RV.Net Open Roads Forum: 07+ Ford E450 Passenger Seat Swivel Base?
 > 07+ Ford E450 Passenger Seat Swivel Base?
Ductape Dave
New Jersey, USA
Posted: 12/12/11 07:42pm Link  |  Print  |  Notify Moderator
Has anyone purchased an OEM swivel seat base from Discountvantruck.com for there 07+ E450 high back passenger seat?
Wanted to know how well it works?
If there is any play in the seat while traveling?
Or any other likes or dislikes?
Thanks in advance, Dave
2016 Coachmen Clipper 17BH
2016 Toyota 4Runner SR5
jim1632
Arlington, VA
Posted: 12/12/11 07:44pm Link  |  Print  |  Notify Moderator
Had one. Worked fine for me. Big problem is moving the seat back and forth to make it swivel.
Easy to install too.
knobhill24
Upper Michigan
Posted: 12/13/11 06:02am Link  |  Print  |  Notify Moderator
I have swivel base's in my Aspect I have to open the doors some and have move the seat back and forth to swivel. There is no play while traveling very seldom do I swivel the driver's you are limited to how much you recline by the steering wheel. What brand of swivel Winnebago use's I do not know.
rvtommy
blooming prairie minnesota
Posted: 12/13/11 07:43am Link  |  Print  |  Notify Moderator
The main reason the C does not come with swivel seats someone might sit side ways and not all the way around is if AIR BAG is set off ya will get hurt badly!!!!!!! If you do swivel just always have seat facinf forward when traveling!!! Good luck rvtommy
this is rvtommy
Ductape Dave
New Jersey, USA
Posted: 12/13/11 12:05pm Link  |  Print  |  Notify Moderator
Thanks to all, sounds like swiveling the seat is more trouble than its worth.
Replant
Someplace
Posted: 12/13/11 04:35pm Link  |  Print  |  Notify Moderator
My MH has swivel seats in the cab but doesn't have air-bags. I replaced the original E350 seats with nice leather power seats from a 2005 Expedition. Now they sit so high that I can barely reach the pedals. Getting into the cab is almost like climbing into a semi [emoticon]
So I now have to cut 3" from the center of the 6" pedestals and have them welded back together unless I can find something in the junk yard.
mrdcb18
Mooresville
Posted: 12/13/11 05:14pm Link  |  Print  |  Notify Moderator
Does any company make an Air ride seat base for the E-350 and 450?
Remmag
Painesville,OH 44077,United States
Posted: 12/13/11 06:55pm Link  |  Print  |  Notify Moderator
I have the DV&T swivel base in my '07 e450 and love it. It's not that much trouble to swivel and adds a comfortable seat to the living area.
DonCarol
Seekonk, MA
Posted: 12/22/11 02:09pm Link  |  Print  |  Notify Moderator
Just ordered swivel base for our 2010 Itasca Cambria 30C. I was told by DV&T that the install is very simple and start to finish should not exceed one hour. I did have to purchase a 65mm Star wrench in order to remove the front bolts on the bracket base. Will keep you posted as to how long it took to install and the actual difficulty in doing the job.
bukhrn
Lanexa, Va
Posted: 12/22/11 07:21pm Link  |  Print  |  Notify Moderator
I have an '07, & I don't see how you could make it work, if you slide it back to clear the dog house, the back hits the dinette back, & swiveling in it's present location would hit the drivers door?[emoticon] Just not enough clearence all the way around to swivel it.
2007 Forester 2941DS
2014 Ford Focus
