xp8103
Maine
Hopefully, the deconstruction is complete. Once the pictures come thru I'll post them. I've been able to remove all the rotted stuff and most all of the wet stuff. There's still a little wet here and there. There must be something I can put on it to pull the water out besides air. Air might be the one tho. Anyhow, Its certainly fixable.
I've removed the luan from both the outer and inner filon sheets. How do you remove the residual and glue?
Nik
2011 Dodge Ram 3500 CTD "Outdoorsman"
CC, LB 4x4, SRW, 6-spd Auto, 3.73LSD, Timbrens, TorkLifts and HappiJac QwikLoads
2005 Lance 1010
Member - Cape Lookout Mobile Sportfishermen
swarner123
usa
I used a DA air orbital sander with 120 grit and held my left hand on the falon and sanded with my right hand kinda presing the falon into my sander, it worked great. Using the air compressor blew all the dust off real good and with a damp rag wiped the 1/8 ply and the falon before trowling on the glue.. Love to see your pics when you get them. The kids and I camped last night the camper was fantastic ,im glad it finished.....
steven warner
xp8103
Maine
Picked up some poplar for the framing and a couple new galvanized carriage bolts at Home Depot today. didn't find ANY 1/8" ply or luan.... Hmmmm.... D/A sounds like the ticket. Thanks for the tip.
88lover
xp8103 wrote: Picked up some poplar for the framing and a couple new galvanized carriage bolts at Home Depot today. didn't find ANY 1/8" ply or lauan.... Hmmmm.... D/A sounds like the ticket. Thanks for the tip. 1/8 luan is special order at Lowes. I bought 2 sheets last summer for $20.00 each No one even at the professional desk even knew that they were available until I gave them the SKU and Lowes order number. I found the numbers on line by going to the National Lowes site and did a search
1/8 x 4 x 8 Lauan Hardwood Plywood
Item #: 95321 | Model #: LBR95321
hope this helps
xp8103
Maine
It does. I'll take those numbers with me! Thanks!
Am not finding Latex FRP adhesive in anything but a 3.5 gallon tub for $55 at lowes. Is there a substitute? Or is it available in smaller quantities someplace else for less??
swarner123
usa
Yes Lowes has the big tubs, I got mine at OC Cluss lumber yard in a 1 gallon for around 21.00. Check your smaller lumber yards. Its used alot for installing tub shower surrounds.
xp8103
Maine
88lover wrote: 1/8 luan is special order at Lowes. I bought 2 sheets last summer for $20.00 each No one even at the professional desk even knew that they were available until I gave them the SKU and Lowes order number. I found the numbers on line by going to the National Lowes site and did a search
hope this helps
My local Lowes can find the sku but they can't get it shipped to Maine. they said there isn't a price or anything available to them. Called my local lumber yard, they said they don't carry, try the big box. So it looks like I'm going to have to buy a sheet of the "5.2mm" and belt-sand off a layer or so to get down to an eighth.
xp8103
Maine
Still looking for an alternative to FRP adhesive.....
swarner123
usa
http://shop.ebay.com/i.html?_nkw=FRP+adhesive&_sacat=0&_odkw=pfr&_osacat=0&_trksid=p3286.c0.m270.l1313
copy and paste this link to ebay.
Or go to ebay and search FRP adhesive
xp8103
Maine
Found it! Thanks! don't know why I didn't bother to go to eBay.... Just dont think eBay when I think glue I guess!
