RV.Net Open Roads Forum: Truck Campers: Hitch extension effect on axle weights
 > Hitch extension effect on axle weights
kereams
Beaverton, OR
Posted: 07/18/11 05:06pm Link  |  Print  |  Notify Moderator
Hello All. I have created a spreadsheet to calculate the effect of a hitch extension on the axle weights of the truck. The math is thorough and should be accurate. You will need to download the document to use it as Google Docs is not compatible with some of the items in the spreadsheet. It was created with Excel 2010 but should be backwards compatible if office converts it properly. The cells in Green can be manipulated to change the resultants.
Let me know what you think!
Cheers,
Keith
Link to Google Document - Download in top left corner
*2011 F350 SRW CC/LB/PSD - Mods: Custom overload springs with custom early engagement blocks~Firestone Airbags~Hellwig Big Wig Rear Sway~Rancho RS9000XL~Bilstein Steering Damper~19.5" Hankook DH01'a on steel wheels.
*2012 Chalet Ascent S95R Camper
SoCalDesertRider
Arizona desert
Posted: 07/18/11 07:28pm Link  |  Print  |  Notify Moderator
I do it the old fashioned way...
WB = Wheelbase Length
HA = Hitch to Axle distance
TW = Tongue Weight
FA = weight removed from front axle
RA = weight added to rear axle
HA / WB x TW = FA
TW + FA = RA
Example-
170" wheelbase length
60" hitch to axle distance
500 lb tongue weight
60 / 170 x 500 = 176
176 lbs are removed from the front axle
500 + 176 = 676
676 lbs are added to the rear axle
Now move the hitch to axle distance out to 100"...
100 / 170 x 500 = 294
294 lbs are removed from the front axle
500 + 294 = 794
794 lbs are added to the rear axle
[emoticon]
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
trails2004
Outside
Posted: 07/18/11 08:20pm Link  |  Print  |  Notify Moderator
Thanks for your efforts-- This should be in the TC University!
BradW
Mayor of Flat Rock
Posted: 07/20/11 01:19pm Link  |  Print  |  Notify Moderator
DONE!
Good Info! Thanks for Posting.
Brad
Wake Up America
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
