RV.Net Open Roads Forum: Truck Campers: Another shower hose extension thread
 > Another shower hose extension thread
76Scoutman
Huntsville, AL
Posted: 10/10/11 08:56am Link  |  Print  |  Notify Moderator
So the last trip out with our TC I realized just how short the outside shower hose was. We have pop up shower privy and it had to sit right beside the truck for the hose to reach. I remembered that there was a thread on here about making a longer one but I didn't want any splices in mine so I set off to lowes with my shower head in hand looking for a solution...
Here's what I came up with and I figured I'd share it and the picts with ya'll.
The output of my outside shower points straight up and I don't have much room for a straight fitting so I found a 90* PEX 1/2" barb to 1/2" female pipe thread FPT fitting. On the other end of the 3/8" ID fiber reinforced hose I put a PEX 1/2" barb to 1/2" female pipe thread FPT (straight fitting). This threaded right onto the shower head perfectly with no adapters and no splices. I used about 12' of hose but you could use more or less. If you don't like the RV shower then you could use a kitchen sink sprayer or many other items from the lawn and garden section. I just used regular hose clamps to secure everything. The fittings were $3-4 each and I have about $10 in hose so this is an easy $20 project if you use your outside shower for more than filling the dog's water bowl. :-)
And the finished product...
Reddog1
El Dorado, CA
Posted: 10/10/11 09:05am Link  |  Print  |  Notify Moderator
Very simple and straight forward.
I do not recall why, but I think the RV Shower head is designed differently than the standard shower dead or kitchen sink sprayer. Maybe someone that knows for sure will chime in.
Wayne
PapPappy
Wilmington, NC
Posted: 10/10/11 09:39am Link  |  Print  |  Notify Moderator
I never thought of using the shower for filling the dogs bowl....thanks[emoticon]
Only kidding...great tip, and the pictures saved you a few thousands words![emoticon]
happy Camping[emoticon]
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau ">
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.">
Purchased April 2008"> FMCA# F407293
The Pets
crazyhorse
peoria,az.
Posted: 10/10/11 09:07am Link  |  Print  |  Notify Moderator
great tip
76Scoutman
Huntsville, AL
Posted: 10/10/11 09:38am Link  |  Print  |  Notify Moderator
Wayne
The back of the shower head had a cutoff that you rotate with your thumb for conserving water. If the flow is too low, I read on here that you can drill out the restrictor holes in the threaded base to get a 'firmer' shower stream.
The nice thing about the kitchen sink sprayer is that it probably consumes the least water cause you can't leave it on. But that could be a drawback as well.
BradW
Mayor of Flat Rock
Posted: 10/10/11 11:41am Link  |  Print  |  Notify Moderator
Great idea! Added to the TCU stickie Thread.
