RV.Net Open Roads Forum: Truck Campers: Odyssey battery installation. Part 3
 > Odyssey battery installation. Part 3
msiminoff
Silicon Valley, CA
Posted: 01/02/12 12:05am Link  |  Print  |  Notify Moderator
I'm done [emoticon]
The last phase of my battery update was to run new power cables from the truck to the camper. I installed a 2-pole 200A connector into my truck bed and a corresponding pigtail on the camper. The power cables (4ga throughout) run straight to the passenger side battery terminals. Of course the pos' cable is fused at both ends. Unlike most other TC installations I've seen, I have chosen to use a manual battery disconnect switch inside my camper rather than an ignition operated solenoid or a voltage sensitive relay.
Here are some pic's:
In case you missed 'em, here are links to Part 1 and Part 2.
Happy New Year!
-Mark
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
pianotuna
Regina, SK, Canada
Posted: 01/02/12 06:48am Link  |  Print  |  Notify Moderator
Hi,
A very neat job!
Is that a diode on top of the battery?
I used manually switched relays--but took the power for them from the ignition "on" key position. This lets me control which battery to recharge first from the alternator.
Regards, Don
SoCalDesertRider
Arizona desert
Posted: 01/02/12 10:39am Link  |  Print  |  Notify Moderator
Looks nice! I like the circuit breaker right on top of the battery too. [emoticon]
I'm going to check out those Odyssey batteries. I may pick up 2 new ones to replace the starting batteries in my diesel F350. I have a pair of older Optimas in the gas F350, but I have heard bad things about the new Optimas made in Mexico. Their pricing is astronomical now too. I remember when Optimas were $120. Now they're about $200.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
SoCalDesertRider
Arizona desert
Posted: 01/02/12 12:02pm Link  |  Print  |  Notify Moderator
I checked out the Odyssey 1750 model, which fits my year F350's. Cost is $300-$350 each. Yikes!
msiminoff
Silicon Valley, CA
Posted: 01/02/12 12:32pm Link  |  Print  |  Notify Moderator
The DieHard Platinum P2 Group 65 is the identical battery as Odyssey's PC1750 and costs $199.00 at your local Sears store... and it comes with a 4-year free-replacement warranty.
The 'thing' on top of the battery is a fuse.
[emoticon]
SoCalDesertRider
Arizona desert
Posted: 01/02/12 03:17pm Link  |  Print  |  Notify Moderator
[emoticon]
Cool, thanks! [emoticon]
Sorry, I thought it was a resettable circuit breaker, rather than a replaceable fuse.
