RV.Net Open Roads Forum: Travel Trailers: R-7 insulation value
 > R-7 insulation value
forrestrv
washington
Posted: 11/13/11 09:57pm Link  |  Print  |  Notify Moderator
I am in the process of buying a travel trailer with R-7 insulation in the roof, sidewalls and floor is this decent, or will it be fairly cold with R-7 insulation, i live in the pacific northwest.
B.O. Plenty
Minnesota
Posted: 11/13/11 10:12pm Link  |  Print  |  Notify Moderator
That's very minimal. Should be good for 40 degrees and above but not for any cold weather. It's going to be hot in the Summer as well.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
mockturtle
AZ
Posted: 11/13/11 10:32pm Link  |  Print  |  Notify Moderator
I agree that would be minimal insulation for an RV. My C is R-11. As B.O. has stated, it's not only important for cold weather but for hot weather, as well. Just face the fact that you will need to heat and cool your TT more than you would a better insulated unit.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
ktmrfs
Portland, Oregon
Posted: 11/13/11 10:40pm Link  |  Print  |  Notify Moderator
ours is r-9 walls, r-14 roof and r-30 floor, r-15 in the slideouts, and a covered bellypan. still gets hot in the summer and is adequate for our winter trips in the PNW. IMHO r-7 is going to be pretty marginal if you do any fall or spring camping, and it will take a pretty good A/C to keep it cool in the summer. As I mentioned our is adequate, we have camped in the winter with temps in the low 20's I wouldn't want anything colder with our trailer.
2011 Keystone Outback 295RE
forty4san
Full Time, Some Place
Posted: 11/13/11 11:12pm Link  |  Print  |  Notify Moderator
Your in the PNW, check out an Arctic Fox.
Susan I
2008 McKenzie Starwood 32 FKD TT
Hensley & Prodigy Brake Controller
03 Dodge 3500 Quad HO Diesel DRW 4:10 ">
Fulltiming, On the road somewhere. ">
LarryJM
NoVa
Posted: 11/14/11 02:35am Link  |  Print  |  Notify Moderator
Might want to check your specs for the floor since the Keystone sites says the floor is R-14 ... R-30 is high even for a S&B home.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
shum02
Burlington ON CDA
Posted: 11/14/11 04:41am Link  |  Print  |  Notify Moderator
My KZ is an R7-9 rig and we camp all winter up here in Ontario. Just requires a little more propane and an extra electric heater to keep the unit comfortable even down to -20C.
Unless your only camping with propane don't worry about it, you've already paid for the electricity. Finding and filling all the holes in a rig and stopping drafts as well as adding insulation to exterior doors and windows will also help a ton to make a rig comfortable.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
pianotuna
Regina, SK, Canada
Posted: 11/14/11 07:12am Link  |  Print  |  Notify Moderator
Hi,
A lot can be done to improve heat loss. Last year my "back yard" experiments results suggested about 430 Btu's per 1 degree delta T, or about 126 watts of heating.
I've been making modifications to my Class C to improve these numbers and prevent fresh water line freeze ups.
Our first cold weather arrived on the weekend and here are the results:
968 watts =~3304 btu's 18 C above ambient, 183.6 btu's per degree and 53.8 watts per degree.
Regards, Don
coolbreeze01
Redding, Ca
Posted: 11/14/11 09:00am Link  |  Print  |  Notify Moderator
As a comparison, our Komfort is R-18 Floor, R-17 Roof, R-7 Wall.
My latest Arctic Fox brochure lists R-18 Ceiling, R-7 Walls and Floor.
Have fun shopping.
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
TurnThePage
North ID
Posted: 11/14/11 09:43am Link  |  Print  |  Notify Moderator
Mine is also R7 all the way around. I want better eventually, but it's very livable in the mean time. My trailer is fairly small, and the 13.5k BTU AC has no problem keep it cool in the Summer. And it's not bad to heat in the Winter either. As others have pointed out, there are many things you can do to improve the situation: home made storm windows, insulated curtains, sleeping bags (or similar) stuffed into storage areas, insulate the roof vent, etc., etc. An electric heater on the low (750 watt) setting will keep the whole trailer comfy down to about 35F.
On edit: That's down to 35F without using the onboard furnace.
* This post was edited 11/14/11 10:19am by an administrator/moderator *
2015 Ram 1500
2004 Pioneer 18T6
