RV.Net Open Roads Forum: Wobbly Table - Modified Base Cone Fix!
 > Wobbly Table - Modified Base Cone Fix!
deweysmith5
Wabash, IN
Posted: 06/28/12 01:34pm Link  |  Print  |  Notify Moderator
Hmmm, I think I'll have to look into this fix...Thanks
2016 Cougar xlite 27rks
2015 Duramax Z71 Silverado
The Wife, The Lab, and sometimes a grandkid or two
64thunderbolt
Az
Posted: 06/28/12 04:10pm Link  |  Print  |  Notify Moderator
Me too, mine has been a pita forever. Never think about it till I sit down to eat. LOL.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
08 Arctic Cat Prowler 700XTX
profdant139
Posted: 06/28/12 04:18pm Link  |  Print  |  Notify Moderator
Very good detective work!! This is now on my to do list!!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
pkunk
Questa, NM
Posted: 06/28/12 05:40pm Link  |  Print  |  Notify Moderator
We never take ours down, so I screwed a 3/4 x 3/4 board to the wall and screwed up through that to the table top. Solid!
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
Dakzuki
Carnation, Wa, USA
Posted: 06/30/12 11:01am Link  |  Print  |  Notify Moderator
If your table goes up flush to the wall there's another trick. The guy that owned my Chinook before me did this mod:
Fasten a cleat to the wall (kinda like pkunk did but you'll need a bit bigger piece of wood) so that the table fits flush on top of it. Drill the cleat and install 2 vertical metal pins spaced apart as far as you see fit.
Drill the underside of the table at the pin locations and install some metal inserts that the pins will fit into. The inserts will be stronger than the base wood (or particle board) your table is made of.
Now when you install the table it will be supported vertically by the tube(s) and at the end by the cleat positively located laterally by the pins. It works great and the dinette can still be used as a bed.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
Alaskan Class C
Anchorage
Posted: 06/30/12 11:32am Link  |  Print  |  Notify Moderator
My friend just solved this in his rv by converting the table to a wall mount with a leg at the end of the table. Now its solid and still can come apart to use the dinette as a bed. He bought a conversion kit at the local rv store.
This kit of course wont work if your wobbly table doesn't sit next to a wall.
1978 Itasca, It's old but I own it....
nadkaw1957
Reno
Posted: 06/30/12 07:10pm Link  |  Print  |  Notify Moderator
That was my solution - couldn't be happier with it.
2011 Trail Sport 25S
2015 Ram 1500 EcoDiesel
Tom&Dale
Sammamish, WA
Posted: 06/30/12 10:47pm Link  |  Print  |  Notify Moderator
I'll also give a recommendation to the single leg option. Used this hinge along with this support leg.
Took about 2 hours to install since it is a pivot from table to the bed height and I wanted to get the measurements absolutely correct since both the hinge bracket and wall plates are mounted on the wall. They have a drawing on the above link that shows how it works when finished.
A benefit is that now we use the dinette bed not for lying down but sitting up and watching a movie together after dinner. While that could be done before but it was a pain to take the table down and put backup. Plus you had to put those two tubes someplace.
Good luck,
Tom
02 Dodge 2500 CTD, Edge EZ, Goerend transmission (3.55 axle ratio), BrakeSmart, BD exhaust brake, Firestone Ride-Rite air bags, Husky 16K hitch & towing our 05 Americana LC30/31 RL
phenrichs
Watertown, SD
Posted: 07/01/12 08:13am Link  |  Print  |  Notify Moderator
great idea for the wall. I have a U-dinette so no wall flush option for me. Still trying to figure it out. I am thinking of getting a small pipe and flattening the ends to make a removable support bar much like some brands use as support for hybrid bunks. One end on bottom of table top and the other end on the bottom of the dinette booth.
2006 Ram 3500 Megacab Cummins
2012 Keystone Sprinter 311BHS
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
