RV.Net Open Roads Forum: Custom built tie downs on an 06 Dodge 3500
 > Custom built tie downs on an 06 Dodge 3500
76Scoutman
Huntsville, AL
Posted: 10/10/11 12:00pm Link  |  Print  |  Notify Moderator
When I bought my TC the previous owner threw in a set of 4 bed rail tie downs and a box of misc hardware, hooks, chains, turnbuckles, etc. I've wanted to build my own set of tie downs since I'm cheap and have all the materials/abilities to do so. After a lot of creeper time under the truck scratching my head on how I wanted to go about doing this I came up with a solution.
For the rear...
The bumper brackets have a rectangular hole in them that was just about right for a piece of receiver tube. I cut holes in the chrome bumper to let the tube stick out and trimmed it with edge trim. I had some cool pins that didn't have a project yet so I used them here and rivited the lanyard to the bumper bracket to keep them from getting lost.
The rear insert you have to slide in before putting the TC on cause the tie down and the camper jack want to occupy the same space. Once on, just slide them out and put the pin in.
I'll let the picts do the rest...
My rear end is naked!!
The brackets I started with.
Trimmed a little material out of the hole for the tube to fit in.
Once the bracket was done, I marked where the tube was going to come out, drilled the 4 corner holes from the inside, then connected the dots with the plasma cutter. The hole is not square since it's on a complex curved surface which is why I did it this way. I had a flexible straight edge clamped to guide the plasma tip and it cut much better through the chrome bumper than I imagined it would.
The finished hole.
* This post was edited 10/10/11 12:26pm by 76Scoutman *
76Scoutman
Huntsville, AL
Posted: 10/10/11 12:16pm Link  |  Print  |  Notify Moderator
Ignore the dent in either end of my bumper. [emoticon]
After the hole was cut in the bumper I could then slide out the 2.5 x 2.5" tube to mark the wierd cut for the outside.
Holes prep'd and ready to go.
Painted only the parts that wouldn't get paint when assembled.
Tack'd in. C-clamp holding things firm and parallel to the bracket and bumper.
Burned in.
76Scoutman
Huntsville, AL
Posted: 10/10/11 12:31pm Link  |  Print  |  Notify Moderator
Mostly finished. Blue tape on to keep from scratching truck paint when putting the bumper back on.
Finished.
76Scoutman
Huntsville, AL
Posted: 10/10/11 12:43pm Link  |  Print  |  Notify Moderator
The inserts...
I did a quick model of the end plate to make sure it was how I wanted it. Once I had tweaked the part to my liking, I printed out to scale, center punched the holes and traced the outside for the plasma cutter. I tap'd the holes for the fold down step. They're really only used when the TC is off, if I wanted to leave the inserts in. Not sure if I'll keep the steps or not.
Shot from the rear.
* This post was edited 10/10/11 12:54pm by 76Scoutman *
76Scoutman
Huntsville, AL
Posted: 10/10/11 12:52pm Link  |  Print  |  Notify Moderator
Oh and the rig I'm working on. [emoticon]
So now on to the front mounts...
I'll save ya'll the fab steps and get right on to the mounts. I'll have to go out and snap a few shots of them on the truck as I just put them on last night.
Pre paint, passengers side.
Pre paint, drivers side.
The finished product after paint.
ScottG
Bothell Wa.
Posted: 10/10/11 12:56pm Link  |  Print  |  Notify Moderator
Nice design and very good looking welds!
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
SoCalDesertRider
Arizona desert
Posted: 10/10/11 01:43pm Link  |  Print  |  Notify Moderator
Very nice job on the layout, cutting, prep, fitting and welding. [emoticon]
For future reference, you can buy seamless 2" i.d. 1/4" wall square hitch tube at most metal suppliers, to use for nesting tube projects, rather than buying generic seamed tube and grinding out the inside seam. You can also buy it as a pre-fabricated receiver tube, with the 5/8" pin hole already drilled and the collar around one end. Check DiscountHitches.com, in their hitch fabrication parts section for the tubes.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
tilemantim
Santa Rosa,Ca
Posted: 10/10/11 02:09pm Link  |  Print  |  Notify Moderator
Very good... I did my own custom tie downs, but yours take the cake. Impressed...It won't be long before someone else copies your design...
76Scoutman
Huntsville, AL
Posted: 10/10/11 02:35pm Link  |  Print  |  Notify Moderator
Thanks for the kind words...
Honestly I didn't want to pay the price for seamless receiver tubing, especially for a whole 20' stick. I had bought about 12' of this stuff a while back for various projects and it works fairly well with no modification other than drilling the holes you want, where you want them. It's 2.5" square but has a 3/16" wall with the seam. The .25" wall is a better fit but like you said, it's either grind the seam (an air powered 1/2" wide belt sander works good for this), pay for the expensive stuff, or go premade. Most projects that I use receiver tube for get a 1/2" jack bolt tap'd into the side to eliminate play in the hitch. Since these wouldn't be in full time, and when they are they'd have tension on them anyway, I didn't bother.
76Scoutman
Huntsville, AL
Posted: 10/10/11 02:40pm Link  |  Print  |  Notify Moderator
Here's a quick side shot and one of them mounted.
