RV.Net Open Roads Forum: Truck Campers: Jack extensions?
 > Jack extensions?
~DJ~
Boise, Idaho
Posted: 11/09/11 07:59am Link  |  Print  |  Notify Moderator
Not for duallies but for length. There should be a safe, sturdy way to lift higher than wobbly blocks. Preferably bolt on so off loading at camp would be easy with a lifted truck.
Any ideas?
Thanks......DJ
'16 FORD F250 6.2. Air Bags
'16 Arctic Fox 25R. Xantrex 2000 inverter/charger, four Trojan 6 volts, 450 watts solar.
Super_Dave
Harrisville, UT
Posted: 11/09/11 08:38am Link  |  Print  |  Notify Moderator
Tube steel is sized such that most 1 up sizes slip nicely over the smaller size. You'd have to cut the foot off the existing jack leg. I'd think something like a hitch pin for easy on/off of the extension would be cool. Weld a 3" - 4" square base on the extention tube for a new foot and you're good to go.
I see you have a pop up, I've been told by friends that they are not suitable for camping in when off loaded due to inadequate floor structure. Is this something you've been doing successfully?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Decay
Allentown, Pa.
Posted: 11/09/11 08:46am Link  |  Print  |  Notify Moderator
I had my weldshop make me extensions. Same diameter plate top and bottom and 2" pipe. The rear are 8" long and the front are 6" long, bolted onto the existing bottom plate of the jack. I took a grinder with a cut off wheel and trimmed off about 1 1/2" on the front inside so the rear dual tire would clear when offloading and driving out from under the TC. Sorry, no pics. Hope this helps.
07 Dodge Dually Diesel 4wd
05 3319 Raptor
02 Lance 1121 with 96 Tracker/toad
84 VW Westie
08 Polaris RZR
02 HD FLHT Standard
05 KLR 650
1 Wife
2 Hounds
BeatCJ
Amboy, WA
Posted: 11/09/11 09:07am Link  |  Print  |  Notify Moderator
Reico-Titan used to sell a 6" extension that bolted to the foot of their hydraulic jack. I looked quickly at their site, and don't see it right now. I would bet if you called them, the extensions are still available. I doubt they are the same as the jacks on your Northstar, but I bet it would be easy to modify them to fit. Of course, they are a simple length of tube that has a foot at either end, and they bolt to the existing foot with 3 cap screws. Pretty easy to have made.
Gordon
Now
2001 GMC 3500 DRW, Duramax
2002 ALJO 196LT
Old
1987 F-350 XLT Lariat SRW 6.9
1986 Western Wilderness Alpine Dinette 11
DonCurley
La Sal, Utah
Posted: 11/09/11 09:40am Link  |  Print  |  Notify Moderator
I have a set of four of the 6" bolt-on extenders from Happijac. They work really well for campers equipped with Happijac jacks on high-stance pickups with larger diameter tires.
-'07 Dodge 3500/QC/SB/SRW/4x4/6.7L CTD/6-spd auto/35" Toyo MT's/Ride-Rite air bags/RS9000XL shocks
-'07 Apex 8 fully optioned w/220W solar/2 T-145's/2KW Prosine/Honda EU2000i/Tundra fridge/AC/etc
-'00 Jeep Wrangler TJ 4x4, highly modified w/5.9L Magnum V8
AnEv942
CA
Posted: 11/09/11 10:50am Link  |  Print  |  Notify Moderator
Thats just too simple Don!
Mark
~DJ~
Boise, Idaho
Posted: 11/09/11 12:38pm Link  |  Print  |  Notify Moderator
Definitely depends on the pop up. If you go to Northstar web site they have a video of maybe 12 guys standing in their pop up supported by the jacks only!!!
Other brands will obviously vary.
~DJ~
Boise, Idaho
Posted: 11/09/11 12:40pm Link  |  Print  |  Notify Moderator
That's what I need right there!!! If I get this used Sunlite I am looking at I will definitely need those. Probably just have a welding shop make me a set once I figure the length.
Thanks Don!!!!!!!!!!!! [emoticon]
dadwolf2
Henderson,NV
Posted: 11/09/11 06:06pm Link  |  Print  |  Notify Moderator
X2 Bought mine from Torklift online store.
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
Droland
Fort Worth, Texas
Posted: 11/09/11 08:03pm Link  |  Print  |  Notify Moderator
Those are exactly what I need! Anybody got a link for those?
2010 Ford F250
2001 Lance Lite 815
2004 Glastron SX175
 > Jack extensions?
