casper6871 wrote: ... Coleman uses a weird connector to the unit itself and that fitting is fused to the reg. ...
The regulator is NOT fused to the pipe. If you look at the picture I posted earlier you will see the regulator can be removed from the pipe that goes to the special connector. The regulator DOES unscrew if you give it enough force. NO, you will NOT damage it but I did buy a second regulator from Coleman just for this hookup and to also have an unmodified one .... which I have never used.
Gene and DW Ginny 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363 Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Says "image not available due to your settings" may be because I'm on an iPad, I'll try from a computer and see if I can see it. Thank you
2009 Berkshire 390 Bunk House
2000 Dutchstar DP3859 *SOLD*
