6-spd Auto, 3.73LSD, Timbrens, TorkLifts and HappiJac QwikLoads
2005 Lance 1010
Member - Cape Lookout Mobile Sportfishermen
swarner123
usa
Posted: 04/22/11 07:47am Link  |  Print  |  Notify Moderator
I used a 6 inch drywall trowl and kinda jamed it in between. These pics are of the finished left rear corner. It needs washed and buffed yet. The other pics are where I reinforced the tie downs. Under the gas tanks they have a 3/4 x 1 1/2 pine THATS ALL!!!! So I bolted a 2x3 aluminum angle and sealed around everything, the corner turned out good. These repairs can be done for very inexpencive
88lover
Posted: 04/23/11 06:37am Link  |  Print  |  Notify Moderator
When I replaced the wings on my Lance, I soaked the filon off of the luann then used 6" trowel and a machette to get the filon off of the deteriorated luann then used a 60 grit sander to remove any glue still visible. Since the frame on the wings was rotted, the luann and filon came off easy. The hardest part was the staples around the edges but careful extraction did the job. Good Luck
Page of 7
