RV.Net Open Roads Forum: Help dry camping and electric stopped working
 > Help dry camping and electric stopped working
LoneWolfWarrior
No where
Posted: 01/10/12 10:11pm Link  |  Print  |  Notify Moderator
Hi. I am at a rest stop for the night and I was running the generator. I had an electric heater going because I am low on propane and that was enough just for the night.But I used the microwave at the same time (i know, dumb. But this is my first time and its a newbie mistake) and something went. I checked the circuit breaker and nothing is flipped. But I have no power anywhere in the rv.
It's cold out and I've got blankets, but if anyone has any ideas I'd greatly appreciate it.
I have a four winds hurricane 2000 33 sl.
LoneWolfWarrior
2000 Four Winds Hurricane 33SL
Golden_HVAC
Fulltime, CA, USA
Posted: 01/10/12 10:20pm Link  |  Print  |  Notify Moderator
Hi,
So did the generator stall? Is it still running but no 120 volt power in the RV? Or no power to any light or anything in the RV? (you stated no power to the RV so I am to guess no lights or any 12 volt power?)
If the problem is only no 120 volt power, that is simple, just find the generator, turn on the 30 amp main breaker for the generator, and you will have power to the microwave and heater again. By running the heater on low heat, you can run the microwave (providing the water heater is not on electric.).
The microwave is about 12.5 amps, heater on high heat about 12.5 amps, and if your water heater is on, perhaps 8-10 amps, exceeding the 30 amp limit.
Certainly a new mistake, I know you will not do this again!
Yet if you truly have no power through out the coach, then try starting the engine to see if you have power to the lights again. You might have melted a 100 amp fuse for the batteries, or tripped a 45 amp fuse from the battery to converter.
Fred.
Old-Biscuit
Verde Valley
Did you check the circuit breaker on generator?
hawkman541
Livingston, Texas
Hey, Had the same thing happen to me one night in Corpus Christi on the beach. Mine turned out to be the breaker on the generator. Reset all the breakers and still nothing worked. I turned the generator off, reset the breakers and all returned to normal. Good Luck
2002 Ford F-450 Crew Cab
2013 Heartland Landmark San Antonio
Frank-10lb. Chihuahua
FIRE UP
Lake Havasu City AZ
Posted: 01/10/12 10:21pm Link  |  Print  |  Notify Moderator
Well Sir,
Is it possible you blew a "GFI" some place in the coach? If I recall, there's a breaker on the generator too. At least there was one on my previous coach, a '99 Bounder with the F-53 Chassis and V-10 Ford. So, you're saying none of the lights work, the water pump, the fridge is out too?
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
bfast54
Traverse City ,Mi.
Posted: 01/10/12 10:23pm Link  |  Print  |  Notify Moderator
Also, if you ned to..shut down the genny, and restart ..................after you check the breakers.
My genny, if you overload, you shut it down, to reset(thank goodness for remote stop/start.
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller">
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
LoneWolfWarrior
No where
Posted: 01/10/12 10:27pm Link  |  Print  |  Notify Moderator
Generator was still running, but no power other than battery operated lights. Going outsi de to check it.
hawkman541
Livingston, Texas
X2 on Fire UP. Forgot all about that GFI. If you reset the breaker, all is fine, but no power. Reset GFI also. Good Luck
LoneWolfWarrior
No where
Posted: 01/10/12 10:34pm Link  |  Print  |  Notify Moderator
That worked! Yay! Thanks so much guys! I won't ever do that again! G nite.
old guy
Oregon (pronounced Or e gun)
Posted: 01/10/12 11:07pm Link  |  Print  |  Notify Moderator
have you check the GFI in the bathroom
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
