RV.Net Open Roads Forum: Class A Motorhomes: BREEZE HANDLING ISSUES - Mike Mas
 > BREEZE HANDLING ISSUES - Mike Mas
wolfe10
Posted: 11/18/11 05:00pm Link  |  Print  |  Notify Moderator
HeresLucy wrote:
The Breeze is built on Tiffin's PowerGlide chassis. You will probably need to take these questions to the TRVN forum.
Lucy
Thanks, Lucy.
I don't happen to have a Tiffin product, so I don't monitor that site.
If you/others happen to get any factual info on this, would appreciate your posting it here.
Thanks.
Brett
Brett Wolfe
2003 Alpine 38'
HeresLucy
Central Illinois
Posted: 11/18/11 05:43pm Link  |  Print  |  Notify Moderator
wolfe10 wrote:
Lucy
Thanks, Lucy.
Thanks.
Brett
I'm really out of my element on this topic and since we don't own a Breeze I really don't follow the discussions on it. But in an interest to help I looked thru the replies in one the links I provided earlier and this one had some details that might make sense to folks who understands this stuff. I'm leaving out the member's name. This was posted in July of 2011.
"There may be several "causes" for your steering problem, and if you work with the factory (Tiffin) they should be able to correct your steering problems.
First, they are now recommending lowering the tire pressures to 80-85 psi all around; as compared to there original requirement of 110 psi. This pressure is sufficient to handle the maximum vehicle weight ratings on each axle, but you still need to get your coach weighed -- preferably on all four corners -- to make sure you are not over weight on one of the corners.
Next, Tiffin has issued a new set of alignment specifications -- they are available from Gary Harris at Tiffin -- that have new values for caster, camber and ride height. Both sets of axles need to be checked for alignment: the critical dimensions for the rear are ride height and thrust angle, while ride height and caster are critical for the front.
Next, the vehicle needs to be loaded to the approximate weight and distribution you will using while travelling. It became apparent early on to most Breeze owners that the Power Glide chassis were aligned at chassis build-out, but many did not receive re-alignment after the the "house" was added.
Next, have the alignment performed by a reliable truck facility and have them communicate with Tiffin (Gary Harris) prior to undertaking the alignment.
Finally, don't be afraid to become vocal with Red Bay -- up to and including with Bob Tiffin -- until you are comfortable with the ride."
Hopefully it helps?
Lucy
* This post was edited 11/18/11 05:56pm by HeresLucy *
2006 Allegro Bus 40' DP
2005 Grand Cherokee
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
